7 Replies Latest reply on Jan 10, 2012 2:37 PM by RathanakDiep
    After Effects CS5 causing Mac to crash during render
    RathanakDiep
      I am currently experiencing problems with my Mac Pro crashing while I am trying to output a final render.  Here are the current specs for my compositions and computer:
      Composition:
      -5,760 pixels wide x 2,160 pixels high (The video is going to be used for a Video Wall)
      -29.97 fps
      -44 seconds long
      -3D composition with layers moving in 3D space
      Computer:
      -MacPro 2.93 Ghz 12-core
      -64 GB RAM
      -NVIDIA Quadro 4000
      -OSX 10.7.2 Lion
      Multiprocessing Settings:
      -RAM reserved for other applications 32 GB
      -RAM available for AE 32 GB
      -CPUs reserved for other applications 12
      -RAM allocation per background 2 GB
      -Installed CPUs 24
      -Actual CPUs that will be used 12
      I've tried prerendering layers.  I've even tried swapping video cards but it still crashes about every other time.  If you have any insight or need additional info, please respond.  Thanks.
      Jimmy Diep
        • 1. Re: After Effects CS5 causing Mac to crash during render
          bogiesan Level 4
          The crashlog is available from an app called Console, look for the menu item Show Log List.
          You should be able to see a possible explanation even though crash logs are practically illegible.
          The video card is not really part of the equation for After Effects unles sit is faulty.
          Give us a few hours, maybe a day or two, for rick and Myl to make some reasonable suggestions.
          • 2. Re: After Effects CS5 causing Mac to crash during render
            Dave LaRonde Level 6
            There are very few, if indeed there are any, devices that can play back a single file of those huge dimensions.  Almost always, such multiscreen animations are played on synchronized multiple devices.
            I VERY STRONGLY suggest you double-check with the client on the delivery specifications.  I also suggest a visit to the Creative COW's Live & Stage Events forum.  There's a gent by the name of Walter Soyka who frequently contributes there, and he really knows his stuff about multiscreen.
            But to answer your AE question,  you may not have your memory allocation straight.  Try allocating 4GB/processor in AE, and using fewer of them.  And as always, don't render using Open GL acceleration.  Forget that it exists for rendering.
            Oh, and make sure you're fully updated with AE.  I think your version should be at least AE 10.0.2.  It may even be a higher number than that by now.
            • 3. Re: After Effects CS5 causing Mac to crash during render
              RathanakDiep Level 1
              Thanks guys for the quick response.
              Dave - The animation will play across synchronized devices, like you thought, but even if we output parts of the composition that are at 1920x1080, the computer will still occasionally crash on me.
              I will try the setting that you suggested to see if it helps out any and report back.  Thanks.
              • 4. Re: After Effects CS5 causing Mac to crash during render
                bogiesan Level 4
                This eliminates the processing of the material as the cause. It's the material, not the computer or the app, that is casuing the crash.
                Using yoru crashlogs, you can narrow your binary testing down to a few interations but it's a simple matter of turning off half the layers and initiating the render. Fail? Turn off the remaining layers. Success? Test the other half.
                You will quickly narrow your crashing down to one or more possible art or video resources such as a corrupt PS file, something in CMYK that has values that cannot be comverted easily to RGB, a video file that shoudl be decompressed first.
                • 5. Re: After Effects CS5 causing Mac to crash during render
                  1/10/12 10:34:10.710 AM [0x0-0x35035].com.adobe.aerendercore: Jan 10 10:34:10 dhcp-171-68-113-242.cisco.com aeselflink[300] <Error>: ATSFontGetPostScriptName failed: error -984.
                  Here is one of the errors that I came across in the crash log.  This error comes up several times.
                  • 6. Re: After Effects CS5 causing Mac to crash during render
                    This error would lead me to believe that a text layer is using a bad typeface.
                    • 7. Re: After Effects CS5 causing Mac to crash during render
                      Here is what I found in the crash reporter.  Not sure if this is what I am supposed to be looking at but thought you might have some insight:
                      Process:     aeselflink [265]
                      Path:        /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/aeselflink.app/Contents/MacOS/aeselflink
                      Identifier:  com.adobe.aerendercore
                      Version:     10.0.2 (10.0)
                      Code Type:   X86-64 (Native)
                      Parent Process:  launchd [148]
                      Date/Time:   2012-01-06 13:41:41.094 -0800
                      OS Version:  Mac OS X 10.7.2 (11C74)
                      Report Version:  9
                      Interval Since Last Report:      33057 sec
                      Crashes Since Last Report:       1
                      Per-App Interval Since Last Report:  18798 sec
                      Per-App Crashes Since Last Report:   1
                      Anonymous UUID:                  FCFA397F-A0A2-4AC5-8B18-51D68DE29B1B
                      Crashed Thread:  76  Dispatch queue: com.apple.root.default-priority
                      Exception Type:  EXC_CRASH (SIGABRT)
                      Exception Codes: 0x0000000000000000, 0x0000000000000000
                      Application Specific Information:
                      abort() called
                      pure virtual method called
                      objc[265]: garbage collection is OFF
                      Thread 0:: Dispatch queue: com.apple.main-thread
                      0   ???                       0x000000011fdb525c 0 + 4829434460
                      1   com.adobe.MediaCore.ImporterQuickTime0x000000011b58cbac PrImportModule<ImporterQuickTime>::ImportEntry(ASL::ResourceCollection const&, int, imStdParms*, void*, void*) + 1100
                      2   com.adobe.MediaCore.ImporterQuickTime0x000000011b58c161 xImportEntry + 81
                      3   com.adobe.MediaCore.Frameworks.ImporterHost0x0000000106ce6591 ML::LocalImporterModule::CallImportModule(int, void*, void*) + 193
                      4   com.adobe.MediaCore.Frameworks.ImporterHost0x0000000106ce7453 ML::LocalImporterModule::~LocalImporterModule() + 67
                      5   com.adobe.MediaCore.Frameworks.ImporterHost0x0000000106cea05f ML::LocalImporterModule::Release() + 47
                      6   com.adobe.MediaCore.Frameworks.ImporterHost0x0000000106ccc7ce ML::ImporterFactory::~ImporterFactory() + 94
                      7   com.adobe.MediaCore.Frameworks.ImporterHost0x0000000106cd383d ML::ImporterFactory::Release() + 189
                      8   com.adobe.MediaCore.Frameworks.PluginSupport0x000000010709b737 std::_Rb_tree<dvacore::utility::Guid, std::pair<dvacore::utility::Guid const, ASL::InterfaceRef<ML::IPluginModuleFactory, ML::IPluginModuleFactory> >, std::_Select1st<std::pair<dvacore::utility::Guid const, ASL::InterfaceRef<ML::IPluginModuleFactory, ML::IPluginModuleFactory> > >, std::less<dvacore::utility::Guid>, std::allocator<std::pair<dvacore::utility::Guid const, ASL::InterfaceRef<ML::IPluginModuleFactory, ML::IPluginModuleFactory> > > >::_M_erase(std::_Rb_tree_node<std::pair<dvacore::utility::Guid const, ASL::InterfaceRef<ML::IPluginModuleFactory, ML::IPluginModuleFactory> > >*) + 71
                      9   com.adobe.MediaCore.Frameworks.PluginSupport0x000000010709b723 std::_Rb_tree<dvacore::utility::Guid, std::pair<dvacore::utility::Guid const, ASL::InterfaceRef<ML::IPluginModuleFactory, ML::IPluginModuleFactory> >, std::_Select1st<std::pair<dvacore::utility::Guid const, ASL::InterfaceRef<ML::IPluginModuleFactory, ML::IPluginModuleFactory> > >, std::less<dvacore::utility::Guid>, std::allocator<std::pair<dvacore::utility::Guid const, ASL::InterfaceRef<ML::IPluginModuleFactory, ML::IPluginModuleFactory> > > >::_M_erase(std::_Rb_tree_node<std::pair<dvacore::utility::Guid const, ASL::InterfaceRef<ML::IPluginModuleFactory, ML::IPluginModuleFactory> > >*) + 51
                      10  com.adobe.MediaCore.Frameworks.PluginSupport0x000000010709b287 __tcf_1 + 23
                      11  libsystem_c.dylib         0x00007fff89cd47c8 __cxa_finalize + 274
                      12  libsystem_c.dylib         0x00007fff89cd4652 exit + 18
                      13  com.adobe.AfterEffectsLib.framework0x000000010068f7d7 GetMetaPanelSuite + 7959
                      14  U.dylib                   0x0000000102a87846 U_LoadFrameworkBundle + 662
                      15  libsystem_c.dylib         0x00007fff89d35cfa _sigtramp + 26
                      16  com.adobe.psl             0x000000010a28507a 0x109f34000 + 3477626
                      17  com.adobe.psl             0x000000010a14b178 0x109f34000 + 2191736
                      18  com.adobe.psl             0x000000010a1557b7 0x109f34000 + 2234295
                      19  com.adobe.psl             0x000000010a37f36d PSLSetImageLocation + 1033
                      20  com.adobe.psl             0x000000010a382b4e PSLGetImageAlphaChannelCount + 138
                      21  com.adobe.psl             0x000000010a386ee9 PSLGetImageLayerByID + 227
                      22  com.adobe.psl             0x000000010a3870e7 PSLGetImageLayer + 29
                      23  BEE.dylib                 0x000000010144cec3 BEE_ConvertScrapFromPublic(dvaui::datatransfer::OS_ReceiveDataBase*, std::basic_string<unsigned short, std::char_traits<unsigned short>, std::allocator<unsigned short> >, BEE_Scrap**) + 12739
                      24  BEE.dylib                 0x000000010128b097 void CopyWorldToLayer0<PF_Pixel16>(AdobePSL::Image, M_LRect const&, PF_WorldX<PF_Pixel16> const*) + 55
                      25  BEE.dylib                 0x000000010128c244 void BEE_LayerStyleNode::RenderWorldUsingStyle<PF_Pixel16>(int, int, PF_WorldX<PF_Pixel16> const*, M_LRect const&, boost::shared_ptr<CImageStyler>, M_LRect const&, PF_WorldX<PF_Pixel16>*) const + 196
                      26  BEE.dylib                 0x000000010128200a BEE_LayerStyleNode::DoRender(RG_RenderRequest const&, RG_CheckoutResult*, M_LRect const&, PF_MaskWorld*, PF_CompositeModePlus const&, RG_CheckoutResult*) const + 506
                      27  RG.dylib                  0x00000001020f11e9 RG_CompositeNodeBase::Render(RG_NodeRenderCB*, RG_RenderRequest const&, RG_NodeData const*) const + 313
                      28  RG.dylib                  0x00000001020f9499 RG_CheckoutResult::SkipRendering() + 1225
                      29  RG.dylib                  0x00000001020f95f2 RG_CheckoutResult::SkipRendering() + 1570
                      30  RG.dylib                  0x00000001020f9765 RG_CheckoutResult::GetOutputWorld() + 85
                      31  RG.dylib                  0x00000001020f121e RG_CompositeNodeBase::Render(RG_NodeRenderCB*, RG_RenderRequest const&, RG_NodeData const*) const + 366
                      32  RG.dylib                  0x00000001020f9499 RG_CheckoutResult::SkipRendering() + 1225
                      33  RG.dylib                  0x00000001020fa341 RG_Traverser::Execute(RG_RenderRequest const&, M_LRect*, char*, PF_World**, RG_BufferLock**) + 449
                      34  RG.dylib                  0x00000001020fa5b2 RG_Traverser::Execute(RG_RenderRequest const&, M_LRect const&, PF_World*, M_LRect*) + 66
                      35  RG.dylib                  0x00000001020fa831 RG_ExecuteGraph(RG_RenderNode const*, RG_RenderRequest const&, M_LRect const&, PF_World*, M_LRect*) + 81
                      36  BEE.dylib                 0x00000001012e41a4 BEE_RenderAdjustmentLayerForArtisan(PR_RenderContext**, BEE_RenderTrace*, PF_World*, M_Rect*, PF_World**) + 3124
                      37  BEE.dylib                 0x00000001012e46f2 BEE_RenderAdjustmentLayerForArtisan(PR_RenderContext**, BEE_RenderTrace*, PF_World*, M_Rect*, PF_World**) + 4482
                      38  BEE.dylib                 0x00000001011ec01e BEE_CheckoutItemFrame(BEE_Item*, BEE_ItemRenderOptions const&, BEE_CheckoutReceipt*, bool) + 878
                      39  BEE.dylib                 0x00000001011e8a2e BEE_CheckoutCachedItemFrameRange(BEE_LockRangeProgressInfo*, BEE_CacheHitType, BEE_Item*, BEE_ItemRenderOptions const&, T_Time*, T_Time*, int, short, BEE_CheckoutRange*, boost::shared_ptr<BEE_CacheLog>*, bool) + 2270
                      40  BEE.dylib                 0x00000001011ec667 BEE_CheckoutItemFrame(BEE_Item*, BEE_ItemRenderOptions const&, BEE_CheckoutReceipt*, bool) + 2487
                      41  BEE.dylib                 0x00000001012d69ff BEE_GetTracedParentCompSpanFromRootCompSpan(BEE_RenderTrace const*, T_Time const*, T_Time const*, T_Time*, T_Time*) + 415
                      42  RG.dylib                  0x00000001020f9499 RG_CheckoutResult::SkipRendering() + 1225
                      43  RG.dylib                  0x00000001020f95f2 RG_CheckoutResult::SkipRendering() + 1570
                      44  RG.dylib                  0x00000001020f965f RG_CheckoutResult::GetWorld() + 79
                      45  RG.dylib                  0x00000001020f1246 RG_CompositeNodeBase::Render(RG_NodeRenderCB*, RG_RenderRequest const&, RG_NodeData const*) const + 406
                      46  RG.dylib                  0x00000001020f9499 RG_CheckoutResult::SkipRendering() + 1225
                      47  RG.dylib                  0x00000001020f95f2 RG_CheckoutResult::SkipRendering() + 1570
                      48  RG.dylib                  0x00000001020f965f RG_CheckoutResult::GetWorld() + 79
                      49  FLT.dylib                 0x000000010189e349 FLTp_Node::CheckoutLayerRender(FLTp_NodeLayerCheckoutCBData*, int, PF_LayerDef**) const + 89
                      50  FLT.dylib                 0x0000000101893691 FLT_FCSeqSpec::GetDependentMapFrameRange(T_TimeSpan const&, T_Time const&, int*, int*) const + 673
                      51  com.adobe.AfterEffects.Curves 0x000000010c71d3d5 EffectMainExtra + 2085
                      52  FLT.dylib                 0x00000001018d1254 FLTp_DoLazyGlobals(FLT_FCSpec*, unsigned char*, unsigned char*) + 5252
                      53  FLT.dylib                 0x000000010189e507 FLTp_Node::Render(RG_NodeRenderCB*, RG_RenderRequest const&, RG_NodeData const*) const + 183
                      54  RG.dylib                  0x00000001020f9499 RG_CheckoutResult::SkipRendering() + 1225
                      55  RG.dylib                  0x00000001020f95f2 RG_CheckoutResult::SkipRendering() + 1570
                      56  RG.dylib                  0x00000001020f9765 RG_CheckoutResult::GetOutputWorld() + 85
                      57  BEE.dylib                 0x00000001012d4b68 BEE_DisposeNestedCompRenderContextForArtisan(PR_RenderContext**) + 1832
                      58  RG.dylib                  0x00000001020f9499 RG_CheckoutResult::SkipRendering() + 1225
                      59  RG.dylib                  0x00000001020f95f2 RG_CheckoutResult::SkipRendering() + 1570
                      60  RG.dylib                  0x00000001020f9765 RG_CheckoutResult::GetOutputWorld() + 85
                      61  RG.dylib                  0x00000001020f121e RG_CompositeNodeBase::Render(RG_NodeRenderCB*, RG_RenderRequest const&, RG_NodeData const*) const + 366
                      62  RG.dylib                  0x00000001020f9499 RG_CheckoutResult::SkipRendering() + 1225
                      63  RG.dylib                  0x00000001020fa341 RG_Traverser::Execute(RG_RenderRequest const&, M_LRect*, char*, PF_World**, RG_BufferLock**) + 449
                      64  RG.dylib                  0x00000001020fa5b2 RG_Traverser::Execute(RG_RenderRequest const&, M_LRect const&, PF_World*, M_LRect*) + 66
                      65  RG.dylib                  0x00000001020fa831 RG_ExecuteGraph(RG_RenderNode const*, RG_RenderRequest const&, M_LRect const&, PF_World*, M_LRect*) + 81
                      66  BEE.dylib                 0x00000001012e41a4 BEE_RenderAdjustmentLayerForArtisan(PR_RenderContext**, BEE_RenderTrace*, PF_World*, M_Rect*, PF_World**) + 3124
                      67  BEE.dylib                 0x00000001012e46f2 BEE_RenderAdjustmentLayerForArtisan(PR_RenderContext**, BEE_RenderTrace*, PF_World*, M_Rect*, PF_World**) + 4482
                      68  BEE.dylib                 0x00000001011ec01e BEE_CheckoutItemFrame(BEE_Item*, BEE_ItemRenderOptions const&, BEE_CheckoutReceipt*, bool) + 878
                      69  BEE.dylib                 0x00000001011e8a2e BEE_CheckoutCachedItemFrameRange(BEE_LockRangeProgressInfo*, BEE_CacheHitType, BEE_Item*, BEE_ItemRenderOptions const&, T_Time*, T_Time*, int, short, BEE_CheckoutRange*, boost::shared_ptr<BEE_CacheLog>*, bool) + 2270
                      70  BEE.dylib                 0x00000001011e9251 BEE_CheckoutCachedItemFrameRange(BEE_LockRangeProgressInfo*, BEE_CacheHitType, BEE_Item*, BEE_ItemRenderOptions const&, T_Time*, T_Time*, int, short, BEE_CheckoutRange*, boost::shared_ptr<BEE_CacheLog>*, bool) + 4353
                      71  com.adobe.AfterEffects.AEGPDriver0x0000000122ae5caa 0x122ab9000 + 183466
                      72  com.adobe.AfterEffects.AEDynamicLinkServer0x0000000122c4d89f AEDynamicLinkServerMain + 246751
                      73  com.adobe.AfterEffects.AEDynamicLinkServer0x0000000122c509a1 AEDynamicLinkServerMain + 259297
                      74  com.adobe.AfterEffects.AEDynamicLinkServer0x0000000122c51985 AEDynamicLinkServerMain + 263365
                      75  com.adobe.AfterEffects.AEDynamicLinkServer0x0000000122c15fe2 AEDynamicLinkServerMain + 19234
                      76  com.adobe.AfterEffects.AEDynamicLinkServer0x0000000122c16566 AEDynamicLinkServerMain + 20646
                      77  com.adobe.AfterEffects.AEGPDriver0x0000000122b01630 GPMain_AEGPDriver + 65024
                      78  com.adobe.AfterEffectsLib.framework0x00000001006b5dad PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char const*, char const*, PT_TrackerEntryPoints const*) + 18701
                      79  com.adobe.AfterEffectsLib.framework0x00000001006c2d33 CChore::Perform(int*) + 883
                      80  com.adobe.AfterEffectsLib.framework0x00000001006b58a9 PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char const*, char const*, PT_TrackerEntryPoints const*) + 17417
                      81  com.adobe.AfterEffectsLib.framework0x00000001006d0a23 CSwitchboard::DoIdle(EventRecord*) + 51
                      82  com.adobe.AfterEffectsLib.framework0x00000001006d1b0c CSwitchboard::IdleTimerFunc(CSwitchboard*) + 220
                      83  com.adobe.AfterEffectsLib.framework0x000000010046f073 0x100468000 + 28787
                      84  com.adobe.dvacore.framework   0x0000000102d4be16 int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 38
                      85  com.adobe.AfterEffectsLib.framework0x0000000100661396 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 5382
                      86  com.adobe.AfterEffectsLib.framework0x00000001006614c1 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 5681
                      87  com.adobe.dvacore.framework   0x0000000102d4acf5 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 197
                      88  com.adobe.AfterEffectsLib.framework0x000000010046f166 0x100468000 + 29030
                      89  com.apple.Foundation      0x00007fff8e81d014 __NSFireTimer + 102
                      90  com.apple.CoreFoundation  0x00007fff8c396f84 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
                      91  com.apple.CoreFoundation  0x00007fff8c396ad6 __CFRunLoopDoTimer + 534
                      92  com.apple.CoreFoundation  0x00007fff8c377471 __CFRunLoopRun + 1617
                      93  com.apple.CoreFoundation  0x00007fff8c376ae6 CFRunLoopRunSpecific + 230
                      94  com.apple.HIToolbox       0x00007fff872e53d3 RunCurrentEventLoopInMode + 277
                      95  com.apple.HIToolbox       0x00007fff872ec63d ReceiveNextEventCommon + 355
                      96  com.apple.HIToolbox       0x00007fff872ec4ca BlockUntilNextEventMatchingListInMode + 62
                      97  com.apple.AppKit          0x00007fff915663f1 _DPSNextEvent + 659
                      98  com.apple.AppKit          0x00007fff91565cf5 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 135
                      99  com.apple.AppKit          0x00007fff9156262d -[NSApplication run] + 470
                      100 com.adobe.AfterEffectsLib.framework0x00000001006b54a2 PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char const*, char const*, PT_TrackerEntryPoints const*) + 16386
                      101 com.adobe.AfterEffectsLib.framework0x000000010065f81c SetAPETerminateFunc(boost::function<void ()()> const&) + 1308
                      102 com.adobe.AfterEffectsLib.framework0x000000010065fee4 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 84
                      103 com.adobe.aerendercore    0x00000001000043b8 main + 1144
                      104 com.adobe.aerendercore    0x0000000100003895 _start + 227
                      105 com.adobe.aerendercore    0x00000001000037b1 start + 33
                      Thread 1:: Dispatch queue: com.apple.libdispatch-manager
                      0   libsystem_kernel.dylib    0x00007fff891377e6 kevent + 10
                      1   libdispatch.dylib         0x00007fff892345be _dispatch_mgr_invoke + 923
                      2   libdispatch.dylib         0x00007fff8923314e _dispatch_mgr_thread + 54
                      Thread 2:
                      0   libsystem_kernel.dylib    0x00007fff89136bca __psynch_cvwait + 10
                      1   libsystem_c.dylib         0x00007fff89ce5274 _pthread_cond_wait + 840
                      2   com.apple.CoreServices.CarbonCore0x00007fff8dd88c9a TSWaitOnCondition + 106
                      3   com.apple.CoreServices.CarbonCore0x00007fff8dd1b3f6 TSWaitOnConditionTimedRelative + 127
                      4   com.apple.CoreServices.CarbonCore0x00007fff8dd600bd MPWaitOnQueue + 181
                      5   com.adobe.MediaCore.Frameworks.ASL.Foundation0x0000000104dc0080 ASL::(anonymous namespace)::TaskProc(void*) + 96
                      6   com.apple.CoreServices.CarbonCore0x00007fff8dd60f22 PrivateMPEntryPoint + 58
                      7   libsystem_c.dylib         0x00007fff89ce18bf _pthread_start + 335
                      8   libsystem_c.dylib         0x00007fff89ce4b75 thread_start + 13
                      Thread 3:
                      5   AdobeACE                  0x0000000108efd18d 0x108ec3000 + 237965
                      6   AdobeACE                  0x0000000108efcb3a 0x108ec3000 + 236346
                      7   com.apple.CoreServices.CarbonCore0x00007fff8dd60f22 PrivateMPEntryPoint + 58
                      8   libsystem_c.dylib         0x00007fff89ce18bf _pthread_start + 335
                      9   libsystem_c.dylib         0x00007fff89ce4b75 thread_start + 13
                      Thread 4:
                      Thread 5:
                      Thread 6:
                      Thread 7:
                      Thread 8:
                      Thread 9:
                      Thread 10:
                      Thread 11:
                      Thread 12:
                      Thread 13:
                      Thread 14:
                      Thread 15:
                      Thread 16:
                      Thread 17:
                      Thread 18:
                      5   com.adobe.dvacore.framework   0x0000000102db3a1f dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 143
                      6   com.adobe.dvacore.framework   0x0000000102d4cd5e boost::function0<void>::operator()() const + 46
                      7   com.adobe.dvacore.framework   0x0000000102dabe53 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
                      8   com.adobe.boost_threads.framework0x0000000107fd2ac4 thread_proxy + 132
                      9   libsystem_c.dylib         0x00007fff89ce18bf _pthread_start + 335
                      10  libsystem_c.dylib         0x00007fff89ce4b75 thread_start + 13
                      Thread 19:
                      Thread 20:
                      Thread 21:
                      Thread 22:
                      Thread 23:
                      Thread 24:
                      Thread 25:
                      1   com.adobe.dvatransport.framework0x0000000107d2cc4e boost::asio::detail::kqueue_reactor<false>::run(bool) + 478
                      2   com.adobe.dvatransport.framework0x0000000107d2dd05 boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 517
                      3   com.adobe.dvatransport.framework0x0000000107d0b8cc SkyConnectionEnv::MainLoop() + 76
                      4   com.adobe.dvatransport.framework0x0000000107d0b939 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
                      5   com.adobe.boost_threads.framework0x0000000107fd2ac4 thread_proxy + 132
                      6   libsystem_c.dylib         0x00007fff89ce18bf _pthread_start + 335
                      7   libsystem_c.dylib         0x00007fff89ce4b75 thread_start + 13
                      Thread 26:
                      2   com.adobe.dvatransport.framework0x0000000107d2de3f boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 831
                      3   com.adobe.dvatransport.framework0x0000000107d2ea35 boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service<boost::asio ::ip::tcp>::work_io_service_runner>::run() + 53
                      4   com.adobe.dvatransport.framework0x0000000107d13c79 asio_detail_posix_thread_function + 25
                      5   libsystem_c.dylib         0x00007fff89ce18bf _pthread_start + 335
                      6   libsystem_c.dylib         0x00007fff89ce4b75 thread_start + 13
                      Thread 27:
                      2   com.adobe.AfterEffects.MThread0x000000010f7a9a8f main + 20767
                      3   com.adobe.dvacore.framework   0x0000000102d4cd5e boost::function0<void>::operator()() const + 46
                      4   com.adobe.dvacore.framework   0x0000000102dabe53 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
                      Thread 28:
                      Thread 29:
                      Thread 30:
                      Thread 31:
                      Thread 32:
                      Thread 33:
                      Thread 34:
                      Thread 35:
                      Thread 36:
                      Thread 37:
                      Thread 38:
                      Thread 39:
                      Thread 40:
                      Thread 41:
                      Thread 42:
                      Thread 43:
                      Thread 44:
                      Thread 45:
                      Thread 46:
                      Thread 47:
                      Thread 48:
                      Thread 49:
                      Thread 50:
                      Thread 51:
                      Thread 52:
                      2   libtbb.dylib              0x000000010001022c tbb::internal::GenericScheduler::wait_while_pool_is_empty() + 92
                      3   libtbb.dylib              0x000000010001ab84 tbb::internal::CustomScheduler<tbb::internal::IntelSchedulerTraits>::wait_for_all(tbb::ta sk&, tbb::task*) + 1858
                      4   libtbb.dylib              0x0000000100012e3a tbb::internal::GenericScheduler::worker_routine(void*) + 632
                      Thread 53:
                      Thread 54:
                      Thread 55:
                      Thread 56:
                      Thread 57:
                      Thread 58:
                      Thread 59:
                      Thread 60:
                      Thread 61:
                      Thread 62:
                      Thread 63:
                      Thread 64:
                      Thread 65:
                      Thread 66:
                      Thread 67:
                      Thread 68:
                      Thread 69:
                      Thread 70:
                      Thread 71:
                      Thread 72:
                      Thread 73:
                      Thread 74:
                      Thread 75:
                      0   libsystem_kernel.dylib    0x00007fff89136e42 __semwait_signal + 10
                      1   libsystem_c.dylib         0x00007fff89c97dea nanosleep + 164
                      2   libsystem_c.dylib         0x00007fff89c97c2c sleep + 61
                      3   com.redgiantsoftware.Knoll-Light-Factory-EZ-640x000000011a010c45 AEFX_ReleaseDrawbotSuites + 7809
                      4   com.redgiantsoftware.Knoll-Light-Factory-EZ-640x000000011a012632 AEFX_ReleaseDrawbotSuites + 14446
                      Thread 76 Crashed:: Dispatch queue: com.apple.root.default-priority
                      0   libsystem_kernel.dylib    0x00007fff89136ce2 __pthread_kill + 10
                      1   libsystem_c.dylib         0x00007fff89ce37d2 pthread_kill + 95
                      2   libsystem_c.dylib         0x00007fff89cd4a7a abort + 143
                      3   libc++abi.dylib           0x00007fff8d98b7bc abort_message + 214
                      4   libc++abi.dylib           0x00007fff8d98909c __cxa_pure_virtual + 18
                      5   com.adobe.dvacore.framework   0x0000000102d65a94 dvacore::debug::Trace(char const*) + 84
                      6   com.adobe.dvamarshal.framework0x0000000107de4ad2 dvamarshal::Responder::SendError(int, std::basic_string<unsigned short, std::char_traits<unsigned short>, std::allocator<unsigned short> > const&) + 1634
                      7   com.adobe.AfterEffects.AEDynamicLinkServer0x0000000122c516b1 AEDynamicLinkServerMain + 262641
                      8   com.adobe.AfterEffects.AEDynamicLinkServer0x0000000122c0ff18 unsigned short* std::basic_string<unsigned short, std::char_traits<unsigned short>, std::allocator<unsigned short> >::_S_construct<unsigned short*>(unsigned short*, unsigned short*, std::allocator<unsigned short> const&, std::forward_iterator_tag) + 20472
                      9   com.adobe.dvamarshal.framework0x0000000107e08ecc dvamarshal::RPCServer::OnRequestReceived(boost::shared_ptr<dvatransport::Session>, boost::shared_ptr<std::vector<unsigned char, std::allocator<unsigned char> > >) + 2556
                      10  com.adobe.dvamarshal.framework0x0000000107e09aac boost::detail::function::function_obj_invoker2<boost::_bi::bind_t<dvatransport::Transport Error, boost::_mfi::mf2<dvatransport::TransportError, dvamarshal::RPCServer, boost::shared_ptr<dvatransport::Session>, boost::shared_ptr<std::vector<unsigned char, std::allocator<unsigned char> > > >, boost::_bi::list3<boost::_bi::value<dvamarshal::RPCServer*>, boost::arg<1> (*)(), boost::arg<2> (*)()> >, dvatransport::TransportError, boost::shared_ptr<dvatransport::Session>, boost::shared_ptr<std::vector<unsigned char, std::allocator<unsigned char> > > >::invoke(boost::detail::function::function_buffer&, boost::shared_ptr<dvatransport::Session>, boost::shared_ptr<std::vector<unsigned char, std::allocator<unsigned char> > >) + 140
                      11  com.adobe.dvatransport.framework0x0000000107d00f26 boost::function2<dvatransport::TransportError, boost::shared_ptr<dvatransport::Session>, boost::shared_ptr<std::vector<unsigned char, std::allocator<unsigned char> > > >::operator()(boost::shared_ptr<dvatransport::Session>, boost::shared_ptr<std::vector<unsigned char, std::allocator<unsigned char> > >) const + 118
                      12  com.adobe.dvatransport.framework0x0000000107cfc17b dvatransport::TransportListenerManager::Process_SessionRecvMessage(boost::shared_ptr<dvat ransport::SessionFacade>, boost::shared_ptr<std::vector<unsigned char, std::allocator<unsigned char> > >) + 491
                      13  com.adobe.dvatransport.framework0x0000000107cfc2ea dvatransport::TransportListenerManager::Process_SessionRecvMessage(boost::shared_ptr<dvat ransport::SessionFacade>, boost::shared_ptr<std::vector<unsigned char, std::allocator<unsigned char> > >) + 858
                      14  com.adobe.dvatransport.framework0x0000000107cfc764 dvatransport::GenericTransporter::SessionTable_RecvMessage(boost::shared_ptr<dvatransport ::GenericSession>, boost::shared_ptr<std::vector<unsigned char, std::allocator<unsigned char> > >) + 228
                      15  com.adobe.dvatransport.framework0x0000000107cfcbed dvatransport::GenericTransporter::NotifyIncomingExecute(unsigned long long) + 637
                      16  com.adobe.dvatransport.framework0x0000000107cfcfc8 dvatransport::GenericTransporter::StaticNotifyIncomingExecute(boost::weak_ptr<dvatranspor t::GenericTransporter>, unsigned long long) + 72
                      17  com.adobe.dvatransport.framework0x0000000107cfd8c2 boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::weak_ptr<dvatransport::GenericTransporter>, unsigned long long), boost::_bi::list2<boost::_bi::value<boost::weak_ptr<dvatransport::GenericTransporter> >, boost::_bi::value<unsigned long long> > >, void>::invoke(boost::detail::function::function_buffer&) + 50
                      18  com.adobe.dvacore.framework   0x0000000102db64ce dvacore::threads::ExecuteTopLevelFunction(dvacore::threads::AllocatedFunctionT<boost::fun ction<void ()()> > const&) + 46
                      19  com.adobe.dvacore.framework   0x0000000102db5dc8 dvacore::threads::(anonymous namespace)::WrapGCDAsyncCall(void*) + 24
                      20  libdispatch.dylib         0x00007fff89233799 _dispatch_worker_thread2 + 255
                      21  libsystem_c.dylib         0x00007fff89ce33da _pthread_wqthread + 316
                      22  libsystem_c.dylib         0x00007fff89ce4b85 start_wqthread + 13
                      Thread 76 crashed with X86 Thread State (64-bit):
                        rax: 0x0000000000000000  rbx: 0x0000000000000006  rcx: 0x000000010f4fae48  rdx: 0x0000000000000000
                        rdi: 0x000000000000a993  rsi: 0x0000000000000006  rbp: 0x000000010f4fae70  rsp: 0x000000010f4fae48
                         r8: 0x00007fff76f24fb8   r9: 0x000000000000088e  r10: 0x00007fff89136d0a  r11: 0xffffff80002d8220
                        r12: 0x000000010f4fafd0  r13: 0x00007fff8d98908a  r14: 0x000000010f4fc000  r15: 0x000000010f4fafc0
                        rip: 0x00007fff89136ce2  rfl: 0x0000000000000206  cr2: 0x000000010f4fafdc
                      Logical CPU: 0
                      Binary Images:
                         0x100000000 -    0x100004ff3 +com.adobe.aerendercore (10.0.2 - 10.0) <F872C6DA-F095-3192-A614-32D267C5815F> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/aeselflink.app/Contents/MacOS/aeselflink
                         0x100007000 -    0x100020feb +libtbb.dylib (??? - ???) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/libtbb.dylib
                         0x100031000 -    0x100037feb +libtbbmalloc.dylib (??? - ???) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/libtbbmalloc.dylib
                         0x10003e000 -    0x10004aff5 +com.adobe.boost_signals.framework (boost_signals version 5.0.0 - 5.0.0.213330) <7ED4C50F-F971-3D91-A97B-7374FE8449C7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
                         0x10005c000 -    0x10005dfff +com.adobe.boost_system.framework (boost_system version 5.0.0 - 5.0.0.213330) <B9C598B2-22A8-F01D-E6D3-98CEEEEEDFE8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                         0x100063000 -    0x10006aff3 +com.adobe.boost_date_time.framework (boost_date_time version 5.0.0 - 5.0.0.213330) <75F741A6-3459-0C54-5981-879FD5FB4513> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                         0x10007a000 -    0x10007fffd +com.adobe.AdobeCrashReporter (3.0 - 3.0.20100302) <DFFB9A08-8369-D65F-161F-7C61D562E307> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                         0x100084000 -    0x1001c7fef +WRServices (??? - ???) <DD50D315-C0EC-C729-AC67-92588187E8C7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                         0x100213000 -    0x100317fef +hydra_filters (??? - ???) <0B1F2AA6-8987-64E8-8A6A-6C10E07995AA> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/hydra_filters.framework/Versions/A/hydra_filters
                         0x10040c000 -    0x10042afff +image_runtime (??? - ???) <47C885A9-B0DB-9DA4-D491-4848D6E16C9C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
                         0x100464000 -    0x100465fff +ALOG.dylib (??? - ???) <17C79781-1C74-FF1D-3B9B-7E3C479E04CA> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ALOG.dylib
                         0x100468000 -    0x100e3cfef +com.adobe.AfterEffectsLib.framework (AfterFXLib 1.0 - 1.0) <6C988E88-DA41-533C-6ABB-014428C93D75> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AfterFXLib.framework/Versions/A/AfterFXLib
                         0x101195000 -    0x101195ff7 +AEFX.dylib (??? - ???) <38C91126-8F3A-72A3-9C1A-A5F4F7D26DE8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AEFX.dylib
                         0x101198000 -    0x101553fe7 +BEE.dylib (??? - ???) <824D107A-32B4-C27D-E7FF-992200A1D4E2> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BEE.dylib
                         0x10179c000 -    0x1017abff3 +BEZ.dylib (??? - ???) <64DD0A27-9811-D4DA-410A-D04A33D51C09> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BEZ.dylib
                         0x1017af000 -    0x1017baff3 +BM.dylib (??? - ???) <4B419D70-BEFB-1518-E243-9F7C427F0BCF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BM.dylib
                         0x1017c1000 -    0x1017fcfff +COR.dylib (??? - ???) <523B2653-982D-A7B1-7E46-3035185FC755> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/COR.dylib
                         0x101818000 -    0x101838ff7 +FILE.dylib (??? - ???) <8C0108DE-0939-B478-83FE-6CAA0B1BD4D9> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FILE.dylib
                         0x101846000 -    0x101873fff +FLO.dylib (??? - ???) <03F3D547-549C-6AF3-C56C-D2FF8D960189> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FLO.dylib
                         0x101879000 -    0x10193cfff +FLT.dylib (??? - ???) <9ACEBA90-E37E-F39A-8983-9740B6B1247C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FLT.dylib
                         0x10199f000 -    0x1019a6ff3 +LIST.dylib (??? - ???) <4B92B54C-58C2-AE03-2FE0-7612292308BB> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/LIST.dylib
                         0x1019aa000 -    0x1019bdfff +M.dylib (??? - ???) <B2E9616F-58D7-C61E-8F3E-B59EB470A5DD> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/M.dylib
                         0x1019c2000 -    0x1019cbff7 +MC.dylib (??? - ???) <7D22B3E7-91DF-29A3-181A-45836A95815D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MC.dylib
                         0x1019d2000 -    0x101a32fff +MSK.dylib (??? - ???) <18567FA4-D29C-A7CC-E171-4951C8D953CE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MSK.dylib
                         0x101a46000 -    0x101a5dff7 +OM.dylib (??? - ???) <038045CD-8F0E-F653-3558-101B8BBD73F1> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/OM.dylib
                         0x101a65000 -    0x101a87ff7 +P.dylib (??? - ???) <E331E1A8-0D31-7AF7-6F8D-648560B35715> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/P.dylib
                         0x101a90000 -    0x101dd9fff +PF.dylib (??? - ???) <28A11568-3D66-D9D3-C223-B148790B645C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PF.dylib
                         0x101e15000 -    0x10201efef +PIN.dylib (??? - ???) <348FE5F6-72CD-81DB-EB79-2D43E254D6A3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PIN.dylib
                         0x10209f000 -    0x1020b9fff +PLUG.dylib (??? - ???) <CD92296B-4DDD-42DE-E1C5-DEE9125435BF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PLUG.dylib
                         0x1020c4000 -    0x1020d7fff +PR.dylib (??? - ???) <DC8D0279-EB98-BDCC-FC4F-9AD89654BD88> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PR.dylib
                         0x1020de000 -    0x1020e4fff +PREF.dylib (??? - ???) <89A77A8E-0D59-1B6C-6B8B-BACD8E306A7D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PREF.dylib
                         0x1020e8000 -    0x102100fff +RG.dylib (??? - ???) <1FE58EAC-5AE5-7721-60FE-22D76E38B44A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RG.dylib
                         0x102109000 -    0x10210bff7 +RI.dylib (??? - ???) <1A162A0E-74E1-D9EC-5DF4-54FA03611E14> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RI.dylib
                         0x10210e000 -    0x10210ffff +RND.dylib (??? - ???) <8EBC47EA-31AF-058E-A866-C4AD643FBA3C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RND.dylib
                         0x102116000 -    0x102175ff7 +SLU.dylib (??? - ???) <07F95C65-97B9-A1E6-28C6-D16C6C83CF44> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SLU.dylib
                         0x10219b000 -    0x1021b7ffd +SND.dylib (??? - ???) <7A46F7CB-529D-6E8F-A9B8-1DCDA8B9C6C9> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SND.dylib
                         0x1021bf000 -    0x1021c2ff1 +STR.dylib (??? - ???) <CF77ED97-0B3A-A09E-123D-70BDC6873B87> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/STR.dylib
                         0x1021c6000 -    0x1021c9fff +T.dylib (??? - ???) <1FF948E2-7673-6A70-9672-E0DB7CD53B68> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/T.dylib
                         0x1021cc000 -    0x102209ff5 +TDB.dylib (??? - ???) <6AAD534E-4FE9-0F67-3332-7C7F768DCFAB> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/TDB.dylib
                         0x10221d000 -    0x1028c8fe5 +TXT.dylib (??? - ???) <E3D83931-3DC1-15DE-07D9-0411C0B8714D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/TXT.dylib
                         0x102a67000 -    0x102aa3ff1 +U.dylib (??? - ???) <1B56EF87-6059-DF73-8664-6F9922B020FE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/U.dylib
                         0x102ab7000 -    0x102abbfff +VAL.dylib (??? - ???) <B6EAB521-C2CA-0EC8-2894-82256EA332FE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VAL.dylib
                         0x102abe000 -    0x102b6efff +com.adobe.exo.framework (exo version 5.0.0 - 5.0.0.213330) <6666025B-D174-3947-9303-74C84DC2691E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/exo.framework/Versions/A/exo
                         0x102c75000 -    0x102c9bff3 +PREM.dylib (??? - ???) <E834653A-E4B7-8FDD-2975-CA7A376BAF24> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PREM.dylib
                         0x102caf000 -    0x102d08fff +FRP.dylib (??? - ???) <11E66C11-1A92-27D3-7F3C-89BEA1076C87> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FRP.dylib
                         0x102d25000 -    0x102e83ff7 +com.adobe.dvacore.framework (dvacore version 5.0.0 - 5.0.0.213330) <7B602339-2F06-3CB4-6F0C-99E44A72C4BD> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                         0x102ff7000 -    0x10333eff7 +com.adobe.dvaui.framework (dvaui version 5.0.0 - 5.0.0.213330) <09E1BD11-A603-AFD7-447F-E8DF43BE5B1E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                         0x1036ff000 -    0x1037adfff +com.adobe.dvaworkspace.framework (dvaworkspace version 5.0.0 - 5.0.0.213330) <EFB19EF5-724F-36D0-2863-6C7D48E18AA7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
                         0x103889000 -    0x1038a9fef +com.adobe.dvaunittesting.framework (dvaunittesting version 5.0.0 - 5.0.0.213330) <9D70CBAE-BEA3-844E-7065-A3D742BD84F6> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
                         0x1038d2000 -    0x1038e2ff8 +com.adobe.ahclientframework (1.5.0.30 - 1.5.0.30) <5D6FFC4E-7B81-3E8C-F0D4-66A3FA94A837> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                         0x1038ed000 -    0x103965fef +com.adobe.adobe_caps (adobe_caps 3.0.116.0 - 3.0.116.0) <4A355686-1451-B19A-0C55-DFE49FD2539E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                         0x10397b000 -    0x1039e0fff +aif_core (??? - ???) <C69264C9-6B12-DAE1-BBF1-086DBCF4B42C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
                         0x103a22000 -    0x103c51fff +aif_ogl (??? - ???) <AAED77EB-4176-229B-52E0-D77A48BD801E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
                         0x103e15000 -    0x103e2bfff +data_flow (??? - ???) <CE8BFE6F-356B-4C21-0629-B5E291DB751C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
                         0x103e5e000 -    0x104353fef +image_compiler (??? - ???) <89706338-A311-D973-1E46-B92A715F2322> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/image_compiler.framework/Versions/A/image_compiler
                         0x104893000 -    0x104929fff +image_flow (??? - ???) <5C0CA6F6-DA34-A648-4F05-8BD41B09DACE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flow
                         0x104a0f000 -    0x104a4eff7 +com.adobe.dynamiclinkui.framework (dynamiclinkui version 5.0.0 - 5.0.0.213330) <DE06F1FB-0F66-5C9F-4F54-299F30265CCF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynamiclinkui
                         0x104aa4000 -    0x104c6dfff +com.adobe.dynamiclink.framework (dynamiclink version 5.0.0 - 5.0.0.213330) <41CBC782-8098-E507-9EF8-1E6CA4BBA682> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
                         0x104d8b000 -    0x104dedff5 +com.adobe.MediaCore.Frameworks.ASL.Foundation (1.0 - 1.0) <C6F9433A-C67A-8F18-DCDA-0CD3FFC43377> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
                         0x104ed4000 -    0x104eeafff +ASLMessaging (??? - ???) <2C7F3B21-594C-18A3-79D0-18427D54746E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
                         0x104f09000 -    0x104f1affe +ASLUnitTesting (??? - ???) <78A491AD-883A-35FF-E2C8-D3BDA34390F5> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
                         0x104f32000 -    0x104f4cff3 +com.adobe.MediaCore.Frameworks.AudioFilterHost (1.0 - 1.0) <F157C4D4-0DE1-03E2-33F7-94C311D9C028> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
                         0x104f74000 -    0x104facfff +com.adobe.MediaCore.Frameworks.AudioFilters (??? - 1.0) <6E96215C-9F5E-4279-F7A0-4373B3DE53F8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
                         0x105017000 -    0x10508ffe3 +com.adobe.MediaCore.Frameworks.AudioRenderer (??? - 1.0) <7DBFA1E2-1936-A36A-F052-87624EA741DB> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
                         0x10512a000 -    0x105168fe1 +com.adobe.MediaCore.Frameworks.AudioSupport (1.0 - 1.0) <D2184349-1E4E-C1DA-9B36-2DD147EBCA04> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
                         0x1051b1000 -    0x105c22fef +com.adobe.MediaCore.Frameworks.Backend (??? - 1.0) <2EAEDF03-A538-10C3-304D-89AA7C3256E5> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
                         0x106949000 -    0x106aedff3 +com.adobe.MediaCore.Frameworks.ImageRenderer (??? - 1.0) <491E09C6-B1E8-34EE-C443-0BD3A994FE08> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
                         0x106c1d000 -    0x106da7ff7 +com.adobe.MediaCore.Frameworks.ImporterHost (1.0 - 1.0) <A1F5620F-064F-84CD-8566-179C34DFF7A0> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
                         0x106f69000 -    0x106f9dfff +com.adobe.MediaFoundation (??? - 1.0) <BB6D09A8-5B89-51DD-A25D-BE037404BC90> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
                         0x106fe0000 -    0x106fe3fff +com.adobe.MediaCore.Frameworks.MediaUtils (1.0 - 1.0) <2D9111FE-D392-8170-FEFA-476F0E4AF1C0> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
                         0x106fe8000 -    0x106fe9fff +com.adobe.MediaCore.Frameworks.Memory (1.0 - 1.0) <AC8511F8-DE4F-AAB3-BB91-E1FC28587970> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
                         0x106fee000 -    0x107029fff +com.adobe.MediaCore.Frameworks.MLFoundation (1.0 - 1.0) <23C68FE4-7DD6-8114-55D6-2BF3D47A9AFF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
                         0x107079000 -    0x1070abfff +com.adobe.MediaCore.Frameworks.PluginSupport (1.0 - 1.0) <0F1CFAA6-9E74-B497-08B8-F38713F1D0D7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
                         0x1070ea000 -    0x1070ebfff +PRM (??? - ???) <D97553CC-84FE-B386-29CF-1123AEBB0737> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
                         0x1070ef000 -    0x107127fff +com.adobe.MediaCore.Frameworks.SweetPeaSupport (1.0 - 1.0) <B3ECEBF7-269E-884F-8486-1174776EF82A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
                         0x107178000 -    0x1071c1fff +com.adobe.MediaCore.VideoFrame (1.0 - 1.0) <B70FFFF8-402F-1016-DAAE-BAB12877B3BB> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
                         0x10720f000 -    0x10732bfff +com.adobe.MediaCore.Frameworks.VideoRenderer (1.0 - 1.0) <D73078CD-417D-60D1-DBFC-7A75A27ABF61> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
                         0x107495000 -    0x10753dfe1 +com.adobe.dvaeve.framework (dvaeve version 5.0.0 - 5.0.0.213330) <AAE0583B-11DB-4FCA-9FAC-F8C9F0D2AA43> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
                         0x10763a000 -    0x1076adfff +com.adobe.MediaCore.Frameworks.PlayerHost (1.0 - 1.0) <7F2013B9-752F-9B86-03C7-EAE70D01D459> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
                         0x107748000 -    0x10781afff +com.adobe.MediaCore.Frameworks.VideoFilterHost (1.0 - 1.0) <8BFECBFA-0E5C-37F5-27DA-8F178C964486> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
                         0x1078dd000 -    0x107947ff7 +com.adobe.amtlib (amtlib 3.0.0.64 - 3.0.0.64) <6B2F73C2-10AB-08B3-4AB0-A31C83D1E5E0> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                         0x10797a000 -    0x107a18ff2 +libicucnv.dylib.36.0 (36.0.0 - compatibility 36.0.0) <5651FB7C-24ED-8CC8-2ADE-A5CB7CA493C3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
                         0x107a38000 -    0x107a53fff +libicudata.dylib.36.0 (36.0.0 - compatibility 36.0.0) <FEF83A1C-8D48-66B4-BED6-B91835D1AA68> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
                         0x107a56000 -    0x107ab0fff +com.adobe.dvametadata.framework (dvametadata version 5.0.0 - 5.0.0.213330) <21955CA4-BC9D-F2CF-B217-E34DFD980ECF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
                         0x107b32000 -    0x107bb6fff +com.adobe.dvametadataUI.framework (dvametadataUI version 5.0.0 - 5.0.0.213330) <4DC58B98-61F8-9200-83F8-E4671A17DED8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
                         0x107c4d000 -    0x107c91ff7 +com.adobe.dvatemporalxmp.framework (dvatemporalxmp version 5.0.0 - 5.0.0.213330) <DB6C3952-1331-F021-0962-08E294C5109E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
                         0x107cb1000 -    0x107ccafff +com.adobe.dvamediatypes.framework (dvamediatypes version 5.0.0 - 5.0.0.213330) <7D8DD5A0-DD60-48D7-F47F-A5FD3C38594E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                         0x107ce9000 -    0x107d5fff7 +com.adobe.dvatransport.framework (dvatransport version 5.0.0 - 5.0.0.213330) <AB14B04F-9B7D-BD45-AE08-0E319432487E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
                         0x107de2000 -    0x107e1eff3 +com.adobe.dvamarshal.framework (dvamarshal version 5.0.0 - 5.0.0.213330) <D968E016-14F2-53ED-1137-B23841F44514> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
                         0x107e8a000 -    0x107e98fff +com.adobe.MediaCore.Frameworks.ProjectSupport (1.0 - 1.0) <61ECFA88-BE54-2D24-A1A4-F2C6EA11869A> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
                         0x107eac000 -    0x107eeffff +DynamicLinkMedia (??? - ???) <F81D082B-981B-D504-17A1-3BF9E61E152F> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
                         0x107f5c000 -    0x107f5cfff  libmx.A.dylib (2026.0.0 - compatibility 1.0.0) <C23BF0A1-7E6D-35EF-85FE-651EE2C13D53> /usr/lib/libmx.A.dylib
                         0x107f5f000 -    0x107f8aff6 +AdobeAXE8SharedExpat (??? - ???) <F5C1010B-CAFF-5290-8B55-6FEB3A287225> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
                         0x107f9c000 -    0x107fa2fff  com.apple.agl (3.1.4 - AGL-3.1.4) <FF5AC177-9B51-3FB8-9AD3-E2296CFC6BCA> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                         0x107fa9000 -    0x107fc6fff +AdobeBIB (??? - ???) <3FF7BFF2-52DF-046A-A081-2BDB1055A1B4> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                         0x107fd0000 -    0x107fd8ff3 +com.adobe.boost_threads.framework (boost_threads version 5.0.0 - 5.0.0.213330) <6C490A02-CF74-2F86-C015-984FF873AAEC> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                         0x107fe7000 -    0x10803dfeb +com.adobe.headlights.LogSessionFramework (??? - 2.0.1.011) <03B80698-2C3B-A232-F15F-8F08F8963A19> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                         0x108082000 -    0x108140ffb +filter_graph (??? - ???) <90535156-341B-C860-30A4-DB3E13327893> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/filter_graph.framework/Versions/A/filter_graph
                         0x108268000 -    0x1082c6ffd +AdobeXMP (??? - ???) <29839F01-4A21-5B72-FF9A-E030D214F5E2> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                         0x1082d4000 -    0x108360fe3 +AdobeXMPFiles (??? - ???) <C4531436-CA4F-8A06-0481-CD1648C20C48> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
                         0x108398000 -    0x108438fef +com.adobe.AdobeScCore (ScCore 4.1.25 - 4.1.25.10116) <2049AC79-9EFA-1D8B-C577-174B36569A29> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                         0x10847e000 -    0x108522ffb +com.adobe.AdobeExtendScript (ExtendScript 4.1.25 - 4.1.25.10116) <B2464DBF-230E-3187-6004-F8A804ED24A3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
                         0x108584000 -    0x108662fef +AdobeAXEDOMCore (??? - ???) <8D4592B8-5DA1-D957-B1BA-FB20116514DD> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                         0x1086da000 -    0x108a0bfe7 +AdobeCoolType (??? - ???) <C93152AA-AC85-5157-0B28-AFE1D6CAA31F> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                         0x108aa7000 -    0x108df1fe7 +AdobeAGM (??? - ???) <E48474D7-E499-6F7A-9F2A-E9A82D075405> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                         0x108ec3000 -    0x108fd8fff +AdobeACE (??? - ???) <0A896D92-86A5-D870-9BE0-755ADD1B1A33> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                         0x108ffd000 -    0x10901efff +AdobeBIBUtils (??? - ???) <1468CBC0-B799-0808-91D1-78BAD0320F99> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                         0x10902b000 -    0x1090feffb +AdobeJP2K (??? - ???) <8571D9BA-44F9-92A3-0444-5FFAC2994B88> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                         0x10911e000 -    0x10915fff7 +AdobeARE (??? - ???) <CE1A57E7-5175-C3A7-B644-94B4D149ED13> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
                         0x109169000 -    0x1097c1fef +AdobePDFL (??? - ???) <45AA7483-10A6-2DAB-1FF8-62C9E615039E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
                         0x109910000 -    0x109e21fff +AdobeMPS (??? - ???) <10C4E979-45F3-A7C6-0438-262CE5F595B9> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                         0x109ef7000 -    0x109f22fef +AdobeAXE16SharedExpat (??? - ???) <F5E56D3B-AE0E-245C-E706-DFA630D6771C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedEx pat
                         0x109f34000 -    0x10acf7fff +com.adobe.psl (AdobePSL 12.0.0.7667 - 12.0.0.7667) <F1C9409D-033E-58D0-B902-6422BC488AA5> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
                         0x10b067000 -    0x10b112feb +com.adobe.MediaCore.Frameworks.ExporterHost (1.0 - 1.0) <4FB7350B-F8E6-3F52-FF7C-F5ADC5F8D5C2> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
                         0x10b226000 -    0x10b246feb +SegMatServices.dylib (??? - ???) <B7428FCE-F64A-B2CF-E4F5-949C939CBD4B> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SegMatServices.dylib
                         0x10b253000 -    0x10b253ff7 +SAM.dylib (??? - ???) <502250ED-293F-096C-A500-FFDC26B4D291> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SAM.dylib
                         0x10b256000 -    0x10b339fff  libcrypto.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <358B5B40-43B2-3F92-9FD3-DAA68806E1FF> /usr/lib/libcrypto.0.9.7.dylib
                         0x10b38f000 -    0x10b667fe6 +libxerces-c-3.0.dylib (??? - ???) <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/libxerces-c-3.0.dylib
                         0x10b7e1000 -    0x10b7f7ff6 +com.adobe.AMEAppFoundation.framework (??? - 1.0) <1DD15F8C-040E-AF21-688C-FFBA5B51CDE7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
                         0x10b818000 -    0x10b83bff1 +com.adobe.PostEncodeHost.framework (??? - 1.0) <5E752955-289E-3167-0141-DE35752552F8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostEncodeHost
                         0x10b869000 -    0x10b925ff7 +AMEWrapper (??? - ???) <5EA10E44-E9FB-99D3-7343-2DD221D4E26E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrapper
                         0x10b9e4000 -    0x10baebfff +com.adobe.EncoderHost.framework (??? - 1.0) <1E94B9FE-C03E-A69D-4CDA-FA3C7A5D6026> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
                         0x10bbf0000 -    0x10bdbdfff +com.adobe.SettingsUI.framework (??? - 1.0) <6771ACBD-81A3-C8D3-2FAF-252B74B7C313> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
                         0x10c01a000 -    0x10c078ff7 +com.adobe.MediaCore.Frameworks.Utilities.QT32Client (1.0 - 1.0) <8ECDD03C-91E6-9BF7-9799-81444AE58FEE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Client
                         0x10c0e6000 -    0x10c111fff  com.apple.carbonframeworktemplate (1.0 - 1.0) <7BE552FD-E6C2-ECF3-44C1-C2B811D3743D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefoundation
                         0x10c14b000 -    0x10c174fff +ameproperties (??? - ???) <85EDF89A-CEE5-FD89-250A-5501F426A8A3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ameproperties.framework/Versions/A/ameproperties
                         0x10c1b7000 -    0x10c1bbff2 +com.adobe.AppServices.framework (??? - 1.0) <2A048D8F-1E9F-B137-031E-0F00AE2B07EF> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AppServices.framework/Versions/A/AppServices
                         0x10c701000 -    0x10c702ff7 +com.adobe.AfterEffects.Paint (??? - ???) <5B77146F-A369-A587-E45B-5031D5FDCEAB> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Paint.plugin/Contents/MacOS/Paint
                         0x10c705000 -    0x10c714fff +com.adobe.AfterEffects.FreePin (??? - ???) <A0A70A3D-76D6-FD23-83D6-EAFB696BFD50> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Puppet.plugin/Contents/MacOS/FreePin
                         0x10c718000 -    0x10c727ff7 +com.adobe.AfterEffects.Curves (??? - ???) <794331F9-55EF-E98B-1A19-B3465BF327AF> /Applications/Adobe After Effects CS5/*/Curves.plugin/Contents/MacOS/Curves
                         0x10c72c000 -    0x10c73dfff +com.adobe.AfterEffects.Hue_Sat (??? - ???) <437B911F-25EB-9166-C311-64B337D08609> /Applications/Adobe After Effects CS5/*/Hue_Sat.plugin/Contents/MacOS/Hue_Sat
                         0x10c742000 -    0x10c748fff +com.adobe.AfterEffects.Ramp (??? - ???) <B943F4EE-376A-0CCD-451A-D5D46E3E6FB1> /Applications/Adobe After Effects CS5/*/Ramp.plugin/Contents/MacOS/Ramp
                         0x10c74b000 -    0x10c779ff7  GLRendererFloat (??? - ???) <16DF14A0-7264-31A4-83F6-E6F96CF4AB3D> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
                         0x10c783000 -    0x10c785fff  com.apple.textencoding.unicode (2.4 - 2.4) <FD4695F4-6110-36C6-AC06-86453E30FF6E> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                         0x10e7e7000 -    0x10e7ebff7  libFontRegistryUI.dylib (??? - ???) <F617D431-0BCD-3E1F-9BFC-599FDFAC99A0> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistryUI.dylib
                         0x10f400000 -    0x10f431fff +com.adobe.MediaCore.ImporterMPEG (1.0 - 1.0) <BD4C1DFF-7E23-CB28-EC77-73D735B7AA53> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ImporterMPEG.bundle/Contents/MacOS/ImporterMPEG
                         0x10f79f000 -    0x10f7abfff +com.adobe.AfterEffects.MThread (??? - ???) <F027B6CF-87F7-461D-FF5E-B480B3208684> /Applications/Adobe After Effects CS5/*/Mthread.plugin/Contents/MacOS/MThread
                         0x1147e5000 -    0x1147e9fff +com.adobe.AfterEffects.EasyEase (??? - ???) <1EEBC378-C767-1E87-F2D1-E71F2628D7A9> /Applications/Adobe After Effects CS5/*/EasyEase.plugin/Contents/MacOS/EasyEase
                         0x1147f0000 -    0x1147f4ff7 +com.adobe.AfterEffects.ExpScale (??? - ???) <A6A418C2-F688-4D08-CADF-81FEE0F48447> /Applications/Adobe After Effects CS5/*/ExpScale.plugin/Contents/MacOS/ExpScale
                         0x1147f7000 -    0x1147faff7 +com.adobe.AfterEffects.Durer (??? - ???) <B2939DFA-9DCA-D8C3-AF5E-886EC0B8A3A9> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Standard3D.plugin/Contents/MacOS/Durer
                         0x114f91000 -    0x114f92fff  ATSHI.dylib (??? - ???) <F13B3CE7-DFD5-3FB4-B56F-73F6348A80EE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
                         0x114feb000 -    0x114feffff  com.apple.audio.AudioIPCPlugIn (1.2.1 - 1.2.1) <46DBC886-A984-36F8-BAC6-CFBAED880258> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
                         0x114ff4000 -    0x114ffafff  com.apple.audio.AppleHDAHALPlugIn (2.1.3 - 2.1.3f7) <25F21980-C114-3688-B6E7-FD83052D67B1> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                         0x118111000 -    0x11813bff1 +com.mainconcept.mc_dec_dv (8.5 - 8.5.0.14572) <CFF0820D-B6C1-0DB8-43DE-35169748FD94> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/aeselflink.app/Contents/Frameworks/mc_dec_dv.framework/mc_dec_dv
                         0x118154000 -    0x11816cff3 +com.adobe.MediaCore.Frameworks.QTParser (1.0 - 1.0) <57895541-6128-EDAC-440D-BDB5196BA07F> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
                         0x1189bb000 -    0x1189e2ff1 +com.mainconcept.mc_enc_dv (8.5 - 8.5.0.14572) <46AB8404-6892-F7BF-150E-D8249ECFD0B8> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/aeselflink.app/Contents/Frameworks/mc_enc_dv.framework/mc_enc_dv
                         0x1189f6000 -    0x1189fafff +com.adobe.AfterEffects.TRKeys (??? - ???) <4E2F842E-6234-EAD6-DDF1-60684C295EFD> /Applications/Adobe After Effects CS5/*/TRKeys.plugin/Contents/MacOS/TRKeys
                         0x118e83000 -    0x118e87ff7 +com.adobe.AfterEffects.RPFImport (??? - ???) <4501BFAD-388B-B3D7-BA8D-6E2348510C2B> /Applications/Adobe After Effects CS5/*/RPFImport.plugin/Contents/MacOS/RPFImport
                         0x11a000000 -    0x11a04ffef +com.redgiantsoftware.Knoll-Light-Factory-EZ-64 (2.7.2 - ???) <1C3CF6F6-BB1E-7BEB-6FEA-3C1AB7447945> /Library/Application Support/Adobe/*/Knoll Light Factory EZ 64.plugin/Contents/MacOS/Knoll Light Factory EZ 64
                         0x11a079000 -    0x11a07cff7 +com.adobe.AfterEffects.Fill (??? - ???) <1670EE48-72E7-0D9C-3006-A4AE0DCC0D5F> /Applications/Adobe After Effects CS5/*/Fill.plugin/Contents/MacOS/Fill
                         0x11a0da000 -    0x11a0dbff7  libCyrillicConverter.dylib (54.0.0 - compatibility 1.0.0) <B33779D3-937C-39A1-91E9-385B5268EF70> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
                         0x11a0e6000 -    0x11a0ecff7 +com.adobe.AfterEffects.Sequence (??? - ???) <FCC7D1D9-B4D7-A230-28E4-9AA5E0E7F128> /Applications/Adobe After Effects CS5/*/Sequence.plugin/Contents/MacOS/Sequence
                         0x11a0f1000 -    0x11a0f5ff8 +com.adobe.ape.shim (adbeape version 3.1.65.7508 - 3.1.65.7508) <0C380604-C686-C2E4-0535-C1FAB230187E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                         0x11a7c5000 -    0x11a7dbfe7 +com.adobe.AfterEffects.PS3Export (??? - ???) <CC5AFFF6-03B4-CA61-E7F3-FBEED55C8DC0> /Applications/Adobe After Effects CS5/*/PS Layer Export.plugin/Contents/MacOS/PS3Export
                         0x11a7e7000 -    0x11a7f3ff7 +com.adobe.AfterEffects.LocalizePresets (??? - ???) <17C7FDFE-ED29-06C8-2366-28BCAD07AFF3> /Applications/Adobe After Effects CS5/*/LocalizePresets.plugin/Contents/MacOS/LocalizePresets
                         0x11b57f000 -    0x11b5c1fff +com.adobe.MediaCore.ImporterQuickTime (1.0 - 1.0) <87C8B24A-FCED-0A22-011B-3EADF0D3C4C3> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ImporterQuickTime.bundle/Contents/MacOS/ImporterQui ckTime
                         0x11b700000 -    0x11b722ff3 +com.adobe.AfterEffects.PS3Import (??? - ???) <E4385DB6-F96C-2D00-2A87-521B20F912DB> /Applications/Adobe After Effects CS5/*/PS Layer Import.plugin/Contents/MacOS/PS3Import
                         0x11b733000 -    0x11b750fff +com.adobe.AfterEffects.AudioPal (??? - ???) <94CFD84C-1556-1AB5-24FB-5C0B37BEF258> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Audio Palette.plugin/Contents/MacOS/AudioPal
                         0x11b762000 -    0x11b76dfff +com.adobe.AfterEffects.Analyzer (??? - ???) <815BF143-ED92-7D39-EB23-2C62468C8C33> /Applications/Adobe After Effects CS5/*/Analyzer.plugin/Contents/MacOS/Analyzer
                         0x11d904000 -    0x11d974ff6 +com.adobe.amt.services (AMTServices 3.0.0.64 [BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00] - 3.0.0.64) <52FF1F9B-9991-ECE2-C7E3-09DA1B368CBE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
                         0x11d9b6000 -    0x11d9e5ffb +com.adobe.AfterEffects.BrushPal (??? - ???) <E5EADE5D-9FD8-273E-9365-8D0AF4EDCA5F> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Brush Palette.plugin/Contents/MacOS/BrushPal
                         0x11eefc000 -    0x11ef0fff7 +libKLF_OGL.dylib (??? - ???) <3A9D4BD1-BB5E-56DC-DDCC-4D329A261BC1> /usr/local/lib/libKLF_OGL.dylib
                         0x11f6c6000 -    0x11f6e8fff +com.adobe.AfterEffects.InfoPal (??? - ???) <C7D5511C-C227-9B32-6A81-BA5208B11719> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Info Palette.plugin/Contents/MacOS/InfoPal
                         0x11feb6000 -    0x12007dfef +com.adobe.MediaCore.ImporterRED (1.01 - 1.0) <8B43E093-9776-BA88-BA13-DC2B16E1D9E7> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ImporterRED.bundle/Contents/MacOS/ImporterRED
                         0x1202b4000 -    0x1202e0ffb +com.adobe.AfterEffects.PaintPal (??? - ???) <FB1601E2-EDBB-AF31-A66A-B0B41F47C619> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Paint Palette.plugin/Contents/MacOS/PaintPal
                         0x1205e6000 -    0x120605fe3 +com.adobe.AfterEffects.Jpg (??? - ???) <729A1D95-35C8-A460-772B-1E2A113BD6E5> /Applications/Adobe After Effects CS5/*/JPEG.plugin/Contents/MacOS/Jpg
                         0x122ab9000 -    0x122b3afff +com.adobe.AfterEffects.AEGPDriver (??? - ???) <67C926C0-5043-F3A2-D806-82E04ABCFB37> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/AEGPDriver.plugin/Contents/MacOS/AEGPDriver
                         0x122b72000 -    0x122be8fff +com.adobe.AfterEffects.Escher (??? - ???) <85979F2D-DDAC-4318-C4FB-D8840E6198EE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Advanced3D.plugin/Contents/MacOS/Escher
                         0x122bf5000 -    0x122c73ff3 +com.adobe.AfterEffects.AEDynamicLinkServer (??? - ???) <C0725AC0-F27A-7DEA-D4BD-F1479958653C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/AEDynamicLinkServer.plugin/Contents/MacOS/AEDynamicLinkServer
                         0x122dad000 -    0x122dceff7 +com.adobe.AfterEffects.ParaPal (??? - ???) <F540ED0F-008D-3C74-7473-C7361233EA5E> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Paragraph Palette.plugin/Contents/MacOS/ParaPal
                         0x122de2000 -    0x122df2fff +com.adobe.AfterEffects.MayaImport (??? - ???) <05ECF3B4-4010-A6B2-BB72-A3E4F315AC59> /Applications/Adobe After Effects CS5/*/MayaImport.plugin/Contents/MacOS/MayaImport
                         0x122f00000 -    0x122f40ff7 +com.adobe.AfterEffects.CharPal (??? - ???) <ACA5E9B5-8A7E-C9A0-83BD-2948142460A5> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Character Palette.plugin/Contents/MacOS/CharPal
                         0x122f61000 -    0x1230f8fff +com.adobe.AfterEffects.SnapCut (??? - ???) <1F9B1DDD-DD0F-1EEC-33F3-12A29EB5CBFB> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Roto Brush.plugin/Contents/MacOS/SnapCut
                         0x123127000 -    0x123149fff +com.adobe.AfterEffects.TimePal (??? - ???) <19A6A96C-3154-FCE8-F269-16447EBD646C> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Time Palette.plugin/Contents/MacOS/TimePal
                         0x12315f000 -    0x1231a2fff +com.adobe.AfterEffects.ToolPal (??? - ???) <3A49C887-A43E-653A-A273-0EC125394D9D> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Tool Palette.plugin/Contents/MacOS/ToolPal
                         0x1231c3000 -    0x1231e3ffb +com.adobe.AfterEffects.TrackerPal (??? - ???) <76714712-25A3-18E9-920B-AF11957FE480> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Tracker Palette.plugin/Contents/MacOS/TrackerPal
                         0x1231f5000 -    0x123fc7ff7 +com.ImagineerSystems.mochashapeconverter4ae (1 - 1.0.0) <3C1F5D08-D515-9E24-35ED-CC76FCCA9675> /Applications/Adobe After Effects CS5/*/mocha shape converter for AE.plugin/Contents/MacOS/mochashapeconverter4ae
                         0x124194000 -    0x1241fafff +com.adobe.AfterEffects.AE_OpenGL (??? - ???) <D35E0572-FA2B-CFC9-C609-163C27847D3E> /Applications/Adobe After Effects CS5/*/AE_OpenGL.plugin/Contents/MacOS/AE_OpenGL
                         0x12420e000 -    0x124290ff3 +com.adobe.AfterEffects.FlashExporter (??? - ???) <0050C472-EF44-DFCC-C6F8-FDEB5AC68C45> /Applications/Adobe After Effects CS5/*/FlashExporter.plugin/Contents/MacOS/FlashExporter
                         0x1242bd000 -    0x12440efeb +com.adobe.AfterEffects.OpenEXR (??? - ???) <E570DDA8-8CD5-5C4B-A8EA-38B63E89231A> /Applications/Adobe After Effects CS5/*/OpenEXR.plugin/Contents/MacOS/OpenEXR
                         0x1250a7000 -    0x1250d7fff +com.adobe.AfterEffects.PNGIO (??? - ???) <E752B8F9-3C5C-5298-D7DD-298D6789C2D1> /Applications/Adobe After Effects CS5/*/PNGIO.plugin/Contents/MacOS/PNGIO
                         0x1250e3000 -    0x125198fff +com.adobe.AfterEffects.PremiereProImport (??? - ???) <BC46A6E8-0ED6-5151-EDE6-8EC4CF0F0E79> /Applications/Adobe After Effects CS5/*/PremiereProImport.plugin/Contents/MacOS/PremiereProImport
                         0x1251c5000 -    0x125233fff +com.adobe.MediaCore.Frameworks.UI (1.0 - 1.0) <20B843DF-2A79-ECAC-884D-8741419B5169> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
                         0x1252a4000 -    0x125300fff +com.adobe.AfterEffects.TIFFIO (??? - ???) <77C9C76E-661D-89F7-57BA-29760D6ED037> /Applications/Adobe After Effects CS5/*/TIFF.plugin/Contents/MacOS/TIFFIO
                         0x125310000 -    0x1253d4feb +com.adobe.AfterEffects.Vic (??? - ???) <E3FADC9D-839C-F345-5408-4609A3B8A810> /Applications/Adobe After Effects CS5/*/Vector Output.plugin/Contents/MacOS/Vic
                         0x12542b000 -    0x125444ff3 +com.adobe.AfterEffects.Align (??? - ???) <4105A2F0-0F6F-8C14-F4FE-EBC0BDBE5766> /Applications/Adobe After Effects CS5/*/Align.plugin/Contents/MacOS/Align
                         0x125453000 -    0x12546aff7 +com.adobe.AfterEffects.MetaPal (??? - ???) <FD0F4D64-006B-E3FC-53A0-144827EAFBDB> /Applications/Adobe After Effects CS5/*/MetaPal.plugin/Contents/MacOS/MetaPal
                         0x12547b000 -    0x1254a5fff +com.adobe.AfterEffects.Moka (??? - ???) <25EE9FE8-5466-C0B7-4C50-F6860D3C0894> /Applications/Adobe After Effects CS5/*/Moka.plugin/Contents/MacOS/Moka
                         0x1254b6000 -    0x1254caffb +com.adobe.AfterEffects.MotionSketch (??? - ???) <335C163D-4620-9962-9470-3A769AFB277C> /Applications/Adobe After Effects CS5/*/MotionSketch.plugin/Contents/MacOS/MotionSketch
                         0x1254d8000 -    0x12592cfff +com.adobe.AfterEffects.Scripting (??? - ???) <C677FC3B-CC5B-F4F9-FC1D-B86A34A139E5> /Applications/Adobe After Effects CS5/*/Scripting.plugin/Contents/MacOS/Scripting
                         0x125ab8000 -    0x125accffb +com.adobe.AfterEffects.Smoother (??? - ???) <06BE98C9-D40D-2BDE-4FD7-BB0BB6FF6916> /Applications/Adobe After Effects CS5/*/Smoother.plugin/Contents/MacOS/Smoother
                         0x125ada000 -    0x125af0ff3 +com.adobe.AfterEffects.Wiggler (??? - ???) <F6647999-5863-F5EB-B9D7-BBB73074C147> /Applications/Adobe After Effects CS5/*/Wiggler.plugin/Contents/MacOS/Wiggler
                         0x125b25000 -    0x125c22fff +com.adobe.AfterEffects.RefineMatte (??? - ???) <2732C788-BB29-A4EE-AE02-872F02FE5CCA> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/RefineMatte.plugin/Contents/MacOS/RefineMatte
                         0x12ba00000 -    0x12bb98ff7  GLEngine (??? - ???) <D770A837-9F8D-3C86-AB33-CBDEF5599CA2> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
                         0x12bbcc000 -    0x12bcc5fff  libGLProgrammability.dylib (??? - ???) <BCA0FD49-2103-33D8-8801-326C6A62465E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                         0x12bceb000 -    0x12bfb2ff7  com.apple.ATIRadeonX3000GLDriver (7.12.9 - 7.1.2) <E0D46EC5-2A19-36AA-AECC-A73219F999F1> /System/Library/Extensions/ATIRadeonX3000GLDriver.bundle/Contents/MacOS/ATIRadeonX3000GLD river
                         0x14e880000 -    0x14e89bfff  libJapaneseConverter.dylib (54.0.0 - compatibility 1.0.0) <489CAB2F-2854-3435-81CD-A062384016F7> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                         0x14e8a0000 -    0x14e8c1fff  libKoreanConverter.dylib (54.0.0 - compatibility 1.0.0) <32EBCCBC-E862-3888-8202-B01053FDFECA> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                         0x14e8c5000 -    0x14e8d4ff7  libSimplifiedChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <D5083346-BF48-325F-9399-06F4F9D7986C> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                         0x14e8d8000 -    0x14e8eaff7  libTraditionalChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <8F0BC42F-025B-3803-9C3E-FBD99199DFAA> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                         0x14e8ee000 -    0x14e8f7fff +FastCore (??? - ???) <4A676BFE-2C56-9651-EFF7-E804EC45C87F> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(AdobePSL)/extensions/FastCore.plugin/Contents/MacOS/FastCore
                         0x14eb00000 -    0x14ebdeffd +com.adobe.AfterEffects.Lens_Blur (??? - ???) <886D2B6A-0B9B-F0C9-8F12-A91904437A79> /Applications/Adobe After Effects CS5/*/Lens Blur.plugin/Contents/MacOS/Lens_Blur
                         0x14ec33000 -    0x14ec61ff3 +MMXCore (??? - ???) <0E398A83-FEBA-9272-4A07-04055F56EF16> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(AdobePSL)/extensions/MMXCore.plugin/Contents/MacOS/MMXCore
                         0x171473000 -    0x1714d4fef +com.mainconcept.mc_mfimport (8.5 - 8.5.0.14572) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/mc_mfimport.framework/Versions/8.5/mc_mfimport
                         0x171805000 -    0x171a26fef +libMXF_SDK_r.4.2.319.dylib (4.2.0 - compatibility 4.2.0) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_r.4.2.319.dylib
                         0x171bbd000 -    0x171bffff3 +libMXF_SDK_XML_r.4.2.319.dylib (4.2.0 - compatibility 4.2.0) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_XML_r.4.2.319.dylib
                         0x171c27000 -    0x171ef3ff6 +libxerces-c-3.0.dylib (??? - ???) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libxerces-c-3.0.dylib
                         0x172089000 -    0x17245efef +libxqilla.5.0.0.dylib (6.0.0 - compatibility 6.0.0) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libxqilla.5.0.0.dylib
                         0x172725000 -    0x17274efff +libMOG_Framework_r.2.0.8.dylib (2.0.8 - compatibility 2.0.8) <F686FD64-AF59-C0EA-F3E4-FA05E4144F73> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMOG_Framework_r.2.0.8.dylib
                         0x17279d000 -    0x172808ff0 +MultiProcessor Support (??? - ???) <101FF20A-2063-75D7-76FC-56974AFBAABE> /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(AdobePSL)/extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
                         0x172859000 -    0x1728c3fe7 +libMXF_SDK_Modules_r.1.1.34.dylib (1.1.0 - compatibility 1.1.0) /Applications/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/MOG/Frameworks/libMXF_SDK_Modules_r.1.1.34.dylib
                      0x7fff6d7bb000 - 0x7fff6d7efac7  dyld (195.5 - ???) <4A6E2B28-C7A2-3528-ADB7-4076B9836041> /usr/lib/dyld
                      0x7fff86b84000 - 0x7fff86d86fff  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <38CD6ED3-C8E4-3CCD-89AC-9C3198803101> /usr/lib/libicucore.A.dylib
                      0x7fff86d8d000 - 0x7fff86d93fff  libGFXShared.dylib (??? - ???) <343AE6C0-EB02-333C-8D35-DF6093B92758> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                      0x7fff86d94000 - 0x7fff86df6fff  com.apple.coreui (1.2.1 - 164.1) <F7972630-F696-3FC5-9FCF-A6E1C8771078> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                      0x7fff86df7000 - 0x7fff86eaafff  com.apple.CoreText (220.11.0 - ???) <4EA8E2DF-542D-38D5-ADB9-C0DAA73F898B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
                      0x7fff86eab000 - 0x7fff8711efff  com.apple.CoreImage (7.82 - 1.0.1) <282801B6-5D80-3E2C-88A4-00FE29906D5A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
                      0x7fff8711f000 - 0x7fff8711ffff  com.apple.Carbon (153 - 153) <E37A515C-4C10-3102-8146-C0FBD458F8CF> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                      0x7fff87120000 - 0x7fff87180fff  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <3A7521E6-5510-3FA7-AB65-79693A7A5839> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                      0x7fff87181000 - 0x7fff87188ff7  com.apple.CommerceCore (1.0 - 17) <AA783B87-48D4-3CA6-8FF6-0316396022F4> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                      0x7fff87189000 - 0x7fff872e2fff  com.apple.audio.toolbox.AudioToolbox (1.7.1 - 1.7.1) <4877267E-F736-3019-85D3-40A32A042A80> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                      0x7fff872e3000 - 0x7fff87607fff  com.apple.HIToolbox (1.8 - ???) <A3BE7C59-52E6-3A7F-9B30-24B7DD3E95F2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                      0x7fff87608000 - 0x7fff8760dfff  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <98ECD5F6-E85C-32A5-98CD-8911230CB66A> /usr/lib/system/libcompiler_rt.dylib
                      0x7fff8760e000 - 0x7fff87625fff  com.apple.CFOpenDirectory (10.7 - 144) <9709423E-8484-3B26-AAE8-EF58D1B8FB3F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                      0x7fff87626000 - 0x7fff87626fff  com.apple.audio.units.AudioUnit (1.7.1 - 1.7.1) <04C10813-CCE5-3333-8C72-E8E35E417B3B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                      0x7fff87627000 - 0x7fff87627fff  com.apple.vecLib (3.7 - vecLib 3.7) <9A58105C-B36E-35B5-812C-4ED693F2618F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                      0x7fff8766f000 - 0x7fff87d82587  com.apple.CoreGraphics (1.600.0 - ???) <A9F2451E-6F60-350E-A6E5-539669B53074> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                      0x7fff87d83000 - 0x7fff87debff7  com.apple.audio.CoreAudio (4.0.1 - 4.0.1) <7966E3BE-376B-371A-A21D-9BD763C0BAE7> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                      0x7fff87dfe000 - 0x7fff87f37fef  com.apple.vImage (5.1 - 5.1) <EB634387-CD15-3246-AC28-5FB368ACCEA2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                      0x7fff87f8c000 - 0x7fff87f9afff  com.apple.NetAuth (1.0 - 3.0) <F384FFFD-70F6-3B1C-A886-F5B446E456E7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                      0x7fff87f9b000 - 0x7fff8803ffef  com.apple.ink.framework (1.3.2 - 110) <F69DBD44-FEC8-3C14-8131-CC0245DBBD42> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                      0x7fff883e1000 - 0x7fff886b9ff7  com.apple.security (7.0 - 55010) <93713FF4-FE86-3B4C-8150-5FCC7F3320C8> /System/Library/Frameworks/Security.framework/Versions/A/Security
                      0x7fff886c9000 - 0x7fff886cbfff  libCVMSPluginSupport.dylib (??? - ???) <61D89F3C-C64D-3733-819F-8AAAE4E2E993> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                      0x7fff886cc000 - 0x7fff886e9fff  libPng.dylib (??? - ???) <3C70A94C-9442-3E11-AF51-C1B0EF81680E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
                      0x7fff886ea000 - 0x7fff88765ff7  com.apple.print.framework.PrintCore (7.1 - 366.1) <3F140DEB-9F87-3672-97CC-F983752581AC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                      0x7fff88766000 - 0x7fff887a0fff  com.apple.DebugSymbols (2.1 - 85) <AEF473A5-25BF-3FB7-9A07-320D9CB85959> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                      0x7fff887d2000 - 0x7fff887f8ff7  com.apple.framework.familycontrols (3.0 - 300) <41A6DFC2-EAF5-390A-83A1-C8832528705C> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                      0x7fff887f9000 - 0x7fff887fbff7  com.apple.print.framework.Print (7.1 - 247.1) <8A4925A5-BAA3-373C-9B5D-03E0270C6B12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                      0x7fff88837000 - 0x7fff8884dfff  libGL.dylib (??? - ???) <6A473BF9-4D35-34C6-9F8B-86B68091A9AF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                      0x7fff89120000 - 0x7fff89140fff  libsystem_kernel.dylib (1699.22.81 - compatibility 1.0.0) <B9E259FC-73EA-31E3-8E68-7F980DEBA8A6> /usr/lib/system/libsystem_kernel.dylib
                      0x7fff89141000 - 0x7fff89160fff  libresolv.9.dylib (46.0.0 - compatibility 1.0.0) <33263568-E6F3-359C-A4FA-66AD1300F7D4> /usr/lib/libresolv.9.dylib
                      0x7fff89203000 - 0x7fff89230fe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <095FDD3C-3961-3865-A59B-A5B0A4B8B923> /usr/lib/libSystem.B.dylib
                      0x7fff89231000 - 0x7fff8923ffff  libdispatch.dylib (187.7.0 - compatibility 1.0.0) <712AAEAC-AD90-37F7-B71F-293FF8AE8723> /usr/lib/system/libdispatch.dylib
                      0x7fff892c8000 - 0x7fff8935eff7  libvMisc.dylib (325.4.0 - compatibility 1.0.0) <642D8D54-F9F5-3FBB-A96C-EEFE94C6278B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                      0x7fff893cd000 - 0x7fff893d6ff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <A4D651E3-D1C6-3934-AD49-7A104FD14596> /usr/lib/system/libsystem_notify.dylib
                      0x7fff894b6000 - 0x7fff894bcfff  libmacho.dylib (800.0.0 - compatibility 1.0.0) <D86F63EC-D2BD-32E0-8955-08B5EAFAD2CC> /usr/lib/system/libmacho.dylib
                      0x7fff89bf2000 - 0x7fff89bf7ff7  libsystem_network.dylib (??? - ???) <5DE7024E-1D2D-34A2-80F4-08326331A75B> /usr/lib/system/libsystem_network.dylib
                      0x7fff89bf8000 - 0x7fff89c92ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <4E70C394-773E-3A4B-A93C-59A88ABA9509> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                      0x7fff89c93000 - 0x7fff89d70fef  libsystem_c.dylib (763.12.0 - compatibility 1.0.0) <FF69F06E-0904-3C08-A5EF-536FAFFFDC22> /usr/lib/system/libsystem_c.dylib
                      0x7fff89e02000 - 0x7fff89e2aff7  com.apple.CoreVideo (1.7 - 70.1) <98F917B2-FB53-3EA3-B548-7E97B38309A7> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                      0x7fff89e40000 - 0x7fff89e40fff  com.apple.Accelerate (1.7 - Accelerate 1.7) <82DDF6F5-FBC3-323D-B71D-CF7ABC5CF568> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                      0x7fff89e41000 - 0x7fff89e41fff  com.apple.CoreServices (53 - 53) <043C8026-8EDD-3241-B090-F589E24062EF> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                      0x7fff89e5b000 - 0x7fff89edefef  com.apple.Metadata (10.7.0 - 627.20) <E00156B0-663A-35EF-A307-A2CEB00F1845> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                      0x7fff89f68000 - 0x7fff89fa7ff7  libGLImage.dylib (??? - ???) <2D1D8488-EC5F-3229-B983-CFDE0BB37586> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                      0x7fff89fa8000 - 0x7fff89fa9fff  libdnsinfo.dylib (395.6.0 - compatibility 1.0.0) <718A135F-6349-354A-85D5-430B128EFD57> /usr/lib/system/libdnsinfo.dylib
                      0x7fff8a15f000 - 0x7fff8a15ffff  com.apple.ApplicationServices (41 - 41) <03F3FA8F-8D2A-3AB6-A8E3-40B001116339> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                      0x7fff8a160000 - 0x7fff8a163fff  libRadiance.dylib (??? - ???) <CD89D70D-F177-3BAE-8A26-644EA7D5E28E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
                      0x7fff8a164000 - 0x7fff8a197ff7  com.apple.GSS (2.1 - 2.0) <9A2C9736-DA10-367A-B376-2C7A584E6C7A> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                      0x7fff8a198000 - 0x7fff8a1a3ff7  com.apple.speech.recognition.framework (4.0.19 - 4.0.19) <7ADAAF5B-1D78-32F2-9FFF-D2E3FBB41C2B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                      0x7fff8a1a4000 - 0x7fff8a1a5ff7  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <8BCA214A-8992-34B2-A8B9-B74DEACA1869> /usr/lib/system/libsystem_blocks.dylib
                      0x7fff8a1a6000 - 0x7fff8a1c2ff7  com.apple.GenerationalStorage (1.0 - 125) <31F60175-E38D-3C63-8D95-32CFE7062BCB> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                      0x7fff8a1cb000 - 0x7fff8a1cdfff  libquarantine.dylib (36.0.0 - compatibility 1.0.0) <4C3BFBC7-E592-3939-B376-1C2E2D7C5389> /usr/lib/system/libquarantine.dylib
                      0x7fff8a1db000 - 0x7fff8a2e0ff7  libFontParser.dylib (??? - ???) <B9A53808-C97E-3293-9C33-1EA9D4E83EC8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                      0x7fff8a2e1000 - 0x7fff8a3c5def  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <C5F2392D-B481-3A9D-91BE-3D039FFF4DEC> /usr/lib/libobjc.A.dylib
                      0x7fff8a450000 - 0x7fff8a493ff7  libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <2B1571E1-8E87-364E-BC36-C9C9B5D3EAC4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
                      0x7fff8a87c000 - 0x7fff8a87ffff  libCoreVMClient.dylib (??? - ???) <E034C772-4263-3F48-B083-25A758DD6228> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                      0x7fff8a880000 - 0x7fff8a8a7fff  com.apple.PerformanceAnalysis (1.10 - 10) <2A058167-292E-3C3A-B1F8-49813336E068> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                      0x7fff8a8a8000 - 0x7fff8a8aefff  IOSurface (??? - ???) <2114359C-D839-3855-8735-BBAA2704DB93> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                      0x7fff8a8af000 - 0x7fff8a8f0fff  com.apple.QD (3.12 - ???) <4F3C5629-97C7-3E55-AF3C-ACC524929DA2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                      0x7fff8b62d000 - 0x7fff8b6cfff7  com.apple.securityfoundation (5.0 - 55005) <0D59908C-A61B-389E-AF37-741ACBBA6A94> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                      0x7fff8b80d000 - 0x7fff8b812fff  com.apple.OpenDirectory (10.7 - 146) <91A87249-6A2F-3F89-A8DE-0E95C0B54A3A> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                      0x7fff8b84d000 - 0x7fff8b87aff7  com.apple.opencl (1.50.63 - 1.50.63) <DB335C5C-3ABD-38C8-B6A5-8436EE1484D3> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                      0x7fff8baf7000 - 0x7fff8bafcfff  libGIF.dylib (??? - ???) <393E2DB5-9479-39A6-A75A-B5F20B852532> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
                      0x7fff8c145000 - 0x7fff8c149fff  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <FF83AFF7-42B2-306E-90AF-D539C51A4542> /usr/lib/system/libmathCommon.A.dylib
                      0x7fff8c262000 - 0x7fff8c2d0fff  com.apple.CoreSymbolication (2.1 - 66) <E1582596-4157-3535-BF1F-3BAE92A0B09F> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                      0x7fff8c2d1000 - 0x7fff8c2d2ff7  libremovefile.dylib (21.0.0 - compatibility 1.0.0) <C6C49FB7-1892-32E4-86B5-25AD165131AA> /usr/lib/system/libremovefile.dylib
                      0x7fff8c2d3000 - 0x7fff8c33dfff  com.apple.framework.IOKit (2.0 - ???) <87D55F1D-CDB5-3D13-A5F9-98EA4E22F8EE> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                      0x7fff8c33e000 - 0x7fff8c512fff  com.apple.CoreFoundation (6.7.1 - 635.15) <FE4A86C2-3599-3CF8-AD1A-822F1FEA820F> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                      0x7fff8c584000 - 0x7fff8c58bfff  libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <172B1985-F24A-34E9-8D8B-A2403C9A0399> /usr/lib/system/libcopyfile.dylib
                      0x7fff8c58c000 - 0x7fff8c7a6fef  com.apple.CoreData (104 - 358.12) <33B1FA75-7970-3751-9DCC-FF809D3E1FA2> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                      0x7fff8c895000 - 0x7fff8c919ff7  com.apple.ApplicationServices.ATS (317.5.0 - ???) <FE629F2D-6BC0-3A58-9844-D8B9A6808A00> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                      0x7fff8c91c000 - 0x7fff8c98cfff  com.apple.datadetectorscore (3.0 - 179.4) <2A822A13-94B3-3A43-8724-98FDF698BB12> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                      0x7fff8c98d000 - 0x7fff8cdbafff  libLAPACK.dylib (??? - ???) <4F2E1055-2207-340B-BB45-E4F16171EE0D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                      0x7fff8cdc5000 - 0x7fff8cde2ff7  libxpc.dylib (77.17.0 - compatibility 1.0.0) <72A16104-2F23-3C22-B474-1953F06F9376> /usr/lib/system/libxpc.dylib
                      0x7fff8cde7000 - 0x7fff8cdebfff  libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <5EEAD17D-006C-3855-8093-C7A4A97EE0D0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
                      0x7fff8ceea000 - 0x7fff8d4cefff  libBLAS.dylib (??? - ???) <C34F6D88-187F-33DC-8A68-C0C9D1FA36DF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                      0x7fff8d612000 - 0x7fff8d624ff7  libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <6245B497-784B-355C-98EF-2DC6B45BF05C> /usr/lib/libsasl2.2.dylib
                      0x7fff8d6a8000 - 0x7fff8d6d3ff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <8051A3FC-7385-3EA9-9634-78FC616C3E94> /usr/lib/libxslt.1.dylib
                      0x7fff8d6fd000 - 0x7fff8d800fff  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <7F60B0FF-4946-3639-89AB-B540D318B249> /usr/lib/libsqlite3.dylib
                      0x7fff8d863000 - 0x7fff8d944fff  com.apple.CoreServices.OSServices (478.29 - 478.29) <B487110E-C942-33A8-A494-3BDEDB88B1CD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                      0x7fff8d97b000 - 0x7fff8d980fff  libcache.dylib (47.0.0 - compatibility 1.0.0) <B7757E2E-5A7D-362E-AB71-785FE79E1527> /usr/lib/system/libcache.dylib
                      0x7fff8d981000 - 0x7fff8d982fff  libDiagnosticMessagesClient.dylib (??? - ???) <3DCF577B-F126-302B-BCE2-4DB9A95B8598> /usr/lib/libDiagnosticMessagesClient.dylib
                      0x7fff8d983000 - 0x7fff8d98eff7  libc++abi.dylib (14.0.0 - compatibility 1.0.0) <8FF3D766-D678-36F6-84AC-423C878E6D14> /usr/lib/libc++abi.dylib
                      0x7fff8d9ce000 - 0x7fff8d9d1fff  com.apple.help (1.3.2 - 42) <AB67588E-7227-3993-927F-C9E6DAC507FD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                      0x7fff8d9d2000 - 0x7fff8d9fbfff  com.apple.CoreServicesInternal (113.8 - 113.8) <C1A3CF1B-BC45-3FC6-82B3-1511EBBA9D51> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                      0x7fff8d9fc000 - 0x7fff8da71ff7  libc++.1.dylib (19.0.0 - compatibility 1.0.0) <C0EFFF1B-0FEB-3F99-BE54-506B35B555A9> /usr/lib/libc++.1.dylib
                      0x7fff8da72000 - 0x7fff8db11fff  com.apple.LaunchServices (480.21 - 480.21) <6BFADEA9-5BC1-3B53-A013-488EB7F1AB57> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                      0x7fff8db83000 - 0x7fff8dbd6fff  libFontRegistry.dylib (??? - ???) <57FBD85F-41A6-3DB9-B5F4-FCC6B260F1AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                      0x7fff8dc76000 - 0x7fff8dcd2fff  com.apple.QuickLookFramework (3.1 - 500.1) <0C9E98D2-D8F9-3161-9809-0D77B98AD938> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                      0x7fff8dcd7000 - 0x7fff8dff3ff7  com.apple.CoreServices.CarbonCore (960.18 - 960.18) <6020C3FB-6125-3EAE-A55D-1E77E38BEDEA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                      0x7fff8dff4000 - 0x7fff8dff5fff  libunc.dylib (24.0.0 - compatibility 1.0.0) <C67B3B14-866C-314F-87FF-8025BEC2CAAC> /usr/lib/system/libunc.dylib
                      0x7fff8dff6000 - 0x7fff8e102fff  libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <3A8E1F89-5E26-3C8B-B538-81F5D61DBF8A> /usr/lib/libcrypto.0.9.8.dylib
                      0x7fff8e14d000 - 0x7fff8e151ff7  com.apple.CommonPanels (1.2.5 - 94) <0BB2C436-C9D5-380B-86B5-E355A7711259> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                      0x7fff8e152000 - 0x7fff8e247fff  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <5C40E880-0706-378F-B864-3C2BD922D926> /usr/lib/libiconv.2.dylib
                      0x7fff8e257000 - 0x7fff8e36fff7  com.apple.DesktopServices (1.6.1 - 1.6.1) <4418EAA6-7163-3A77-ABD3-F8289796C81A> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                      0x7fff8e458000 - 0x7fff8e498ff7  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <B7173CA4-CE16-3BAB-8D83-185FCEFA15F5> /usr/lib/libcups.2.dylib
                      0x7fff8e596000 - 0x7fff8e59bfff  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <D952F17B-200A-3A23-B9B2-7C1F7AC19189> /usr/lib/libpam.2.dylib
                      0x7fff8e59c000 - 0x7fff8e59dfff  libsystem_sandbox.dylib (??? - ???) <8D14139B-B671-35F4-9E5A-023B4C523C38> /usr/lib/system/libsystem_sandbox.dylib
                      0x7fff8e59e000 - 0x7fff8e5a0fff  com.apple.TrustEvaluationAgent (2.0 - 1) <1F31CAFF-C1C6-33D3-94E9-11B721761DDF> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                      0x7fff8e5a1000 - 0x7fff8e5e1fff  libtidy.A.dylib (??? - ???) <E500CDB9-C010-3B1A-B995-774EE64F39BE> /usr/lib/libtidy.A.dylib
                      0x7fff8e5e2000 - 0x7fff8e5e9fff  com.apple.NetFS (4.0 - 4.0) <B9F41443-679A-31AD-B0EB-36557DAF782B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                      0x7fff8e5ea000 - 0x7fff8e6ecff7  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <D46F371D-6422-31B7-BCE0-D80713069E0E> /usr/lib/libxml2.2.dylib
                      0x7fff8e6f2000 - 0x7fff8e708ff7  com.apple.ImageCapture (7.0 - 7.0) <69E6E2E1-777E-332E-8BCF-4F0611517DD0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                      0x7fff8e719000 - 0x7fff8e72efff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <C061ECBB-7061-3A43-8A18-90633F943295> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                      0x7fff8e72f000 - 0x7fff8e758fff  libJPEG.dylib (??? - ???) <64D079F9-256A-323B-A837-84628B172F21> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
                      0x7fff8e775000 - 0x7fff8e783ff7  libkxld.dylib (??? - ???) <9C937433-A362-3E40-BF71-FDABA986B56C> /usr/lib/system/libkxld.dylib
                      0x7fff8e7c5000 - 0x7fff8eadeff7  com.apple.Foundation (6.7.1 - 833.20) <D922F590-FDA6-3D89-A271-FD35E2290624> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                      0x7fff8eadf000 - 0x7fff8eaeeff7  com.apple.opengl (1.7.5 - 1.7.5) <2945F1A6-910C-3596-9988-5701B04BD821> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                      0x7fff8eaef000 - 0x7fff8ec8efff  com.apple.QuartzCore (1.7 - 270.0) <E8FC9AA4-A5CB-384B-AD29-7190A1387D3E> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                      0x7fff8ecb7000 - 0x7fff8ed2afff  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <6BDD43E4-A4B1-379E-9ED5-8C713653DFF2> /usr/lib/libstdc++.6.dylib
                      0x7fff8ed2b000 - 0x7fff8ed33fff  libsystem_dnssd.dylib (??? - ???) <407A48F3-64A0-348B-88E6-70CECD3D0D67> /usr/lib/system/libsystem_dnssd.dylib
                      0x7fff8ed34000 - 0x7fff8ed98fff  com.apple.Symbolication (1.2 - 83.1) <0C6F8907-6829-3409-99AC-ACC62923DE98> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                      0x7fff8edaa000 - 0x7fff8ee2fff7  com.apple.Heimdal (2.1 - 2.0) <C92E327E-CB5F-3C9B-92B0-F1680095C8A3> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                      0x7fff8ee3d000 - 0x7fff8ee41fff  libdyld.dylib (195.5.0 - compatibility 1.0.0) <F1903B7A-D3FF-3390-909A-B24E09BAD1A5> /usr/lib/system/libdyld.dylib
                      0x7fff8efae000 - 0x7fff8effcfff  libauto.dylib (??? - ???) <D8AC8458-DDD0-3939-8B96-B6CED81613EF> /usr/lib/libauto.dylib
                      0x7fff8f041000 - 0x7fff8f044ff7  com.apple.securityhi (4.0 - 1) <B37B8946-BBD4-36C1-ABC6-18EDBC573F03> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                      0x7fff8f0a4000 - 0x7fff8f512fff  com.apple.RawCamera.bundle (3.8.2 - 579) <3D4EBC1A-4139-3E22-B407-0D4887D8D208> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                      0x7fff8f5fc000 - 0x7fff8f635fe7  libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <79AAEC98-1258-3DA4-B1C0-4120049D390B> /usr/lib/libssl.0.9.8.dylib
                      0x7fff8fb6c000 - 0x7fff8fb72ff7  libunwind.dylib (30.0.0 - compatibility 1.0.0) <1E9C6C8C-CBE8-3F4B-A5B5-E03E3AB53231> /usr/lib/system/libunwind.dylib
                      0x7fff8fb73000 - 0x7fff8fb8afff  com.apple.MultitouchSupport.framework (220.62.1 - 220.62.1) <F21C79C0-4B5A-3645-81A6-74F8EFA900CE> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                      0x7fff90378000 - 0x7fff9043fff7  ColorSyncDeprecated.dylib (4.6.0 - compatibility 1.0.0) <B3E00682-FD14-30C3-AE7D-2B16655AD469> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
                      0x7fff90485000 - 0x7fff904c0fff  com.apple.LDAPFramework (3.0 - 120.1) <0C23534F-A8E7-3144-B2B2-50F9875101E2> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                      0x7fff904d3000 - 0x7fff9099afff  FaceCoreLight (1.4.7 - compatibility 1.0.0) <E9D2A69C-6E81-358C-A162-510969F91490> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
                      0x7fff9099b000 - 0x7fff909a1fff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <CEA34337-63DE-302E-81AA-10D717E1F699> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                      0x7fff909a2000 - 0x7fff909b6ff7  com.apple.LangAnalysis (1.7.0 - 1.7.0) <04C31EF0-912A-3004-A08F-CEC27030E0B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                      0x7fff90c43000 - 0x7fff90c43fff  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <61EFED6A-A407-301E-B454-CD18314F0075> /usr/lib/system/libkeymgr.dylib
                      0x7fff90c44000 - 0x7fff90c86ff7  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <A5B9778E-11C3-3F61-B740-1F2114E967FB> /usr/lib/system/libcommonCrypto.dylib
                      0x7fff90c87000 - 0x7fff90cdefff  libTIFF.dylib (??? - ???) <FF0D9A24-6956-3F03-81EA-3EEAD22C9DB8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
                      0x7fff90eb8000 - 0x7fff90ecaff7  libz.1.dylib (1.2.5 - compatibility 1.0.0) <30CBEF15-4978-3DED-8629-7109880A19D4> /usr/lib/libz.1.dylib
                      0x7fff90f63000 - 0x7fff90f75ff7  libbsm.0.dylib (??? - ???) <349BB16F-75FA-363F-8D98-7A9C3FA90A0D> /usr/lib/libbsm.0.dylib
                      0x7fff90f76000 - 0x7fff91083fff  libJP2.dylib (??? - ???) <6052C973-9354-35CB-AAB9-31D00D8786F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJP2.dylib
                      0x7fff91084000 - 0x7fff910b4ff7  com.apple.DictionaryServices (1.2.1 - 158.2) <3FC86118-7553-38F7-8916-B329D2E94476> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                      0x7fff910b5000 - 0x7fff91110ff7  com.apple.HIServices (1.10 - ???) <BAB8B422-7047-3D2D-8E0A-13FCF153E4E7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                      0x7fff91111000 - 0x7fff91135ff7  com.apple.RemoteViewServices (1.2 - 39) <862849C8-84C1-32A1-B87E-B29E74778C9F> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                      0x7fff9155d000 - 0x7fff9215eff7  com.apple.AppKit (6.7.2 - 1138.23) <5CD2C850-4F52-3BA2-BA11-3107DFD2D23C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                      0x7fff9217e000 - 0x7fff921b9ff7  libsystem_info.dylib (??? - ???) <9C8C2DCB-96DB-3471-9DCE-ADCC26BE2DD4> /usr/lib/system/libsystem_info.dylib
                      0x7fff9220b000 - 0x7fff9222ffff  com.apple.Kerberos (1.0 - 1) <1F826BCE-DA8F-381D-9C4C-A36AA0EA1CB9> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                      0x7fff92230000 - 0x7fff92284ff7  com.apple.ScalableUserInterface (1.0 - 1) <1873D7BE-2272-31A1-8F85-F70C4D706B3B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterfa ce.framework/Versions/A/ScalableUserInterface
                      0x7fff92398000 - 0x7fff92398fff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <C06A140F-6114-3B8B-B080-E509303145B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                      0x7fff92399000 - 0x7fff92460ff7  com.apple.ColorSync (4.7.0 - 4.7.0) <F325A9D7-7203-36B7-8C1C-B6A4D5CC73A8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                      0x7fff9248b000 - 0x7fff925f1fff  com.apple.CFNetwork (520.2.5 - 520.2.5) <406712D9-3F0C-3763-B4EB-868D01F1F042> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
                      0x7fff925f2000 - 0x7fff92644ff7  libGLU.dylib (??? - ???) <3C9153A0-8499-3DC0-AAA4-9FA6E488BE13> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                      0x7fff92645000 - 0x7fff9268bff7  libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <EAF61ADC-DC00-34CE-B23E-7238ED54E31D> /usr/lib/libcurl.4.dylib
                      0x7fff9268c000 - 0x7fff9276afff  com.apple.ImageIO.framework (3.1.1 - 3.1.1) <13E549F8-5BD6-3BAE-8C33-1D0BD269C081> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
                      0x7fff9276b000 - 0x7fff9276bfff  com.apple.Cocoa (6.6 - ???) <021D4214-9C23-3CD8-AFB2-F331697A4508> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                      0x7fff9276c000 - 0x7fff927b7ff7  com.apple.SystemConfiguration (1.11.1 - 1.11) <F832FE21-5509-37C6-B1F1-48928F31BE45> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                      0x7fff927b8000 - 0x7fff927d5ff7  com.apple.openscripting (1.3.3 - ???) <A64205E6-D3C5-3E12-B1A0-72243151AF7D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                      0x7fff927d6000 - 0x7fff927e1fff  com.apple.CommonAuth (2.1 - 2.0) <BFDD0A8D-4BEA-39EC-98B3-2E083D7B1ABD> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                      0x7fff927e2000 - 0x7fff927ecff7  liblaunch.dylib (392.18.0 - compatibility 1.0.0) <39EF04F2-7F0C-3435-B785-BF283727FFBD> /usr/lib/system/liblaunch.dylib
                      0x7fff92800000 - 0x7fff92801fff  liblangid.dylib (??? - ???) <CACBE3C3-2F7B-3EED-B50E-EDB73F473B77> /usr/lib/liblangid.dylib
                      0x7fff92c7d000 - 0x7fff92c90ff7  libCRFSuite.dylib (??? - ???) <034D4DAA-63F0-35E4-BCEF-338DD7A453DD> /usr/lib/libCRFSuite.dylib
                      0x7fff930c4000 - 0x7fff930d1fff  libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <931F40EB-CA75-3A90-AC97-4DB8E210BC76> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
                      0x7fff93157000 - 0x7fff93196fff  com.apple.AE (527.7 - 527.7) <B82F7ABC-AC8B-3507-B029-969DD5CA813D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                      External Modification Summary:
                        Calls made by other processes targeting this process:
                      task_for_pid: 20
                      thread_create: 0
                      thread_set_state: 0
                        Calls made by this process:
                      task_for_pid: 0
                      thread_create: 0
                      thread_set_state: 0
                        Calls made by all processes on this machine:
                      task_for_pid: 1002
                      thread_create: 0
                      thread_set_state: 0
                      VM Region Summary:
                      ReadOnly portion of Libraries: Total=377.2M resident=309.4M(82%) swapped_out_or_unallocated=67.8M(18%)
                      Writable regions: Total=3.7G written=2.6G(71%) resident=2.7G(71%) swapped_out=0K(0%) unallocated=1.1G(29%)
                      REGION TYPE                  VIRTUAL
                      ATS (font support)             33.4M
                      CG shared images                136K
                      CoreGraphics                     16K
                      CoreServices                   1576K
                      IOKit                           308K
                      IOKit (reserved)              512.0M    reserved VM address space (unallocated)
                      MALLOC                        386.1M
                      MALLOC guard page                32K
                      Memory tag=240                    4K
                      Memory tag=242                   12K
                      STACK GUARD                    56.3M
                      Stack                         127.1M
                      VM_ALLOCATE                     2.7G
                      __CI_BITMAP                      80K
                      __DATA                         45.5M
                      __IMAGE                        1256K
                      __LINKEDIT                    109.2M
                      __TEXT                        268.0M
                      __UNICODE                       544K
                      mapped file                    19.2M
                      shared memory                   416K
                      TOTAL                           4.2G
                      TOTAL, minus reserved VM space  3.7G
                      System Profile:
                      Model: MacPro5,1, BootROM MP51.007F.B03, 12 processors, 6-Core Intel Xeon, 2.93 GHz, 64 GB, SMC 1.39f11
                      Graphics: NVIDIA Quadro 4000, NVIDIA Quadro 4000, PCIe, 2048 MB
                      Memory Module: DIMM 1, 8 GB, DDR3 ECC, 1333 MHz, 0x80AD, 0x484D54333147523742465234432D48392020
                      Memory Module: DIMM 2, 8 GB, DDR3 ECC, 1333 MHz, 0x80AD, 0x484D54333147523742465234432D48392020
                      Memory Module: DIMM 3, 8 GB, DDR3 ECC, 1333 MHz, 0x80AD, 0x484D54333147523742465234432D48392020
                      Memory Module: DIMM 4, 8 GB, DDR3 ECC, 1333 MHz, 0x80AD, 0x484D54333147523742465234432D48392020
                      Memory Module: DIMM 5, 8 GB, DDR3 ECC, 1333 MHz, 0x80AD, 0x484D54333147523742465234432D48392020
                      Memory Module: DIMM 6, 8 GB, DDR3 ECC, 1333 MHz, 0x80AD, 0x484D54333147523742465234432D48392020
                      Memory Module: DIMM 7, 8 GB, DDR3 ECC, 1333 MHz, 0x80AD, 0x484D54333147523742465234432D48392020
                      Memory Module: DIMM 8, 8 GB, DDR3 ECC, 1333 MHz, 0x80AD, 0x484D54333147523742465234432D48392020
                      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.100.98.75.18)
                      Bluetooth: Version 4.0.1f4, 2 service, 18 devices, 1 incoming serial ports
                      Network Service: Ethernet 2, Ethernet, en1
                      PCI Card: NVIDIA Quadro 4000, sppci_displaycontroller, Slot-3
                      PCI Card: NVIDIA Quadro 4000, NVDA,Parent, Slot-3
                      PCI Card: Apple RAID Card, sppci_raid, Slot-4
                      Serial ATA Device: HL-DT-ST DVD-RW GH41N
                      USB Device: hub_device, apple_vendor_id, 0x9126, 0xfa200000 / 2
                      USB Device: Display iSight, apple_vendor_id, 0x8508, 0xfa250000 / 5
                      USB Device: Apple LED Cinema Display, apple_vendor_id, 0x9226, 0xfa260000 / 4
                      USB Device: Display Audio, apple_vendor_id, 0x1105, 0xfa240000 / 3
                      USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfd100000 / 2
                      USB Device: Apple Optical USB Mouse, apple_vendor_id, 0x0304, 0xfd130000 / 4
                      USB Device: Apple Keyboard, apple_vendor_id, 0x0220, 0xfd120000 / 3
                      USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x5a100000 / 2
                      USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0x5a110000 / 5
                      FireWire Device: built-in_hub, 800mbit_speed
