1 Reply Latest reply on Apr 24, 2012 4:18 AM by Marko Pelovic
    Error while debugging AIR for IOS app
    abeymg Level 1
      I get the following error when attempting to debug my AIR-IOS app on an IPad 2.
      The weird thing is that the logfile mentioned does not exist.
      Any ideas?
      - Abey
      # A fatal error has been detected by the Java Runtime Environment:
      #  EXCEPTION_UNCAUGHT_CXX_EXCEPTION (0xe06d7363) at pc=0x764db9bc, pid=5400, tid=9024
      # JRE version: 6.0_29-b11
      # Java VM: Java HotSpot(TM) Client VM (20.4-b02 mixed mode windows-x86 )
      # Problematic frame:
      # C  [KERNELBASE.dll+0xb9bc]
      # An error report file with more information is saved as:
      # C:\Users\ABEY~1.LEX\AppData\Local\Temp\AOT1326388929076\hs_err_pid5400.log
        • 1. Re: Error while debugging AIR for IOS app
          Marko Pelovic
          I have the same error.
          The wierd is that the log file doesn't exists.
          Anyway I try everything... to reinstal my Flash Builder, reinstall all versions of java. I even try to make Xmx and Xms bigger size.. but nothing... still got the error.
          If I create new project... then everything works fine... Export Release Build work very well,
          but if I try to Export Release Build for my large project... then this error comes up.
          I look at my code and no find any errors...
          Build for android works as well, the error comes up when I try to build for iOS.
          Please Adobe - give us help how to fix this.
          Thank you
