4 Replies Latest reply on Jan 12, 2012 8:10 PM by jo@shopologist
    Access "lost" CS files?
    jo@shopologist
      I just upgraded to Mac OS X 10.7.2 in order to get iCloud for my iPhone and lost access to my old InDesign CS and crucial documents.
      How can I "retrieve" everything I've created in CS?
      CS5.5 is way too technical and advanced (and costly) for my nonprofessional needs.
      CS3 would probably be more appropriate. Are those $99 downloads offered online safe/wise?
      Info and suggestions terribly appreciated!
        • 1. Re: Access "lost" CS files?
          John Hawkinson Level 5
          "lost"? What does that mean?
          Did you reformat your hard drive? If so, power off your computer immediately and send it to some place like Drive Savers and expect to spend a few hundred dollars on Data Recovery.
          No they're  neither safe nor wise nor legitimate. You'd have a hard time finding a legitimate CS5 purchase these days (though it is not impossible), but CS3 is essentially impossible.
          • 2. Re: Access "lost" CS files?
            jo@shopologist Level 1
            Sorry I was not clear. 10.7.2 does not support access to CS. The icon for the application in the dock is grayed out with a circle-slash over it.  When I click on the icon, I get a message that says "You can't open the application InDesign CS because Power PC applications are no longer supported."
            • 3. Re: Access "lost" CS files?
              Oh, I see. The problem is you do not own a more recent version of InDesign, and you were depending on Rosetta's in 10.5 or 10.6 ([Snow] Leopard) to run the PPC InDesign version.
              I think your best bet is probably to repartition your hard drive and install 10.6 alongside 10.7, and make it dual boot.
              • 4. Re: Access "lost" CS files?
                That sounds like a solution! Makes perfect sense.
                I will check with the professional who installs these upgrades for me and see if I have enough memory on my hard drive and if that will otherwise work on my computer.
                John, thank you very much for your help!
