1 Reply Latest reply on Jan 8, 2012 7:20 PM by Kevin B Walsh
    Saving to HTML per Chapter in Book
    Kevin B Walsh
      Hello,
      I have thre questions, but they are related.
      1. How does one save per-chapter PDFs?
      2. How does one save to HTML?
      3. How does one save per-chapter HTML?
      For some things, I have found example code.
      I have found examples showing how to open all the files in a book.
      var openedBook = app.ActiveBook
      function openBookFiles(openedBook)
          var bookChapter=openedBook.FirstComponentInBook
          var chapterId = bookChapter.id
          while(chapterId)
              var chapterName = bookChapter.Name
              chapterId = openFile(chapterName)
              bookChapter = bookChapter.NextComponentInBook
              chapterId = bookChapter.id;
      That part works fine.
      I found an example for saving the whole book to PDF:
      function savePdf(openedBook,pdfName)
          var params = GetSaveDefaultParams()
          var returnParamsp =new PropVals()
          var ft = GetPropIndex(params, Constants.FS_FileType)
          params[ft].propVal.ival =Constants.FV_SaveFmtPdf
          openedBook.Save(pdfName, params, returnParamsp);
          return
      That works fine too.
      I tried to modify the above to save to a single HTML file.
      function saveHTM(openedBook,htmName)
          params[ft].propVal.ival =Constants.FV_SaveFmtFilter
          var fth= GetPropIndex(params, Constants.FS_SaveFileTypeHint )
          params[fth].propVal.ival ="0001ADBEHTML"
          openedBook.Save(htmName, params, returnParamsp)
          return
      The above does not work at all.
      I would like to make the above work.
      I would also like to save per-chapter PDFs and per-chapter HTML files.
      However, I have not been able to figure out how to save per-chapter anything.
        • 1. Re: Saving to HTML per Chapter in Book
          Kevin B Walsh Level 1
          Hello,
          I figured out how to get a per-chapter object to save and print to PDF files.
          I needed to use app.ActiveDoc after I opened a file.
              while(chapterId)
                  openedChapter= app.ActiveDoc
                  params[ft ].propVal.ival =Constants.FV_SaveFmtPdf
                  openedChapter.Save(openedChapter.Name + ".pdf", params, returnParamsp);
          Are there problems with this?
          I still cannot save to HTML.
