0 Replies Latest reply on Jan 6, 2012 9:00 PM by TommyReady
    Issues with Flash Builder 4.6 and RDS from CF Server
    TommyReady
      For starters I can't for the life of me figure out how to connect my Flash Builder 4.6 with my CF server that is NOT local but hosted elsewhere and I have RDS setup and works perfect.  I only see in Flash Builder where to set a local CF server.  Anyway, to get around that problem I use
      <s:RemoteObject id="myService" endpoint="http://dev.myURL.com/flex2gateway/" destination="ColdFusion" source="data">
              <s:method name="fetchData" result="handleResults(event)" />
      </s:RemoteObject>
      This code above lets me connect with no problem and I used trace(event) to see the results of my cfc method in the console.
      Anyway, the problem I am having now is that I want to take the results of my cfc method into a datagrid.  Here is the code below I am using.
      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                                           xmlns:mx="library://ns.adobe.com/flex/mx">
                <fx:Script>
                          <![CDATA[
                                    import mx.rpc.events.ResultEvent;
                                    protected function button1_clickHandler(event:MouseEvent):void
                                              myService.fetchData();
                                    protected function handleResults(event:ResultEvent):void
                                              trace(event.result);
                </fx:Script>
                <fx:Declarations>
                          <!-- Place non-visual elements (e.g., services, value objects) here -->
                          </s:RemoteObject>
                </fx:Declarations>
                <s:Button id="test" x="56" y="42" label="Test" click="button1_clickHandler(event)"/>
                <s:DataGrid id="adminList" x="56" y="175" width="766" requestedRowCount="4">
                          <s:columns>
                                    <s:ArrayList>
                                              <s:GridColumn headerText="Admin ID" dataField="admin_id"></s:GridColumn>
                                              <s:GridColumn headerText="Last Name" dataField="last_name"></s:GridColumn>
                                              <s:GridColumn headerText="First Name" dataField="first_name"></s:GridColumn>
                                              <s:GridColumn headerText="Department" dataField="department_name"></s:GridColumn>
                                              <s:GridColumn headerText="Status" dataField="active"></s:GridColumn>
                                    </s:ArrayList>
                          </s:columns>
                </s:DataGrid>
      </s:WindowedApplication>
      What am I doing wrong?  Can anyone help?  Thanks!!!
