0 Replies Latest reply on Jan 10, 2012 3:25 AM by karthikb1987
    Indesign Server CS5 Multiple instance - Urgent, Please help!
    karthikb1987 Level 1
      I am using a windows service to access the indesign server. The instance is created like below.
              Dim oType As Type = Type.GetTypeFromProgID("InDesignServer.Application")
              If oType IsNot Nothing Then
                       Return Activator.CreateInstance(oType)
              End If
      If already an instance is created by some other application, then my service is not able to create an instance. I get the following error from the COM
      "Retrieving the COM class factory for component with CLSID {96D10A00-63E3-423E-A223-DFC4BEA21206} failed due to the following error: 80080005."
      In some article i read that instance can be created by different port numbers and different configuration.
      Is there anyway in VB.net to create an instance like that and will it solve the multiple instance problem ?
      Regards,
      Karthik B
