1 Reply Latest reply on Jan 8, 2012 4:41 AM by Ned Murphy
    Text doesn't show up after exporting
    illduce
      When I export my file, the text that I put in the file with the text tool doesn't show up. Everything else is fine though. Someone please halp!
        • 1. Re: Text doesn't show up after exporting
          If you are using dynamic textfields then it is likely you need to embed the fonts/characters for them.  This is most likely the case if you happen to be masking, animating, or otherwise manipulating them.  To embed the fonts/characters you select the textfield on the stage and in the Properties panel you click the button labeled "Embed..." and then select the character sets you need to embed.
          Another cause could be that the textfields are assigned the same font voor as the background such that they do not seem to appear, but if you see the text before you publish the file then this is less likrly to be tyhe case.
