1 Reply Latest reply on May 29, 2008 5:04 PM by tptackab
    List<MyType> to ArrayCollection of MyType instances?
    tptackab
      Is it possible to have a generically typed List (e.g.List<MyType>)
      instance variable on my object serialized to an ArrayCollection of
      MyType objects in the corresponding AS object? I've struggled for days
      on this and would greatly appreciate if anyone could tell me if it is
      possible.
      For example, I have a Java DTO object (AccountProfileDTO) that
      assembles various objects related to a user for transfer to the
      client (see code below). In Flex, I call a remote Java method that
      returns an AccountProfileDTO object.
      The Java method correctly populates the user (User) and
      userMedications (List<UserMedication>) instance variables on the DTO.
      However, when I examine the resulting AccountProfileDTO in Flex, I see
      the user field is correctly populated but the userMedications
      ArrayCollection is populated with AS Object instances instead of
      UserMedication instances. The Object instances contain the correct
      properties and values, but I would like to have the Objects strongly
      types as UserMedication instances just like the Java object.
      How do I do this, or is it not possible?
      Please see my source code below. I'm using Tomcat + Spring + Flex3. I have no idea where to find the "Attach Code" options, so I apologize if the code is hard to read.
      Tom
      ----- AccountProfileDTO (Java) --------------
      package com.ghs.dto;
      import java.util.List;
      import com.ghs.model.User;
      import com.ghs.model.UserMedication;
      public class AccountProfileDTO {
      private User user;
      private List<UserMedication> userMedications;
      public User getUser() {
      return user;
      public void setUser(User user) {
      this.user = user;
      public List<UserMedication> getUserMedications() {
      return userMedications;
      public void setUserMedications(List<UserMedication> userMedications) {
      this.userMedications = userMedications;
      ----- AccountProfileDTO (ActionScript) --------------
      package com.ghs.dto
      import com.ghs.model.*;
      import com.ghs.dto.*;
      import mx.collections.*;
      [Bindable]
      [RemoteClass(alias="com.ghs.dto.AccountProfileDTO")]
      public var user:User;
      public var userType:UserType;
      public var userAuthorities:ArrayCollection;
      public var userMedications:ArrayCollection;
      public var lastModUser:User;
      public var lastModUserType:UserType;
      public var lastModProvider:Provider;
      ---------------- UserMedication (Java) -------------------
      package com.ghs.model;
      public class UserMedicationKey {
      private String medication;
      private Long userId;
      public String getMedication() {
      return medication;
      public void setMedication(String medication) {
      this.medication = medication;
      public Long getUserId() {
      return userId;
      public void setUserId(Long userId) {
      this.userId = userId;
      ---------------- UserMedication (ActionScript) -------------------
      [Bindable]
      [RemoteClass(alias="com.ghs.model.UserMedication")]
      public class UserMedication extends UserMedicationKey {
      public var lastModBy:Number;
      public var lastModDate:Date;
      public var frequency:String;
      public var dateStarted:Date;
      public var strength:String;
      --------------UserMedicationKey (Java) ---------------------
      private String strength;
      private String frequency;
      public String getStrength() {
      return strength;
      public void setStrength(String strength) {
      this.strength = strength;
      public String getFrequency() {
      return frequency;
      public void setFrequency(String frequency) {
      this.frequency = frequency;
      --------------UserMedicationKey (ActionScript) ---------------------
      [Bindable]
      [RemoteClass(alias="com.ghs.model.UserMedicationKey")]
      public var userId:Number;
      public var medication:String;
        • 1. List&lt;MyType&gt; to ArrayCollection of MyType instances?
          tptackab Level 1
          Ok, it's starting to get clearer. Apparently one must explicitly include a reference to the typed object class held in the ArrayCollection for Flex to properly cast the objects.
          For example, here's my handler:
          public function loadProfileHandler(event:ResultEvent):void
          var accountProfile:AccountProfileDTO = event.result as AccountProfileDTO;
          for each(var userMed:UserMedication in accountProfile.userMedications)
          trace(userMed.medication);
          trace(accountProfile.userMedications);
          If I comment out the "for each" loop, I get back AS Object instances in the ArrayCollection. With the loop in place I get back UserMedication instances in the ArrayCollection (in the result even before the loop executes). Flex does not perform the cast without a reference to the typed object's class. That's strange!
          I seem to recall reading about this in the documentation, but it didn't make sense...until now. Is this a bug (I'm using BlazeDS so I'll probably wrongly assume FDS has the same problem)?
          I've designed several DTOs with Lists several levels deep in the object graph. Am I going to have to drill down and loop through all the lists in my DTO's object graph just to make sure ArrayCollection elements are properly cast to their appropriate type. Yikes!
          Hopefully someone will chime in and tell me there's a better way. :-)
