5 Replies Latest reply on Jan 16, 2012 11:13 AM by Gonterman1201
    [AS][CS5]Use of Scripting Label no longer working from CS4 script
    lithodora Level 1
      We recently upgraded from CS4 to CS5.5. A good majority of my scripts no longer work.
      tell application "Adobe InDesign CS4"
        set contents of text frame "expdate" of page 1 of document 1 to "Works"
      end tell
      tell application "Adobe InDesign CS5.5" to
        set contents of text frame "expdate" of page 1 of document 1 to "Does not work"
      end tell
      There is a text frame with the script label of 'expdate'. I created the same document in CS4 & CS5.5.
      The above script works in CS4. It does not in CS5.5.
      I can't seem to find it in the guide what I am to change to.
      Any help on this?
        • 1. Re: [AS][CS5]Use of Scripting Label no longer working from CS4 script
          With CS5, some things have changed: http://forums.adobe.com/thread/615381
          Scroll down to read Shane Stanley's AS solution, or read the entire thread for a more complete understanding.
          • 2. Re: [AS][CS5]Use of Scripting Label no longer working from CS4 script
            lithodora Level 1
            I had seen that thread and I had tried using the method but got an error response.
            [Shane Stanley] wrote:
            Yes. To refer by item, you should use something like:
            item 1 of all page items whose label is "whatever"
            Instead of 'rectangle "photo1"', you need to use 'rectangle 1 whose label is "photo1"'.
            I tried to use:
              set myframe to item 1 of all page items of page 1 of active document whose label is "expdate"
                      set contents of myframe to "does not work"
            end tell
            Error is variable myframe is not defined.
            Then I tried
              set contents of item 1 of all page items of page 1 of active document whose label is "expdate" to "does not work"
            end tell
            that seems to work, but I have documents that have multiple items with the label. So, I'll make some sort of repeat to deal with that....
            Just an odd way of having to do it.
            • 3. Re: [AS][CS5]Use of Scripting Label no longer working from CS4 script
              sstanleyau Level 4
              I tried to use:
              end tell
              I'm a bit surprised -- your snippet works as expected here.
              • 4. Re: [AS][CS5]Use of Scripting Label no longer working from CS4 script
                lithodora Level 1
                Well I rebooted the computer and used that snippet again and it worked as I expected it to. Odd.
                Here's what I ended up doing:
                --CS5 Way
                  repeat with z from 1 to count of (every page item of page 1 of active document whose label is "expdate")
                  set myframe to (item z of all page items of page 1 of active document whose label is "expdate")
                  set contents of myframe to expdate
                  end repeat
                  --set contents of text frame "expdate" of page 1 of document 1 to expdate --CS4 Way
                It seems that what I was doing before only worked because CS4 would change every text frame whose label is "expdate" in one command.
                The CS5 method isn't that much different other than I must define which of the items to change.
                Is there a better way of going about this then?
                Message was edited by: lithodora
                • 5. Re: [AS][CS5]Use of Scripting Label no longer working from CS4 script
                  Gonterman1201 Level 1
                  Why not just version the script so it runs on 4? app.scriptPreferences.version = 6.0;
