1. Re: Will CS5 handle the files from a Atomos Ninja
Kevin Monahan Jan 5, 2012 12:35 PM (in response to Darren Hall)For Premiere Pro CS5? No. You need Premiere Pro CS5.5 (5.5.1), which fixed all the bugs related to the Atomos Ninja. More info here: http://blogs.adobe.com/premiereprotraining/2011/09/adobe-premiere-pro-cs5-5-update-bug-fix es-mac-osx-v10-7-lion.html
2. Re: Will CS5 handle the files from a Atomos Ninja
Darren Hall Jan 5, 2012 12:47 PM (in response to Kevin Monahan)Hi Kevin,
thanks for your imput. I am on 5.5.1 PC he is on 5 so I will tell him to give it a miss.
Darren
3. Re: Will CS5 handle the files from a Atomos Ninja
Kevin Monahan Jan 5, 2012 12:51 PM (in response to Darren Hall)Cool. Best of luck on the project!
4. Re: Will CS5 handle the files from a Atomos Ninja
SAFEHARBOR11 Jan 5, 2012 1:09 PM (in response to Kevin Monahan)Hi Darren,
I was actually using Premiere CS5 on the PC with the Ninja and the files worked fine. The "bug" was that if you recorded 4-channel audio in Ninja, Premiere would report "Unsupported Format", but if using 2-channel sound then the clips worked fine. This is all fixed in CS5.5 as Kevin pointed out.
Jeff Pulera
Safe Harbor Computers
5. Re: Will CS5 handle the files from a Atomos Ninja
Kevin Monahan Jan 5, 2012 1:28 PM (in response to SAFEHARBOR11)Thanks for the clarification Jeff. You are right about that. You can change the Ninja to record two channels, which would create files that Premiere Pro CS5 could import.
6. Re: Will CS5 handle the files from a Atomos Ninja
Darren Hall Jan 5, 2012 8:20 PM (in response to SAFEHARBOR11)Thanks Jeff nice to see you on this site.
Darren
