2 Replies Latest reply on Jan 9, 2012 9:02 PM by Pramod_Kutty
    Issue with list control
    Pramod_Kutty
      TypeError: Error #1010: A term is undefined and has no properties.
                at mx.controls.listClasses::TileBase/scrollVertically()[C:\autobuild\3.2.0\frameworks\projec ts\framework\src\mx\controls\listClasses\TileBase.as:849]
                at mx.controls.listClasses::TileBase/scrollHandler()[C:\autobuild\3.2.0\frameworks\projects\ framework\src\mx\controls\listClasses\TileBase.as:2603]
                at flash.events::EventDispatcher/dispatchEventFunction()
                at flash.events::EventDispatcher/dispatchEvent()
                at mx.core::UIComponent/dispatchEvent()[C:\autobuild\3.2.0\frameworks\projects\framework\src \mx\core\UIComponent.as:9298]
                at mx.controls.scrollClasses::ScrollBar/http://www.adobe.com/2006/flex/mx/internal::dispatchScrollEvent()[C:\autobuild\3.2.0\frameworks\projects\framework\src\mx\controls\scrollClasses\ScrollBa r.as:1261]
                at mx.controls.scrollClasses::ScrollBar/http://www.adobe.com/2006/flex/mx/internal::lineScroll()[C:\autobuild\3.2.0\frameworks\projects\framework\src\mx\controls\scrollClasses\ScrollBa r.as:1223]
                at mx.controls.scrollClasses::ScrollBar/downArrow_buttonDownHandler()[C:\autobuild\3.2.0\fra meworks\projects\framework\src\mx\controls\scrollClasses\ScrollBar.as:1325]
                at mx.controls::Button/http://www.adobe.com/2006/flex/mx/internal::buttonPressed()[C:\autobuild\3.2.0\frameworks\projects\framework\src\mx\controls\Button.as:2504]
                at mx.controls::Button/mouseDownHandler()[C:\autobuild\3.2.0\frameworks\projects\framework\s rc\mx\controls\Button.as:2750]
      I am having an issue with the custom itemrenderer for a Tile List I am using flex sdk 3.2 Is this an issue with flex 3 should I migrate to flex 4
        • 1. Re: Issue with list control
          Flex harUI Adobe Employee
          I don’t have 3.2.  What code is on that line?  What is null?
          • 2. Re: Issue with list control
            Pramod_Kutty Level 1
            My SongsDisplayComponent uses ir itemrenderer
            SongsDisplay.mxml
            <mx:VBox xmlns:mx="http://www.adobe.com/2006/mxml" width="100%" height="100%"
                      borderColor="black" borderStyle="solid">
            <mx:Script>
            <![CDATA[
                      import mx.collections.ArrayCollection;
                      import mx.binding.utils.BindingUtils;
                      import mx.events.ResizeEvent;
            import mx.controls.Alert;
            public function test(event:Event):void
                      //myList.executeBindings(true);
            public function init(event:Event):void
                      //myList.addEventListener(ResizeEvent.RESIZE,test);
                      [Bindable]
            private var arr:ArrayCollection=new ArrayCollection([{thumbnailImage:"test.GIF"},{thumbnailImage:"test.GIF"},{thumbnailImage: "test.GIF"},{thumbnailImage:"test.GIF"},{thumbnailImage:"test.GIF"}])
            </mx:Script>
                                <mx:XML id="catalog" source="catalog.xml"/>
                                 <mx:Array id="arr1">
                    <mx:Object  thumbnailImage="test.GIF" />
                          </mx:Array>
                      <mx:HBox height="100%" width="100%" borderThickness="5" borderColor="RED" borderStyle="solid">
                      <mx:VBox id="vb" height="100%" width="50%" borderColor="GREEN" borderStyle="solid" borderThickness="10">
                                 <mx:List id="myList"
                                    rowCount="2"
                                    columnCount="1"
                                    height="200"
                                    width="200"
                                    dataProvider="{arr}"
                                    itemRenderer="ir"
                                    borderColor="#00BAFF"
                                     borderStyle="solid"
                                      borderThickness="5"
                      </mx:VBox>
                         </mx:HBox>
            </mx:VBox>
            ir.mxml
            <mx:HBox name="ir"
                    horizontalAlign="center"
                    verticalAlign="middle" width="100%" height="110" dataChange="test()">
                    <mx:Script>
                     private function test()
                               Alert.show("scroling");
                    </mx:Script>
                <mx:Image source="{data.thumbnailImage}"/>
            </mx:HBox>
