0 Replies Latest reply on Jan 5, 2012 2:26 AM by Flex4_5
    problem with chart
    Flex4_5
      Hi ALL,
      i have a problem with a chart in flex 4.5 :
      when i excute my application  an error message apparead indicate :
      Error #1088: The markup in the document following the root element must be well-formed.
      after 2 hours i find the position off error but i can't retrieve any solution:
      so my problem is the level of data provider because i spend on chart as XMLList ,when i read data this error given above appeared
      a bit of code when this error is trigged:
      <mx:GridRow width="100%"
        height="2 8">
        <mx:GridItem paddingTop="1"
        height="100%"
        paddingLeft="10">
        <s:TextArea id="BoxAreaExc_7"
        contentBackgroundColor="{colors[7]}"
        text="8"
        width="18"
        height="18"
        styleName="textAreaStyle"
        editable="false"/>
        </mx:GridItem>
        <mx:GridItem paddingTop="2"
        width="100%"
        height="100%"
        paddingLeft="10">
        <s:Label id="labelExc_7_txt"
      text="{pieData[7].@level}"
        buttonMode="true"
        styleName="labelBold"/><!-- -->
        </mx:GridItem>
        <mx:GridItem width="100%"
        height="100%"
        horizontalAlign="right"
        paddingLeft="50">
        <mx:LinkButton buttonMode="{valueExc_7_btn.enabled}"
        id="valueExc_7_btn"
        click="excOutStandings(8,pieData[7].@excluded)"
        enabled="{(entityCombo.textLabel=='All'||valueExc_7_btn.label=='')?false:true}"
           label="{pieData[7].@excluded}"
        </mx:GridItem>
        height="100%"
        paddingLeft="50">
        <mx:LinkButton buttonMode="{valueInc_7_btn.enabled}"
        id="valueInc_7_btn"
        click="incMovement(pieData[7].@num)"
        enabled="{(entityCombo.textLabel=='All'||valueInc_7_btn.label=='')?false:true}"
            label="{pieData[7].@included}"
        </mx:GridItem>
        </mx:GridRow>
      the rows selected by the red is his problem that causes
