2 Replies Latest reply on Mar 21, 2012 11:37 AM by saisri2k2
    How can I get the tab's index? (Question again)
    havefreetime Level 1
      Hi~ All~
      I'm new. so It's not easy everything. pls help me.
      This app has 5 link buttons and TabNavigator.
      1st Tab & 2st Tab can not be removed. If I click Tab1 link button, the 1st tab is chosen.
      and I click the Tab3 link button, 3st Tab can be created and chosen.
      When I click 'Close' button, the tab matching the number will be removed.
      <SOURCE CODE>
            xmlns:mx="library://ns.adobe.com/flex/mx"
            width="386" height="290" minWidth="955" minHeight="600">
      <fx:Script>
        <![CDATA[
         import spark.components.Button;
         private var flag_tab3:Boolean = false;
         private var flag_tab4:Boolean = false;
         private var flag_tab5:Boolean = false;
         private function check_Tab(num:int):void
          switch(num){
           case 0: break;
           case 1: break;
           case 2: if(!flag_tab3) add_Tab(num);
             break;
           case 3: if(!flag_tab4) add_Tab(num);
             break;
           case 4: if(!flag_tab5) add_Tab(num);
             break;
         tab.selectedIndex = num;    <- How can I get the num? The num is not fixed.
         // adding the tab
         private function add_Tab(num:int):void
          var child:NavigatorContent = new NavigatorContent();
          // Create the label
          var lbl:Label = new Label();
          lbl.text = "Sreen"+(num+1);
          // Create the button
          var btn:Button = new Button();
          btn.addEventListener("click", remove_Tab);
          btn.x = 43;
          btn.y = 110;
          btn.label = "Close";
          btn.width = 100;
          btn.height = 30;
          child.addElement(lbl);
          child.addElement(btn);
          tab.addChild(child);
          child.label = lbl.text;
          switch(num){
           case 2: flag_tab3 = !flag_tab3;
             break;
           case 3: flag_tab4 = !flag_tab4;
             break;
           case 4: flag_tab5 = !flag_tab5;
             break;
         // Remove the tab
         private function remove_Tab():void
          tab.removeChildAt(tab.selectedIndex);
      </fx:Script>
      <fx:Declarations>
        <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      <s:HGroup x="24" y="10" width="342" height="25">
        <mx:LinkButton label="Tab1" click="check_Tab(0)"/>
        <mx:LinkButton label="Tab2" click="check_Tab(1)"/>
        <mx:LinkButton label="Tab3" click="check_Tab(2)"/>
        <mx:LinkButton label="Tab4" click="check_Tab(3)"/>
        <mx:LinkButton label="Tab5" click="check_Tab(4)"/>
      </s:HGroup>
      <mx:TabNavigator x="24" y="67" width="343" height="200" id="tab">
        <!-- Screen1 -->
        <s:NavigatorContent width="100%" height="100%" label="Screen1" id="screen1">
         <s:Label text="Screen1"
            textAlign="center"/>
        </s:NavigatorContent>
        <!-- Screen2 -->
        <s:NavigatorContent width="100%" height="100%" label="Screen2" id="screen2">
         <s:Label text="Screen2"
      </mx:TabNavigator>
      </s:Application>
      The problem is....
      The number of tabs can be changed.
      If there is .getTabIndexByName(); method, I can create or choose the tab using button.
      How can I get the selectedIndex value?
      I think I can use .getElementIndex. But I don't know how to use it.
      and....
      To complete this program, do I have to use flag value... switch...  something else...
      My code is very poor. Is there good idea?
      Pls help me.
      Thank you.
      ps. sorry for my english... It's not my first language...
