3 Replies Latest reply on Jan 11, 2012 9:43 PM by Stephen_Spider
    Sequence settings for varied Frame Rates
    BeansproutPro Level 1
      Greetings.  I am new to Premiere Pro and also new to working with different frame rates in the same project.  I am using footage from a Canon Vixia HF S10 and Flip video MinoHD.
      The frame rate of the Canon .MTS files seems to be 60fps.  The frame rate in the Flip .mp4 seems to be 24fps.  In other projects in FCP, I've converted the .MTS files to Mp4, but I'm not sure if that is necessary in PP5.5.
      My questions are:
      1. At what frame rate should I set my sequence?
      2. Is is advisable to convert the .MTS files and if so should I do so to match the Mg4 files exactly?
      3. What other pertinent information should I have to optimize quality?
      I appreciate any guidance without judgement on my limited knowledge .
      Thank You ~ L
      Intel Core 2 Duo
      2 GHz
      L2 Cache:          4 MB
      Memory:          3 GB
      Edit Drive:
        Capacity:          1.82 TB
        Available:          27.83 GB
        Writable:          Yes
        File System:          Journaled HFS+
        BSD Name:          disk3s2
