1 Reply Latest reply on Jan 9, 2012 10:21 AM by Ned Murphy
    Remove dynamic textbox on loading an image
    sudarshan.t Level 6
      I'm trying to remove a line of text placed in a dynamic textbox inside a MC after an image loads in the imageloader component.
      I've highlighted the line in RED in the code below.
      Maybe a timer for this text to disappear or a statuschange function would be helpful. I've been searching extensively but in vain. Any heads-up please?!
      Any help would be much appreciated.
      Thanks.
      Sudarshan
      // Import the MX.UTILS so it can be used to set the scope of the listBox listener and the xml onload feature
      import mx.utils.Delegate;
      // Define default URL to load if no URL is defined in XML attribute
      _root.urlLink = "http://www.somesite.com";
      // declare variables
      var people:Array;
      var product:Array;
      var update:String;
      var dirpath:String;
      // set up the XML instance
      var peoplexml:XML = new XML();
      // initialize items on stage
      _global.style.setStyle("fontFamily","Verdana");
      _global.style.setStyle("fontSize",11);
      // define what should happen when the XML loads
      // (read data into update, dirpath, and brand variables)
      function onXmlLoaded(success:Boolean)
          if (success)
              // make a handle to the root node in the xml
              var mainnode:XMLNode = peoplexml.firstChild;
              update = mainnode.attributes.lastupdate;
              dirpath = mainnode.attributes.dir;
              // set up an array of all brand nodes
              var peoplenodes:Array = peoplexml.firstChild.childNodes;
              for (var i:Number = 0; i < peoplenodes.length; i++)
                  // for each brand node:
                  var personnode:XMLNode = peoplenodes[i];
                  people.push({i:i + 1, pname:personnode.attributes.name});
              // data is all read and put in the right place -- now setup the screen
              // using this data
              setup();
          else
              trace('error reading XML');
      function setup()
          // set up chooseperson dropdown
          choosebrand.labelField = "pname";
          choosebrand.dataProvider = people;
          choosebrand.addEventListener("change",Delegate.create(this, loadProducts));
      function loadProducts(evt:Array)
          var thisitem:Array = evt.target.selectedItem;
          var productList:Array;
          chooseproduct.labelField = "prname";
          product = [prname];
              if (personnode.attributes.name == thisitem.pname)
                  var productnodes:Array = personnode.childNodes;
                  for (var j:Number = 0; j < productnodes.length; j++)
                      // for each product node:
                      var productnode:XMLNode = productnodes[j];
                      product.push({i:j + 1, prname:productnode.attributes.title, img:productnode.attributes.photo, url:productnode.attributes.url, txt:productnode.attributes.txt, det:productnode.attributes.det, price:productnode.attributes.price, clck:productnode.attributes.clck});
                  loader.img.contentPath = "";
                  loader.clck.text = "";
                  loader.ldng.text = "";
                  productTitle.ptitle.text = "";
                  productTitle.pdet.text = "";
                  productTitle.prc.text = "";
          //initialize the product array
          chooseproduct.dataProvider = product;
          chooseproduct.addEventListener("change",Delegate.create(this, loadImage));
      function loadImage(evt:Array)
          productTitle.ptitle.text = thisitem.txt;
          productTitle.pdet.text = thisitem.det;
          productTitle.prc.text = 'Rs.'+ thisitem.price;
          loader.img.contentPath = thisitem.img;
          loader.clck.text = thisitem.clck;
          loader.ldng.text = 'Loading Image...';
          _root.urlLink = thisitem.url;
      function init()
          // initialize the brand array
          people = [pname];
          // set up the xml instance to ignore whitespace between tags
          peoplexml.ignoreWhite = true;
          // set the scope of the onLoad function to the main timeline, not peoplexml
          peoplexml.onLoad = Delegate.create(this, onXmlLoaded);
          // start the xml loading
          peoplexml.load("bannerxml.php");
      init();
