5 Replies Latest reply on Jan 12, 2012 2:34 PM by Bob Dix Photographer
    Capture HDV problems and crash
    RFendelman Level 1
      This is the first time I have tried to capture tape from my Sony Z7U HDV camera.  Usually, I just import the digital files from my digital back.  I am using an iMac 27"
      Problem 1: the captured files are mpeg.  How do I specify Quicktime files, or for that matter any other kind I want?  I do not see any setting choices anywhere.
      Problem 2: at 23:29:07 in my timeline, the frame goes to a solid color and from there on, the audio is way off sync.  at that frame number on the original tape, there is no obvious glitch. Maybe there is a dropped frame that is messing that up, but I can't see it.  In Preferences I selected to show dropped frames and there is no record of one.
      Problem 3: after I have completed the capture, a naming box appears.  When I close that box, PPro crashes.
        • 1. Re: Capture HDV problems and crash
          Harm Millaard Level 7
          Problem 1: iMAC
          Problem 2: is not a problem, it is a streak of luck you are not condemned to QuiRcktime.
          Problem 3: don't do that.
          • 2. Re: Capture HDV problems and crash
            RFendelman Level 1
            Are you, like, the official forum comedian?
            This is not helpful.
            • 3. Re: Capture HDV problems and crash
              Jim_Simon Level 8
              Harm got the numbering a bit off.
              Problem 1:  You can't change this.  The files are MPEG and you have no other options.
              Problem 2:  This is sometimes the result of shooting in MPEG.  Others with experience on this issue may be able to make some suggestions.  The only thing I can offer is not to shoot in MPEG.  (Meaning, get a diffrent camera.)
              Problem 3:  This shouldn't be happening.  Do you still have the captured clip on the hard drive after the crash?
              • 4. Re: Capture HDV problems and crash
                Some additional info:
                1. HDV is always mpeg, If you want quicktime you will have to downconvert in the camera to SD.
                2. If you get red frames that means there are dropped frames: capture with scene detection on that will reduce the sync problem. And run a cleaning tape once in a while.
                Don't use someone elses tapes.
                I have a hdv camera and never have seen red frames.
                3. no issues there.
                • 5. Re: Capture HDV problems and crash
                  Bob Dix Photographer Level 2
                  Do not use timecode in Premiere Pro 1.5.1 or CS 5.5.2 unless you have stripped the tape ( ie.but, run the new tape to record timecode,blank recording ) when videoing before hand, works perfectly on PC, no problems with over 100  Sony Pro Digital Master Tapes we have had issues with a Mac and never use it in other Media Business. At 1920 x 1080p do not use Quick time ,Some Macs do not like Anamorphic HDV/mpeg-2 The hybrid recording in this camera if 4.2.2 color space may be an issue ? Normally 4.2.0 to tape; Ask SONY SERVICE. In HDV Tape mode it is > 1440 x 1080 i , are your settings right ? Do not use Cinema Mode 24 fps unless you are going back to 35mm film, frankly there is no point ???
                  Have a good day ? But, what a great video camera !!!!!!!!!!!!!, the best of both worlds.
                  Experiment >Why don't you use the hard drive output,it may not be anamorphic, it may solve the problem ? or if desperate go to Sony Vegas Pro 11 ? Actually Sony Vegas Movie Studio Platinum 11 may even solve the issue.
                  Message was edited by: Bob Dix Photographer
