4 Replies Latest reply on Jan 5, 2012 6:42 AM by KS_Coastal
    Move all guides to one layer in InDesign (AS)
    KS_Coastal Level 1
      I need to select all the guides in a 20 page document and move them to one layer. The shortcut is easy enough, but when I can only do one page at a time, I lose valueable time. I could really use a script. Any input?
      MAC OSX 10.5.8, ID CS5, AS preferred.
        • 1. Re: Move all guides to one layer in InDesign (AS)
          absqua Level 4
          Sorry, JS:
          function main(){
                    var doc = app.activeDocument, layer = doc.layers.item("Guides");
                    doc.guides.everyItem().itemLayer = layer.isValid ? layer : doc.layers.add({name: "Guides"});
                    layer.move(LocationOptions.AT_BEGINNING);
          if(app.documents.length > 0){
                    app.doScript(main, ScriptLanguage.JAVASCRIPT, undefined, UndoModes.ENTIRE_SCRIPT, "Move Guides");
          Jeff
          • 2. Re: Move all guides to one layer in InDesign (AS)
            KS_Coastal Level 1
            JS - better than nothing (which is what I have now). :-) Thank you!
            • 3. Re: Move all guides to one layer in InDesign (AS)
              Kevin Parrott Level 2
              gidday KS_Coastal
              try this, paste this in script editor, save as file format text file, place it in your scripts panel folder in indesign, you can then run it while your working. (tested using cs5.5 under OSX 10.6.8)(should work under cs5)
              tell application "Adobe InDesign CS5.5"
                  if (count documents) > 0 then
                      my MoveGuidesToOneLayer()
                  else
                      display dialog "No documents are open."
                  end if
              end tell
              on MoveGuidesToOneLayer()
                      set myDoc to active document
                      set myLayerName to "Guides"
                      tell myDoc
                          try
                              set myLayer to layer myLayerName of myDoc
                          on error
                              set myLayer to make layer with properties {name:myLayerName}
                          end try
                          set the item layer of every guide to myLayer
                      end tell
                  end tell
              Kev
              • 4. Re: Move all guides to one layer in InDesign (AS)
                KS_Coastal Level 1
                Perfect, perfect, perfect. Thank you!
