1 Reply Latest reply on May 28, 2013 6:49 AM by nebbb
    Amazon Kindle problem using Flash Builder 4.6
    MintDouble
      Is there a way to specify a version of Air 2.7 using Flash Builder 4.6?  This would be handy for getting apps accepted by the Amazon App store for the Kindle.  Recently, I had an app accepted into the Amazon App store.  However, the App needs to use a version of Air that preceeds Air 3.1.  The version that I was advised to use is
      Adobe AIR v. 2.7.1.1999.
      I tried changing the 2nd line in the prog-app.xml file from:
      <application xmlns="http://ns.adobe.com/air/application/3.1">
      to
      <application xmlns="http://ns.adobe.com/air/application/2.7">
      However, this change led to an error:
      "See details for more information.
        Namespace 2.7 in the application descriptor file should be equal or higher than the minimum version 3.1 required by Flex SDK. "
      I recall that there was a temporary workaround for a similar problem with the Blackberry tablet OS.  The Blackberry OS problem was later solved and the fix is no longer necessary.  Perhaps, we need a work around for the Amazon Kindle to force the Flash Builder 4.6 to compile a release with Air 2.7.1.xx?
      Any ideas how to make this happen?
