1. Re: simple flip transition
Mark.Raykhenberg Jan 13, 2012 2:50 PM (in response to igregurec)Not familiar with weather.app, do you have a different example, is it like the iOS home screen navigation or like the iTunes CoverFlow?
2. Re: simple flip transition
Colin Holgate Jan 13, 2012 3:35 PM (in response to Mark.Raykhenberg)All iPhones have a Weather app, most likely on the first home screen. The one with a picture of the sun as the icon. Open that and then touch the info i in the bottom right corner. That's the effect he means. It's similar to the effect you get when touching the i in a Dashboard app, only with the iOS variation the window shrinks and grows as it spins around.
3. Re: simple flip transition
Mark.Raykhenberg Jan 13, 2012 3:41 PM (in response to Colin Holgate)Oh yes I see, the card flip effect. I would suggest the greensock TweenLite plugin it does a great job animating simple motions, I am not sure if it has a skew options but it does have all the regular tween features found in native flash so you would guess that it does?
http://www.greensock.com/tweenlite/
4. Re: simple flip transition
igregurec Jan 14, 2012 2:33 AM (in response to Mark.Raykhenberg)I've been using Caurina Tweener a lot a few years ago. Since is not developing right now ill try GreenSock tweeners. thank you
5. Re: simple flip transition
igregurec Jan 14, 2012 10:02 AM (in response to igregurec)here's a good example with a source file:
i've tried to insert bigger bitmaps (640x960). It's not smooth on the 3GS (for which 320x480 is just enough) but it works surprisingly better thanwhat i've tried to do in timeline.
