1 Reply Latest reply on Jan 9, 2012 3:20 PM by Dave LaRonde
    audio inside a nested comp
    lmaclanphere Level 1
      hi all
      curious if there's a way to access an audio track in the main comp, for syncing things up while working inside a precomp
      I'm familiar with "edit this, look at that"--is that the way to go about it?  or, copy/pasting the audio into each precomp when necessary?
      thanks
      LML
        • 1. Re: audio inside a nested comp
          Dave LaRonde Level 7
          I think it's just as easy to add the audio layer into the nested comp.  You can always turn the audio off later, or just delete the layer.
          The trick: making sure the audio's in point is at the same point in time as it is in the main comp.  If it begins at 00:00:00:00 in both, it's moot.
