3 Replies Latest reply on Oct 9, 2012 8:15 AM by starrcourt
    Normal 'Inner Shadow' under Photoshop live effects
    Sheikh Naveed
      Hi!
      I want to give what inner shadow using 'photoshop live effects' in fireworks CS5. White does not appear because 'inner shadow' has blending mode as Multiply by default. The main question here 'How to change blending modes under 'photoshop live effects in fireworks.
      Please reply
      Regards
      Sheikh Naveed
        • 1. Re: Normal 'Inner Shadow' under Photoshop live effects
          Linus Lim
          Hi Sheikh,
          if the design is originally created in Fireworks, you can use the Fireworks LIVE Filter > Inner Shadow.
          Add a new vector object above your image, apply "Inner Shadow" and play with blending modes.
          If you prefer Photoshop Inner Shadow, you have to modify it in Photoshop instead. Thats the only way.
          Fireworks does not allow change of Blending Mode for Photoshop Filters.
          Linus
          twitter.com/chunwui
          • 2. Re: Normal 'Inner Shadow' under Photoshop live effects
            exsabuta
            Hi Linus.
            Why?
            • 3. Re: Normal 'Inner Shadow' under Photoshop live effects
              starrcourt
              I'm assuming you're trying to make something like a button. If so please see below for a way to achieve a similar effect.
              Step 1: Apply a stroke using fireworks default stroke feature. Align stroke to inside.
              Step 2: Using fireworks live filters apply your first inner shadow as say a 35% opacity 0 pixel shadow shifted down 2 pixels set at 270º.
              Step 3: Using fireworks live filters apply your second inner shadow as say a 100% opactiy 0 pixel shadow shifted down 1 pixel set a 270º. This shadow should be the same color as the stroke you created earlier.
              This should yield the same effect as photoshop live effects. See the attached picture for side-by-side comparison. Left is using all fireworks live filters (except for the shadow) and right was an imported button that has all photoshop live effects.
              Note* You can move fireworks filters up and down in terms of hierarchy just like layers. This is important to know incase you ever create your inner shadows out of order.
              Hope this helps!
