1. Re: FLV Player Disappears When Site is Published
Rob Dillon Jan 9, 2012 6:15 PM (in response to PeteGould)You probably need to put a copy of the FLVPlayback component in your movie's Library. Go to the Windows menu, Select the Components window. When that opens, select the FLVPlayback component and drag a copy to your movie's Library.
2. Re: FLV Player Disappears When Site is Published
PeteGould Jan 9, 2012 7:47 PM (in response to Rob Dillon)Hi Rob,
Well, I verified that the FLVPlayback component was NOT already in the movie's library, so I added it as you described. Unfortunately that didn't make a difference. Just to make sure, I removed the playback component that I had already placed on the page and dragged the newly-added FLVPlayback component from the window to the page and reconnected it to the media. It plays fine as a publishing preview, as it did before, but not once published.
Here's a STUPID question but I wonder if I'm chasing my tail. Once published, will it play off the local drive, or does it have to be uploaded to a web server? I'm trying to play it off the local drive.
Pete
3. Re: FLV Player Disappears When Site is Published
Rob Dillon Jan 10, 2012 5:18 AM (in response to PeteGould)Yes, you will need to upload the needed files to the server. If you are using an external .flv file, then be sure to upload that file to the server also.
