• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Borderless Printing Issues
Explorer ,
Jan 05, 2012 Jan 05, 2012
Don't know if this is the appropriate place to ask this, but I just can't work out how to get a borderless print from Illustrator CS5.5 and my Epson 2100 on Mac OS X 10.7.
I don't print a lot, but now I have a need to do so.  When I was using Windows, I didn't have this issue, but on OS X, I'm struggling.
This is what happens.
I have a A3 document with graphics that go edge to edge.  I select A3 (Sheet feeder - borderless) in the Media size box, and have tried selecting 'Do not Scale' and 'Fit to Page'. Both give the same results, i.e. borderless printing, but the document doesn't fit on the page - it is being cropped.
If I select A3 (Standard - minimise margins) in the Media size box, and either of the options mentioned before, then I get the whole document, but with a small margin all around the paper.
Can anyone shed any light on this?
Thanks.
Views
27.5K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Enthusiast ,
Do you have the right driver installed?
Votes
Translate
Translate
Report
Report
Explorer ,
Yes, Epson 8.61.
Votes
Translate
Translate
Report
Report
Community Expert ,
Use Photo Quicker which comes with the 2100, if not download here. The program supposedly  give you all the options you need including 6x4 borderless and four on an A4 borderless.
I have not used this, but that is what I have heard. My guess is you can't print .ai files through this app, but you should try a universal format like .pdf (which would also hold your vector quality as this inkjet printer probably does not have postscript liscence)
Votes
Translate
Translate
Report
Report
Community Expert ,
Actually I have a better solution for you,  you can print through Illustrator if you make a custom page size. There is a video on this page showing you hwo to do that.
http://blog.lexjet.com/2011/07/08/how-to-print-through-adobe-illustrator-and-the-epson-driver/
If your vector objects look bitmapped, then try making a .pdf and printing through acrobat.
Votes
Translate
Translate
Report
Report
Explorer ,
Mike, I appreciate the response, but I'm struggling to see how it helps me.
The printer driver (allegedly) gives me all the options I need, BUT, it doesn't do what it says it does, i.e. the full page, borderless.  I either get a cropped image printed borderless, or the full page printed with minimal borders.
Any further ideas?
Votes
Translate
Translate
Report
Report
Community Expert ,
There are many printers out there that says they are borderless, but all they do is print closer to the edge. I personally believe manufacturos should not be be able to claim borderless, unless they truly are.
Though you have a setting that says borderelss, I would try the 2 suggestions i gave you (the .ppd you have form Epson may not be optimized for Illustrator, as they really program that for the photo quicker. If you want to solve your problem you will have to invest the ink and 2 sheets of paper and find out if your printer can truly print to the edge. Also make sure your paper is inserted properly.
I would call Epson and get their response on the issue, would love to hear their response.
Votes
Translate
Translate
Report
Report
Explorer ,
Hi Mike.
I'll try what you suggest a bit later.
The printer does print to the edge OK as I said earlier, but the problem is that the image (document) is cropped, i.e. it doesn't all fit onto the page.
Votes
Translate
Translate
Report
Report
Community Expert ,
That is good news if you printed before to the edge before, as that means the hardware is capable of doing this, and we just need to find what is wrong on the software end. How did you print to the edge before, what software did you use?
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks again, Mike.
It's all in my first post. All done within Illustrator.
Votes
Translate
Translate
Report
Report
Explorer ,
I just tried printing the same doc as a pdf in Adobe Reader.  Same result.  Prints to the edge, but the image is cropped.
Votes
Translate
Translate
Report
Report
Explorer ,
Jan 06, 2012 Jan 06, 2012
No one got any ideas on this? It's driving me mad!
Votes
Translate
Translate
Report
Report
Community Beginner ,
Oct 04, 2023 Oct 04, 2023
20203 and I am having the SAME EXACT ISSUE!!!
Votes
Translate
Translate
Report
Report
Explorer ,
Jan 08, 2012 Jan 08, 2012
I'm not familiar with that printer or with small printers that produce borderless prints, but is it possible that you need to add some bleed to image? The printer would have to be extremely precise to print an image exactly to the edge of the paper without bleed.
How much of the image is cropped off? I'd think that if you don't have bleed in your image, the printer would have to enlarge the image by a few percent in order to print to the edge of the paper. So the image would be cropped slightly in the final print.
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks a lot for your suggestion.
I don't think that would help.  It worked perfectly well when I was using Windows, and also, it's not just Illustrator as I've discovered, it's all apps, and you wouldn't be able to add bleed in something like Adobe Reader, for example.
I'm beginning to think it's an issue with the driver.
Votes
Translate
Translate
Report
Report
Explorer ,
Jan 30, 2016 Jan 30, 2016
I know this is a very old thread, but so are all the threads I find online about this problem and even though years have past, I have the exact same problem, just on a different printer: The printer is physically capable of borderless printing and I have even done so with it, but when printing from Illustrator, Photoshop or Preview, images are scaled up (slightly, to generate bleed) but *still* cropped and finally printed with 3 mm white borders.
Brother says it's just the way things are, but then I discovered that some pdf's I received that are not generated by me, are in fact printed borderless without any problem..
Votes
Translate
Translate
Report
Report
Explorer ,
Feb 06, 2016 Feb 06, 2016
I use Preview instead of Illustrator to print because I don't use most options anyway. Finally, after many hours of investigating this problem, I found a workaround how to print borderless at 100%.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 09, 2024 Apr 09, 2024
I got the same issue.
Illustrator printer settings all setup to print boarderless, the preview shows boarderless, then I print and it comes out with a boarder.
Prints perfectly fine boardless in Photoshop.
Has been driving me insane for the past few hours.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 12, 2024 Apr 12, 2024
Can you tell me how to set up the Illustrator printer settings to print boarderless? I'd love to be able to make a defualt media size of such, but haven't found info on how to.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 13, 2024 Apr 13, 2024
LATEST
It won't work in illustrator, that's what we're  saying.
It only worked for me in Photoshop.
Votes
Translate
Translate
Report
Report
