4 Replies Latest reply on May 30, 2008 4:11 AM by Madhav Subedi
    passing argument to function
    Madhav Subedi Level 4
      obj.addEventListener(MouseEvent.MOUSE_OVER, myFunction);
      this is a line inside a loop.
      now my problem is that i need to pass an object as the argument to myFunction.
      please somebody help me.
        • 1. Re: passing argument to function
          laurent_pinson Level 1
          you can't, you will need to retrieve this object directly in myFunction (using switch, array, if...)
          • 2. Re: passing argument to function
            ohh god!!!!!!!!!!
            dont we have ANNNNNNNNNNNYYYYYYYYYY other easy option???????
            the object i want to pass as argument is created inside a loop..
            • 3. Re: passing argument to function
              slaingod Level 1
              You will be passed an argument: The moused over control will be you event.currentTarget. You can set whatever you want to the my_control.data, like an object { something: 'else', goes: 'here'}
              You could also use an anonymous function possibly:
              obj.addEventListener(MouseEvent.MOUSE_OVER, function(event:MouseEvent):void {
              // something custom here
              (not sure if that helps or not)
              • 4. Re: passing argument to function
                using this code, i can pass arguments to desired function,<calling my function in
                something custom here>.
                but, in my case, the argument is an object that is created inside a loop.
                so the affected object is always the last created object.
                anyway, thanks slaingold for your idea.
