This content has been marked as final.
Show 3 replies
1. Re: newbie: can't get lens blur depth map to work?
Dave LaRonde Jan 13, 2012 3:26 PM (in response to avpromedia)Put the solid with the ramp into a separate comp. Nest the comp in the main comp, and use it as the depth map.
You have to do that because AE processes things in a certain order.
2. Re: newbie: can't get lens blur depth map to work?
avpromedia Jan 13, 2012 8:54 PM (in response to Dave LaRonde)Thanks. Applying precomp to the ramp layer works. But I found out I have to click the non default radio button in the precomp dialog. The one that says put all effects in the new comp or something like that.
3. Re: newbie: can't get lens blur depth map to work?
Rick Gerard Jan 13, 2012 8:56 PM (in response to avpromedia)Yes, you have to move all attributes to the new composition. You're changing the rendering order so that the Ramp gets rendered before Lens Blur depth map uses it.
