2 Replies Latest reply on May 28, 2008 9:24 PM by RoboWizard
    ppt slides in robohelp
      Is there a way to add ppt slides into robohelp. btw i have a document which is done is 11* 17 page setting in ppt. How would i import it in robohelp topics
        • 1. Re: ppt slides in robohelp
          RoboColum(n) Level 5
          Do you want to import the content of the PPT file into RH in order to create topic content or just launch the PPT file from inside a topic. If the former (which sounds more likely) you'd have to create ouptut from your PPT file that could be imported into RH. PDF or HTM files would seem to be the obvious answer.
          • 2. Re: ppt slides in robohelp
            RoboWizard Level 4
            Hi rr336
            One possibility would be to use the Adobe Captivate application to import the PowerPoint. You would then Publish a .SWF you could drop into RoboHelp.
            If you don't wish to use Captivate, there are other converters available that will convert PowerPoint to .SWF. Just Google a bit to find a few.
            Cheers... Rick
