1 Reply Latest reply on May 30, 2008 6:47 AM by clbeech
    behavior panel timeline
    marianna78
      I put correctly from behavior panel in to key frame the action script :
      //Movieclip GotoAndPlay Behavior
      this.sfondoanimato.gotoAndPlay("anima immagine");
      //End Behavior
      but it doesn't work!!! Wy?
      I appreciate any solution possible
      thanks
        • 1. Re: behavior panel timeline
          clbeech Level 3
          with this script you are telling the MovieClip with the instance name of 'sfondoanimato' to gotoAndPlay at the frame labeled 'anima immagine'.
          are these things true?
          does the MC have the correct 'instance name'?
          does the MC contain a frame with the correct 'label'?
          are the spellings (including the 'space') correct in both of the above?
