8 Replies Latest reply on Jan 25, 2012 3:08 PM by pofo401k
    Footer problem...IE (Internet Explorer)
    pofo401k
      Ok in older internet explorer and fire fox the footer for some reason kick lower then where it should be and i dont know why. http://douglaspaquette.mivamerchant.net/website/douglaspaquette.html.. this is the page.
      why one know why?
      css:
      /* SpryMenuBarHorizontal.css - version 0.6 - Spry Pre-Release 1.6.1 */
      /* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
      LAYOUT INFORMATION: describes box model, positioning, z-order
      /* The outermost container of the Menu Bar, an auto width box with no margin or padding */
      ul.MenuBarHorizontal
                list-style-type: none;
                font-size: 105%;
                cursor: default;
                width: auto;
                margin-top: -32px;
                margin-right: 0%;
                margin-bottom: 0px;
                margin-left: 5em;
                height: auto;
                float: left;
                border-bottom-style: none;
                font-weight: normal;
                line-height: normal;
                font-style: normal;
                color: #000;
                padding-top: 0px;
                padding-right: 0%;
                padding-bottom: 0px;
                padding-left: 0%;
                text-align: center;
                border-top-style: none;
                border-right-style: none;
                border-left-style: none;
      /* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
      ul.MenuBarActive
                z-index: 1000;
      /* Menu item containers, position children relative to this container and are a fixed width */
      ul.MenuBarHorizontal li
                padding: 0;
                font-size: 100%;
                position: relative;
                text-align: center;
                cursor: pointer;
                width: auto;
                float: left;
                margin-top: 10px;
                margin-right: 0;
                margin-bottom: 0;
                margin-left: 0;
                visibility: inherit;
      /* Submenus should appear below their parent (top: 0) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
      ul.MenuBarHorizontal ul
                margin: 0;
                padding: 0;
                font-size: 110%;
                z-index: 1020;
                cursor: default;
                width: 12em;
                position: absolute;
                left: -1000em;
      /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to auto so it comes onto the screen below its parent menu item */
      ul.MenuBarHorizontal ul.MenuBarSubmenuVisible
                left: auto;
                -khtml-opacity: 0.9;
                background-color: #666;
      /* Menu item containers are same fixed width as parent */
      ul.MenuBarHorizontal ul li
                width: 11em;
      /* Submenus should appear slightly overlapping to the right (95%) and up (-5%) */
      ul.MenuBarHorizontal ul ul
                position: absolute;
                margin-right: 0;
                margin-bottom: 0;
                width: 12em;
                margin-left: 12em;
      /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
      ul.MenuBarHorizontal ul.MenuBarSubmenuVisible ul.MenuBarSubmenuVisible
                left: auto;
                top: 0;
      DESIGN INFORMATION: describes color scheme, borders, fonts
      /* Submenu containers have borders on all sides */
                border: 1.5px solid #fff;
                font-size: 12px;
                padding-top: 0px;
      /* Menu items are a light gray block with padding and no text decoration */
      ul.MenuBarHorizontal a
                display: block;
                cursor: auto;
                background-color: opacity
      :0.4;
                color: #FFFFFF;
                text-decoration: none;
                font-size: 100%;
                padding-top: 0em;
                padding-right: 2em;
                padding-bottom: 0em;
                padding-left: 0em;
      /* Menu items that have mouse over or focus have a blue background and white text */
      ul.MenuBarHorizontal a:hover, ul.MenuBarHorizontal a:focus
                color: #F69;
                background-color: transparent;
      /* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
      ul.MenuBarHorizontal a.MenuBarItemHover, ul.MenuBarHorizontal a.MenuBarItemSubmenuHover, ul.MenuBarHorizontal a.MenuBarSubmenuVisible
                color: #FF6699;
      SUBMENU INDICATION: styles if there is a submenu under a given menu item
      /* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
                background-image: url(SpryMenuBarDown.gif);
                background-repeat: no-repeat;
                background-position: 95% 50%;
      ul.MenuBarHorizontal ul a.MenuBarItemSubmenu
                background-image: url(SpryMenuBarRight.gif);
      /* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a "hover" background image positioned on the far left (95%) and centered vertically (50%) */
                background-image: url(SpryMenuBarDownHover.gif);
      ul.MenuBarHorizontal ul a.MenuBarItemSubmenuHover
                background-image: url(SpryMenuBarRightHover.gif);
      BROWSER HACKS: the hacks below should not be changed unless you are an expert
      /* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
      ul.MenuBarHorizontal iframe
      position: absolute;
      z-index: 1010;
      /* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
      ul.MenuBarHorizontal li.MenuBarItemIE
                display: inline;
                f\loat: left;
                background-color: #FFF;
                filter:alpha(opacity=0);
                /* [disabled]-moz-opacity:0.; */
                -khtml-opacity: 0.;
                opacity: 0.;
      html:
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      <html xmlns="http://www.w3.org/1999/xhtml">
      <head>
      <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
      <title>Douglas Paquette</title>
      <style type="text/css">
      body {
                margin: 0;
                padding: 0;
                color: #000;
                font-family: Verdana, Arial, Helvetica, sans-serif;
                font-size: 100%;
                line-height: 1.4;
                background-color: #42413C;
                background-position: center;
                left: auto;
                right: auto;
      /* ~~ this fixed width container surrounds the other divs ~~ */
      .container {
                width: 1260px; /* the auto value on the sides, coupled with the width, centers the layout */
                background-attachment: scroll;
                background-position: bottom;
                height: 640px;
                margin-top: 150;
                margin-right: auto;
                margin-bottom: auto;
                margin-left: auto;
                clip: rect(auto,auto,auto,auto);
                background-image: url(Homepage%20Layout%20/Web_BackGround1.gif);
      /* ~~ the header is not given a width. It will extend the full width of your layout. It contains an image placeholder that should be replaced with your own linked logo ~~ */
      .header {
                background-image: url(Homepage%20Layout%20/Banner.jpg);
                height: 150px;
                /* [disabled]background-attachment: scroll; */
                background-position: center bottom;
                width: 1260px;
      /* ~~ The footer ~~ */
      .footer {
      ;        width: 1260px;
                float: inherit;
                margin-top: 491px;
                height: 200px;
      </style>
      <script src="SpryAssets/SpryMenuBar.js" type="text/javascript"></script>
      <link href="SpryAssets/SpryMenuBarHorizontal.css" rel="stylesheet" type="text/css" />
      #apDiv1 {
                position:absolute;
                left:30px;
                top:213px;
                width:123px;
                height:361px;
                z-index:1;
      #apDiv2 {
                position:absolute;
                left:965px;
                top:31px;
                width:453px;
                height:79px;
                z-index:1;
      </style>
      </head>
      <body>
      <div class="container">
        <div class="header" id="logo">
            <div class="header"><!-- end .header -->      </div>
        </div>
          <ul id="MenuBar1" class="MenuBarHorizontal">
      <li><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=CTGY&Catego ry_Code=WA" class="MenuBarItemSubmenu">WOMEN'S ACCESSORIES</a>
            <ul>
                <li><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=CTGY&Catego ry_Code=WASTYLES_JEWELRY" class="MenuBarItemSubmenu">JEWELRY</a>
                  <ul>
                    <li><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=CTGY&Catego ry_Code=WASTYLES_JEWELRY">BRACELETS</a></li>
                    <li><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=CTGY&Catego ry_Code=WASTYLES_RINGS">RINGS</a></li>
                    <li><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=CTGY&Catego ry_Code=WASTYLES_SEMI-PRECIOUS">SEMI-PRECIOUS</a></li>
                  </ul>
                </li>
                <li><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=CTGY&Catego ry_Code=WASTYLES_SANDALS">SANDALS</a></li>
                <li><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=CTGY&Catego ry_Code=WASTYLES_WATCHES">WATCHES</a></li>
                <li><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=CTGY&Catego ry_Code=WASTYLES_KEYCHAINS">KEY CHAINS</a></li>
                <li><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=CTGY&Catego ry_Code=WASTYLES_HEADBANDS" class="MenuBarItemSubmenu">HEAD BANDS</a>
                  <ul>
                    <li><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=CTGY&Catego ry_Code=WASTYLES_RIBBON">RIBBON</a></li>
                    <li><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=CTGY&Catego ry_Code=WASTYLES_HB1">MINI PAPPAGALLO</a></li>
                  </ul>
                </li>
              </ul>
            </li>
            <li><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=CTGY&Catego ry_Code=PA" class="MenuBarItemSubmenu">PET ACCESSORIES</a>
              <ul>
                <li><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=CTGY&Catego ry_Code=PASTYLES_Ribbon">RIBBON</a></li>
                <li><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=CTGY&Catego ry_Code=PASTYLES_Reflictive">REFLECTIVE</a></li>
              </ul>
            </li>
            <li><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=abus">ABOUT US</a></li>
            <li><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=LOGN">ACCOUNT</a></li>
            <li><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=SRCH">SEARCH</a></li>
          </ul>
          <div class="footer">
            <table border="2" align="center" cellpadding="3" cellspacing="0" class="footer">
              <tr>
                <th bgcolor="#42413C" scope="col"><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=CTGY&Catego ry_Code=PA"><img src="Homepage Layout /QuickLinks/(home)QuickLink_Collars.jpg" width="300" height="214" alt="pet" /></a></th>
                <th bgcolor="#42413C" scope="col"><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=CTGY&Catego ry_Code=WASTYLES_SANDALS"><img src="Homepage Layout /QuickLinks/(home)QuickLink_Womens.jpg" width="300" height="215" alt="sandals" /></a></th>
                <th bgcolor="#42413C" scope="col"><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=CTGY&Catego ry_Code=WASTYLES_WATCHES"><img src="Homepage Layout /QuickLinks/(home)QuickLink_Watches.jpg" width="300" height="215" alt="watches" /></a></th>
                <th bgcolor="#42413C" scope="col"><a href="http://douglaspaquette.mivamerchant.net/mm5/merchant.mvc?Store_Code=DPI&Screen=CTGY&Catego ry_Code=WASTYLES_JEWELRY"><img src="Homepage Layout /QuickLinks/QuickLink_Jewlery.jpg" width="300" height="214" alt="jewelry" /></a></th>
              </tr>
            </table>
            <div align="center"></div>
          </div>
      <!-- end .container --></div>
      </div>
      var MenuBar1 = new Spry.Widget.MenuBar("MenuBar1", {imgDown:"SpryAssets/SpryMenuBarDownHover.gif", imgRight:"SpryAssets/SpryMenuBarRightHover.gif"});
      </script>
      </body>
      </html>
