9 Replies Latest reply on Jan 19, 2012 11:27 AM by Harm Millaard
    Titles sticks my preview
    Hilerowitz
      I'm using the CS5 and whenever I put a title on the timeline it sticks my preview. Only after I render the project I can preview with out problems.
      Does someone knows how to fix this problem?
      Thank You,
      Amir.
        • 1. Re: Titles sticks my preview
          Peru Bob Adobe Community Professional & MVP
          Does the title setting match the sequence setting?
          • 2. Re: Titles sticks my preview
            Jim_Simon Level 8
            This sounds like a case of your system not being up to the task of playing back unrendered footage.
            The common solution is to render, as you are doing.
            • 3. Re: Titles sticks my preview
              the_wine_snob Level 9
              Along the lines of Jim's observations, what are the full specs. of your system?
              • 4. Re: Titles sticks my preview
                Hilerowitz Level 1
                Thank you everyone,
                Hunt - Where do i find my system specs.?
                Please tell me and I'll write to you.
                Amir
                • 5. Re: Titles sticks my preview
                  You might have to look in a couple of places, to get it all.
                  First, I like dxdiag.exe (think that it's still the same utility in latest versions of Windows) for most of it, with both System and Display.
                  Then for the I/O (HDD's), you can go to My Computer and Properties.
                  • 6. Re: Titles sticks my preview
                    Hilerowitz Level 1
                    Ok, That is what if found - I put everything beacuse I dont know what you need to look at.
                    intel core i3-2100 CPU 3.10 GHz
                    4 GB RAM
                    64 bit
                    System Information
                    Time of this report: 1/19/2012, 19:46:58
                           Machine name: EDITING
                       Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110622-1506)
                               Language: English (Regional Setting: English)
                    System Manufacturer: INTEL_
                           System Model: DH61WW__
                                   BIOS: IBA GE Slot 00C8 v1365 PXE 2.1 B
                              Processor: Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz (4 CPUs), ~3.1GHz
                                 Memory: 4096MB RAM
                    Available OS Memory: 4074MB RAM
                              Page File: 3768MB used, 4378MB available
                            Windows Dir: C:\Windows
                        DirectX Version: DirectX 11
                    DX Setup Parameters: Not found
                       User DPI Setting: Using System DPI
                    System DPI Setting: 96 DPI (100 percent)
                        DWM DPI Scaling: Disabled
                         DxDiag Version: 6.01.7601.17514 32bit Unicode
                    DxDiag Notes
                          Display Tab 1: No problems found.
                            Sound Tab 1: No problems found.
                            Sound Tab 2: No problems found.
                              Input Tab: No problems found.
                    DirectX Debug Levels
                    Direct3D:    0/4 (retail)
                    DirectDraw:  0/4 (retail)
                    DirectInput: 0/5 (retail)
                    DirectMusic: 0/5 (retail)
                    DirectPlay:  0/9 (retail)
                    DirectSound: 0/5 (retail)
                    DirectShow:  0/6 (retail)
                    Display Devices
                              Card name: NVIDIA GeForce GTX 550 Ti
                           Manufacturer: NVIDIA
                              Chip type: GeForce GTX 550 Ti
                               DAC type: Integrated RAMDAC
                             Device Key: Enum\PCI\VEN_10DE&DEV_1244&SUBSYS_15573842&REV_A1
                         Display Memory: 2774 MB
                       Dedicated Memory: 993 MB
                          Shared Memory: 1781 MB
                           Current Mode: 1920 x 1080 (32 bit) (60Hz)
                           Monitor Name: Generic PnP Monitor
                          Monitor Model: SM2333T
                             Monitor Id: SAM0737
                            Native Mode: 1920 x 1080(p) (60.000Hz)
                            Output Type: HDMI
                            Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
                    Driver File Version: 8.17.0012.7533 (English)
                         Driver Version: 8.17.12.7533
                            DDI Version: 11
                           Driver Model: WDDM 1.1
                      Driver Attributes: Final Retail
                       Driver Date/Size: 5/21/2011 15:01:00, 15223912 bytes
                            WHQL Logo'd: Yes
                        WHQL Date Stamp:
                      Device Identifier: {D7B71E3E-5104-11CF-9F46-5B351FC2C535}
                              Vendor ID: 0x10DE
                              Device ID: 0x1244
                              SubSys ID: 0x15573842
                            Revision ID: 0x00A1
                    Sound Devices
                                Description: Speakers (Realtek High Definition Audio)
                    Default Sound Playback: Yes
                    Default Voice Playback: Yes
                                Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_80862017&REV_1003
                            Manufacturer ID: 1
                                 Product ID: 100
                                       Type: WDM
                                Driver Name: RTKVHD64.sys
                             Driver Version: 6.00.0001.6299 (English)
                                WHQL Logo'd: Yes
                              Date and Size: 1/25/2011 12:54:04, 2727912 bytes
                                Other Files:
                            Driver Provider: Realtek Semiconductor Corp.
                             HW Accel Level: Basic
                                  Cap Flags: 0xF1F
                        Min/Max Sample Rate: 100, 200000
                    Static/Strm HW Mix Bufs: 1, 0
                    Static/Strm HW 3D Bufs: 0, 0
                                  HW Memory: 0
                           Voice Management: No
                    EAX(tm) 2.0 Listen/Src: No, No
                       I3DL2(tm) Listen/Src: No, No
                    Sensaura(tm) ZoomFX(tm): No
                                Description: Realtek Digital Output (Realtek High Definition Audio)
                    Default Sound Playback: No
                    Default Voice Playback: No
                            Manufacturer ID: 1
                                 Product ID: 100
                                       Type: WDM
                                WHQL Logo'd: Yes
                                Other Files:
                                  Cap Flags: 0xF1F
                                  HW Memory: 0
                    Sound Capture Devices
                                Description: Microphone (Realtek High Definition Audio)
                      Default Sound Capture: Yes
                      Default Voice Capture: Yes
                                  Cap Flags: 0x1
                               Format Flags: 0xFFFFF
                    DirectInput Devices
                          Device Name: Mouse
                             Attached: 1
                        Controller ID: n/a
                    Vendor/Product ID: n/a
                            FF Driver: n/a
                          Device Name: Keyboard
                             Attached: 1
                        Controller ID: n/a
                            FF Driver: n/a
                          Device Name: Micr
                             Attached: 1
                        Controller ID: 0x0
                    Vendor/Product ID: 0x045E, 0x0745
                            FF Driver: n/a
                          Device Name: Micr
                             Attached: 1
                        Controller ID: 0x0
                            FF Driver: n/a
                          Device Name: Micr
                             Attached: 1
                        Controller ID: 0x0
                            FF Driver: n/a
                          Device Name: Micr
                             Attached: 1
                        Controller ID: 0x0
                            FF Driver: n/a
                          Device Name: Micr
                             Attached: 1
                        Controller ID: 0x0
                            FF Driver: n/a
                    Poll w/ Interrupt: No
                    System Devices
                         Name: VIA 1394 OHCI Compliant Host Controller
                    Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_30441106&REV_46\5&25BD0015&0&0000E0
                       Driver: n/a
                         Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 1 - 1C10
                    Device ID: PCI\VEN_8086&DEV_1C10&SUBSYS_20178086&REV_B5\3&11583659&0&E0
                       Driver: n/a
                         Name: NVIDIA GeForce GTX 550 Ti
                    Device ID: PCI\VEN_10DE&DEV_1244&SUBSYS_15573842&REV_A1\4&33B12EE1&0&0008
                       Driver: n/a
                         Name: Intel(R) 6 Series/C200 Series Chipset Family 2 port Serial ATA Storage Controller - 1C08
                    Device ID: PCI\VEN_8086&DEV_1C08&SUBSYS_20178086&REV_05\3&11583659&0&FD
                       Driver: n/a
                         Name: High Definition Audio Controller
                    Device ID: PCI\VEN_10DE&DEV_0BEE&SUBSYS_15573842&REV_A1\4&33B12EE1&0&0108
                       Driver: n/a
                         Name: Intel(R) H61 Express Chipset Family LPC Interface Controller - 1C5C
                    Device ID: PCI\VEN_8086&DEV_1C5C&SUBSYS_20178086&REV_05\3&11583659&0&F8
                       Driver: n/a
                         Name: Intel(R) 6 Series/C200 Series Chipset Family 4 port Serial ATA Storage Controller - 1C00
                    Device ID: PCI\VEN_8086&DEV_1C00&SUBSYS_20178086&REV_05\3&11583659&0&FA
                       Driver: n/a
                         Name: Intel(R) Management Engine Interface
                    Device ID: PCI\VEN_8086&DEV_1C3A&SUBSYS_20178086&REV_04\3&11583659&0&B0
                       Driver: n/a
                         Name: Intel(R) 82579V Gigabit Network Connection
                    Device ID: PCI\VEN_8086&DEV_1503&SUBSYS_20178086&REV_05\3&11583659&0&C8
                       Driver: n/a
                         Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
                    Device ID: PCI\VEN_8086&DEV_1C2D&SUBSYS_20178086&REV_05\3&11583659&0&D0
                       Driver: n/a
                         Name: 2nd generation Intel(R) Core(TM) processor family PCI Express Controller - 0101
                    Device ID: PCI\VEN_8086&DEV_0101&SUBSYS_20178086&REV_09\3&11583659&0&08
                       Driver: n/a
                         Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
                    Device ID: PCI\VEN_8086&DEV_1C26&SUBSYS_20178086&REV_05\3&11583659&0&E8
                       Driver: n/a
                         Name: 2nd generation Intel(R) Core(TM) processor family DRAM Controller - 0100
                    Device ID: PCI\VEN_8086&DEV_0100&SUBSYS_20178086&REV_09\3&11583659&0&00
                       Driver: n/a
                         Name: Intel(R) 6 Series/C200 Series Chipset Family SMBus Controller - 1C22
                    Device ID: PCI\VEN_8086&DEV_1C22&SUBSYS_20178086&REV_05\3&11583659&0&FB
                       Driver: n/a
                         Name: PCI standard PCI Express to PCI/PCI-X Bridge
                    Device ID: PCI\VEN_1283&DEV_8892&SUBSYS_20178086&REV_10\00000000832E738300
                       Driver: n/a
                    Device ID: PCI\VEN_8086&DEV_1C20&SUBSYS_20178086&REV_05\3&11583659&0&D8
                       Driver: n/a
                    DirectShow Filters
                    DirectShow Filters:
                    WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
                    WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
                    WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
                    MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
                    Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
                    WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
                    WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
                    Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
                    Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
                    ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.01.3761.0000
                    Avid DVBuffers,0x00200000,1,1,DVBuffers.ax,
                    WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
                    Record Queue,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
                    WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
                    WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.0513
                    WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
                    WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,15.04.3538.0513
                    WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
                    ffdshow DXVA Video Decoder,0xff800002,2,1,ffdshow.ax,1.01.3761.0000
                    ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.01.3761.0000
                    ffdshow Audio Decoder,0xff800001,1,1,ffdshow.ax,1.01.3761.0000
                    DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
                    MPC - Mpeg Source (Gabest),0x00400000,0,0,MpegSplitter.ax,1.05.0001.2910
                    Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
                    WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
                    Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
                    AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
                    VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
                    SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
                    Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
                    AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
                    StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
                    MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
                    MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
                    SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                    VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
                    MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
                    Sony Wave Hammer,0x00200000,1,1,sfhammer.dll,1.00.0000.0292
                    MPC - MP4 Source,0x00600000,0,0,MP4Splitter.ax,1.05.0001.2910
                    Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
                    SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
                    Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
                    MPC - FLV Splitter (Gabest),0x00600000,1,1,FLVSplitter.ax,1.05.0001.2910
                    Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
                    MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
                    WavPack Audio Decoder,0x00600000,1,1,WavPackDSDecoder.ax,1.01.0000.0484
                    DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
                    Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
                    Haali Media Splitter,0x00800001,0,1,splitter.ax,1.10.0348.0015
                    Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.10.0348.0015
                    Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
                    MPC - MP4 Splitter,0x00600000,1,1,MP4Splitter.ax,1.05.0001.2910
                    ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
                    madFlac Decoder,0x00600000,1,1,madFlac.ax,1.10.0000.0000
                    Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
                    MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
                    Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17713
                    Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
                    Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
                    Haali Video Renderer,0x00200000,1,0,dxr.dll,
                    File Writer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.0513
                    VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
                    WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
                    VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
                    File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
                    iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
                    iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
                    Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.10.0348.0015
                    DirectVobSub,0x00200000,2,1,vsfilter.dll,2.39.0005.0003
                    DirectVobSub (auto-loading version),0x00800002,2,1,vsfilter.dll,2.39.0005.0003
                    WAV Dest,0x00000000,0,0,,
                    DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17713
                    Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17713
                    Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.10.0348.0015
                    AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
                    RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
                    Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
                    WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
                    MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
                    DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
                    ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.01.3761.0000
                    SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
                    Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
                    madFlac Source,0x00600000,0,1,madFlac.ax,1.10.0000.0000
                    MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
                    Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
                    MPC - FLV Source (Gabest),0x00600000,0,0,FLVSplitter.ax,1.05.0001.2910
                    StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
                    Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
                    Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17713
                    AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
                    AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
                    MPC - MPEG4 Video Splitter,0x00600000,1,1,MP4Splitter.ax,1.05.0001.2910
                    Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                    MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                    Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                    File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
                    WavPack Audio Splitter,0x00600000,1,1,WavPackDSSplitter.ax,1.01.0000.0323
                    ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.01.3761.0000
                    MPC - Mpeg Splitter (Gabest),0x00400001,1,1,MpegSplitter.ax,1.05.0001.2910
                    Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
                    StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
                    AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
                    MPC - MPEG4 Video Source,0x00600000,0,0,MP4Splitter.ax,1.05.0001.2910
                    Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
                    File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
                    File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
                    Haali Video Sink,0x00200000,1,0,splitter.ax,1.10.0348.0015
                    Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
                    Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
                    BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
                    MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
                    Sony ExpressFX Chorus,0x00200000,1,1,sfxpfx2.dll,1.00.0000.0505
                    Sony ExpressFX Delay,0x00200000,1,1,sfxpfx2.dll,1.00.0000.0505
                    Sony ExpressFX Distortion,0x00200000,1,1,sfxpfx1.dll,1.00.0000.0505
                    Sony ExpressFX Equalization,0x00200000,1,1,sfxpfx2.dll,1.00.0000.0505
                    Sony ExpressFX Flange/Wah-Wah,0x00200000,1,1,sfxpfx1.dll,1.00.0000.0505
                    Sony ExpressFX Amplitude Modulation,0x00200000,1,1,sfxpfx2.dll,1.00.0000.0505
                    Sony ExpressFX Reverb,0x00200000,1,1,sfxpfx1.dll,1.00.0000.0505
                    Sony ExpressFX Stutter,0x00200000,1,1,sfxpfx1.dll,1.00.0000.0505
                    Sony ExpressFX Dynamics,0x00200000,1,1,sfxpfx3.dll,1.00.0000.0144
                    Sony ExpressFX Graphic EQ,0x00200000,1,1,sfxpfx3.dll,1.00.0000.0144
                    Sony ExpressFX Noise Gate,0x00200000,1,1,sfxpfx3.dll,1.00.0000.0144
                    Sony ExpressFX Time Stretch,0x00200000,1,1,sfxpfx3.dll,1.00.0000.0144
                    Sony Multi-Band Dynamics,0x00200000,1,1,sfppack2.dll,1.00.0000.0563
                    Sony Chorus,0x00200000,1,1,sfppack1.dll,1.00.0000.0568
                    Sony Distortion,0x00200000,1,1,sfppack3.dll,1.00.0000.0582
                    Sony Gapper/Snipper,0x00200000,1,1,sfppack3.dll,1.00.0000.0582
                    Sony Acoustic Mirror,0x00200000,1,1,sfmirror.dll,1.01.0000.0295
                    Sony Simple Delay,0x00200000,1,1,sfppack1.dll,1.00.0000.0568
                    Sony Reverb,0x00200000,1,1,sfppack1.dll,1.00.0000.0568
                    Sony Multi-Tap Delay,0x00200000,1,1,sfppack1.dll,1.00.0000.0568
                    Sony Graphic EQ,0x00200000,1,1,sfppack2.dll,1.00.0000.0563
                    Sony Smooth/Enhance,0x00200000,1,1,sfppack3.dll,1.00.0000.0582
                    Sony Clipped Peak Restoration,0x00200000,1,1,sfnrpack.dll,2.00.0000.0444
                    Sony Parametric EQ,0x00200000,1,1,sfppack2.dll,1.00.0000.0563
                    Sony Time Stretch,0x00200000,1,1,sfppack1.dll,1.00.0000.0568
                    Sony Noise Gate,0x00200000,1,1,sfppack2.dll,1.00.0000.0563
                    Sony Audio Restoration,0x00200000,1,1,sfnrpack.dll,2.00.0000.0444
                    Sony Click and Crackle Removal,0x00200000,1,1,sfnrpack.dll,2.00.0000.0444
                    Sony Noise Reduction,0x00200000,1,1,sfnrpack.dll,2.00.0000.0444
                    Sony Paragraphic EQ,0x00200000,1,1,sfppack2.dll,1.00.0000.0563
                    Sony Vibrato,0x00200000,1,1,sfppack3.dll,1.00.0000.0582
                    Sony Pan,0x00200000,1,1,sffrgpnv.dll,1.00.0000.0215
                    Sony Pitch Shift,0x00200000,1,1,sfppack1.dll,1.00.0000.0568
                    Sony Volume,0x00200000,1,1,sffrgpnv.dll,1.00.0000.0215
                    Sony Flange/Wah-wah,0x00200000,1,1,sfppack3.dll,1.00.0000.0582
                    Sony Graphic Dynamics,0x00200000,1,1,sfppack2.dll,1.00.0000.0563
                    Sony Amplitude Modulation,0x00200000,1,1,sfppack3.dll,1.00.0000.0582
                    WDM Streaming Tee/Splitter Devices:
                    Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                    Video Compressors:
                    WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
                    WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
                    MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
                    DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
                    ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.01.3761.0000
                    MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
                    Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
                    Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
                    Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
                    Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
                    Audio Compressors:
                    WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
                    WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
                    IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
                    Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
                    GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
                    CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
                    CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
                    MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
                    Audio Capture Sources:
                    Microphone (Realtek High Defini,0x00200000,0,0,qcap.dll,6.06.7601.17514
                    PBDA CP Filters:
                    PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
                    PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
                    PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
                    Midi Renderers:
                    Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
                    Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
                    WDM Streaming Capture Devices:
                    Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                    Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                    Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                    WDM Streaming Rendering Devices:
                    Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                    Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                    BDA Network Providers:
                    Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                    Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                    Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                    Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                    Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
                    Multi-Instance Capable VBI Codecs:
                    BDA Transport Information Renderers:
                    BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
                    MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
                    BDA CP/CA Filters:
                    Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
                    Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
                    PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
                    XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
                    WDM Streaming Communication Transforms:
                    Audio Renderers:
                    Speakers (Realtek High Definiti,0x00200000,1,0,quartz.dll,6.06.7601.17713
                    Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
                    Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
                    DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
                    DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
                    Realtek Digital Output (Realtek,0x00200000,1,0,quartz.dll,6.06.7601.17713
                    EVR Power Information
                    Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
                      Quality Flags: 2576
                        Enabled:
                        Force throttling
                        Allow half deinterlace
                        Allow scaling
                        Decode Power Usage: 100
                      Balanced Flags: 1424
                        Enabled:
                        Force throttling
                        Allow batching
                        Force half deinterlace
                        Force scaling
                        Decode Power Usage: 50
                      PowerFlags: 1424
                        Enabled:
                        Force throttling
                        Allow batching
                        Force scaling
                        Decode Power Usage: 0
                    • 7. Re: Titles sticks my preview
                      Two things that I see are the CPU - i3, and then the RAM - 4GB on a 64-bit system. That is barely enough to run a 64-bit OS.
                      Rendering for proper playback will probably be the only option.
                      Others will probably find many things that I missed.
                      • 8. Re: Titles sticks my preview
                        Hilerowitz Level 1
                        I see,
                        Thank you I hope I'll manage
                        • 9. Re: Titles sticks my preview
                          Harm Millaard Level 7
                          Rather unlikely, since you have installed so much stuff that you do not need on such a weak system which does not even meet minimum requirements, as at least two physical 7200 RPM SATA disks, you will have conflicts all over the place and a system performance that will make an elderly, handicapped snail laugh when challenged for a race.
                          Why have you installed ffdshow, Haali, Matroska, iTV and similar crap? It only slows down your system, that is already dead slow without this overhead.
                          Your titles stick because there is a serious amount of glue in your system to bring everything to a halt.
