5 Replies Latest reply on Jan 6, 2012 7:04 AM by Captiv8r
    Index doesn't work if PDF file resides in RoboHelp Project
    DXD_Princess Level 1
      If I create a RH8 project and publish, the index works as it should.  Each keystroke will change where you are in the Index. If I put a .PDF file in the project, the Index doesn't work -- it no longer recognizes keystrokes and you can only scroll through it.
      Does RoboHelp not support PDF files within the project?
