5 Replies Latest reply on Jan 16, 2012 1:56 AM by snegig
    delete attribute xml Tags Help Please
    snegig Level 1
      Can anyone suggest me the how i can del attribute in keyterm tags.
      Only delete attribute olinkend kt-real-zero
      thank you
      Regards, snegig
        • 1. Re: delete attribute xml Tags Help Please
          absqua Level 4
          var doc = app.activeDocument,
                    attNodes = doc.xmlElements[0].evaluateXPathExpression("//keyterm[@olinkend = 'kt-real-zero']"),
                    i, l;
          for (i = 0, l = attNodes.length; i < l; i++) {
                    attNodes[i].xmlAttributes.item("olinkend").remove();
          Jeff
          • 2. Re: delete attribute xml Tags Help Please
            snegig Level 1
            Hi Jeff,
            Thank you so much for script.
            (1) Problem=>
            Jeff but i have another problem when i run this script message again and again
            i am click lots of time press OK OK OK then find result.
            (2) Problem=>
            My another problem is that if keyterm value change like this
            olinked = KT01401
            olinked = KT01402
            olinked = KT01403
            • 3. Re: delete attribute xml Tags Help Please
              snegig Level 1
              Hi Jeff,
              (1) Problem=>
              (2) Problem=>
              olinked = KT01401
              olinked = KT01402
              olinked = KT01403
              Kudos to you.
              Regards
              snegig
              • 4. Re: delete attribute xml Tags Help Please
                absqua Level 4
                1. I have seen the "Content contains characters which cannot be encoded." warning when importing xml, but have never tracked down what is going on. Nor have I ever seen content different in InDesign than what I was expecting after seeing this warning. Maybe it occurs when the xml being imported doesn't have the encoding attribute on the initial processing instruction, but InDesign figures out the encoding? I don't know.
                2. If you want to remove any olinked attribute on keyterm elements, just change the xpath expression in .evaluateXPathExpression to //keyterm[@olinkend] . If you want to match multiple specific values, just do //keyterm[@olinkend = 'KT01401' or @olinkend = 'KT01402' or @olinkend = 'KT01403'].
                Jeff
                • 5. Re: delete attribute xml Tags Help Please
                  snegig Level 1
                  Hi absqua,
                  Thank you so much for you script.
                  Thank you again for you heads up.
                  Kudos to you
                  regard
                  snegig
