0 Replies Latest reply on Jan 5, 2012 6:00 AM by Jonathan Braun
    cannot parse remote WSDL using Flash Builder WebServices Wizard
    Jonathan Braun
      Hello everybody,
      I need your help to understand how does Flash Builder proceeds when introspecting remote WSDL, looking for available WebServices on a remote host (here, the remote host is a Windows Server 2008 SP1 and we use 4D Server v12, which provides those webServices)
      My problem: I cannot parse remote WSDL when using Flash Builder WebServices Wizard.
      I am using french version of Flash Builder 4.5.1
      From here, i click on 'next >' , i can see a furtive progressBar. Then, no error occurs but no webService found... and the window stay unchanged (exactly as the snapshot)
      So, I tried to check the WSDL using my browser and typing this in the URL field: http://192.168.1.239/4dwsdl
      Here, i got the expected result:
      This XML file does not appear to have any style information associated with it. The document tree is shown below.
      This WSDL file was automatically generated by 4D_v12/12.2.0
      <definitions xmlns="http://schemas.xmlsoap.org/wsdl/" xmlns:http="http://schemas.xmlsoap.org/wsdl/http/" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/"xmlns:tns="http://www.4d.com/namespace/default" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" name="A_WebService" targetNamespace="http://www.4d.com/namespace/default">
      <types>
      <schema xmlns="http://www.w3.org/2001/XMLSchema" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" targetNamespace="http://www.4d.com/namespace/default">
      <complexType xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/" name="ArrayOfint">
      <complexContent>
      <restriction base="SOAP-ENC:Array">
      <attribute ref="SOAP-ENC:arrayType" wsdl:arrayType="xsd:int[]"/>
      </restriction>
      </complexContent>
      </complexType>
      <complexType xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/" name="ArrayOfstring">
      <complexContent>
      <attribute ref="SOAP-ENC:arrayType" wsdl:arrayType="xsd:string[]"/>
      </restriction>
      </complexContent>
      </complexType>
      <complexType xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/" name="ArrayOfboolean">
      <complexContent>
      <attribute ref="SOAP-ENC:arrayType" wsdl:arrayType="xsd:boolean[]"/>
      </restriction>
      </complexContent>
      </complexType>
      <complexType xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/" name="ArrayOfdate">
      <complexContent>
      <attribute ref="SOAP-ENC:arrayType" wsdl:arrayType="xsd:date[]"/>
      </restriction>
      </complexContent>
      </complexType>
      <complexType xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/" name="ArrayOffloat">
      <complexContent>
      <attribute ref="SOAP-ENC:arrayType" wsdl:arrayType="xsd:float[]"/>
      </restriction>
      </complexContent>
      </complexType>
      </schema>
      </types>
      <message name="WS_get_info_opRequest">
      <part name="numop" type="xsd:int"/>
      <part name="e_user_id" type="xsd:int"/>
      </message>
      <message name="WS_getSupportPagesRequest">
      <part name="e_support_id" type="xsd:int"/>
      <part name="e_numVersion" type="xsd:int"/>
      </message>
      <service name="A_WebService">
      <documentation/>
      <port name="A_WebServicePort" binding="tns:A_WebServiceBinding">
      <soap:address location="http://192.168.1.239/4DSOAP/"/>
      </port>
      </service>
      </definitions>
      So, I spent two days looking all Flash builder and project settings to find any issue to my problem, and still blocked in my developments by i don't know what
      What did i missed? any feature that must be enabled in Flash Builder.
      This worked correctly the last week ^^
      Thank you for your attention and your support
