2 Replies Latest reply on Jan 8, 2012 10:23 PM by linn0102
    The instance can't be released.
    linn0102
      Precondition:
        1.Adobe Flash Player Version:11.1.102.56
        2.Module SubFrame.mxml has a chart and a monitor of his parent container-myFlex.mxml.
      Phenomenon:
        When I load SubFrame.swf more than once,the instance of SubFrame can't be released. But if I remove the chart or the monitor,the instance of SubFrame can be released.
      Problem:
        Can you tell me why both of the chart and the monitor exist,the instance can't be released ? How to solve this problem?
      Remarks:
        In Adobe Flash Player Version 10.0.45.2,this problem isn't exist.
      Code is as follows
          myFlex.mxml
          `<?xml version="1.0" encoding="utf-8"?>
          xmlns:mx="library://ns.adobe.com/flex/mx"
          creationComplete="initApp()">
          <fx:Script>
             <![CDATA[
          import mx.core.FlexGlobals;
          import mx.core.IVisualElementContainer;
          import mx.core.IVisualElement;
          import mx.events.ModuleEvent;
          import mx.modules.IModuleInfo;
          import mx.modules.ModuleManager;
          private static var moduleInfo:IModuleInfo;
          private function initApp():void{
          TestModel.topContainer=topH;
          private function loadSubFrame():void{
          if (moduleInfo != null){
          moduleInfo.unload();
          moduleInfo.release();
          moduleInfo=ModuleManager.getModule("SubFrame.swf");
          moduleInfo.addEventListener(ModuleEvent.READY, onModuleReady, false, 0, true);
          moduleInfo.load();
          public function onModuleReady(evt:ModuleEvent):void{
          mainH.removeAllElements();
          mainH.addElement(moduleInfo.factory.create() as IVisualElement);
          </fx:Script>
          <s:HGroup id="topH">
          </s:HGroup>
          <s:HGroup>
          <s:Button label="load line" click="loadSubFrame()"/>
          <s:HGroup id="mainH" width="100%" height="100%"/>
          </s:HGroup>
          </s:Application>
          SubFrame.mxml
          <mx:Module xmlns:fx="http://ns.adobe.com/mxml/2009"
             creationComplete="init()">
          <fx:Script>
          <![CDATA[
          public function init():void {
             TestModel.topContainer.addEventListener("change", changeHandler, true, 0, true);
          public function changeHandler(e:Event):void {
          </fx:Script>
          <mx:LineChart/>
          </mx:Module>
          TestModel.as
          package
          import spark.components.HGroup;
          public class TestModel
          static public var topContainer:HGroup;
          static public var mainContainer:IVisualElementContainer;
