15 Replies Latest reply on Sep 27, 2017 12:34 AM by Chris.Horgan
    Bouncing down to new track - mono!!
    CrispJB
      Hi - I'm using CS5.5 for Mac  and I want to be able to bounce edited, joined, multi-clips to new tracks in mono. The original tracks are all mono - but the bouncing function always produces a new track in stereo. Is there a setting somewhere that I've missed (I have looked exhaustively).
      As a workaround I have to use the 'convert sample' function in Edit view to create a mono track from the newly bounced stereo track and then add it back in to Multitrack view. This is extremely tedious in a complicated editing project.
      Anyone else come across this?
      Cheers
      CrispJB
        • 1. Re: Bouncing down to new track - mono!!
          SteveG(AudioMasters) Adobe Community Professional
          No, because we know how to do mono mixdowns!
          File>Export>Multitrack Mixdown, and then from the selection box you will be presented with, you can choose just about everything about the export format - including mono.
          • 2. Re: Bouncing down to new track - mono!!
            CrispJB Level 1
            Hi - thanks for the offer of help - though the patronising sarcasm is somewhat gratuitous.
            Are you using a Mac? There's only an option to mixdown an 'entire session' via the route you suggest - which of course I'd tried anyway. I want to be able to bounce individual tracks in (multitrack view) to mono.
            • 3. Re: Bouncing down to new track - mono!!
              What planet are you living on? Oh, I get it - Planet Mac...
              You didn't say that you'd already tried it, otherwise I wouldn't have very sarcastically suggested it in such a patronising way. So in an even more sarcastic and patronising way, I'm going to suggest that you hit the solo button on the track you want to export as mono before you do it. Although I don't really know why I'm bothering...
              • 4. Re: Bouncing down to new track - mono!!
                CrispJB Level 1
                Thanks - well you probably are bothering because somewhere in your austere psyche there's a hint of an idea that helping folk is more rewarding than being sour - though I'm not sure that's clicked yet.
                Talking of clicking - hitting the solo button before bouncing doesn't work either.
                I think I was pretty clear in my original post that I am using a Mac - just as you were making it clear to me that "we know how to do mono mixdowns!". Apparently not. :-)
                • 5. Re: Bouncing down to new track - mono!!
                  Well, it works fine here - and we do know how to do them. Just to make sure, I even tried it again. Whether you're using a Mac or not is irrelevant (which is why I didn't mention it) - the software works the same on both platforms from this POV. You might want to check that the Solo button is in 'exclusive' mode though - that might make a difference. And no, I don't think that this is its default mode; you might have to change it.
                  And I'm not being 'sour', or any of the other things you've suggested. You're just reading that wrong.
                  • 6. Re: Bouncing down to new track - mono!!
                    CrispJB Level 1
                    Ok - thanks - I believe you.
                    I'm afraid that doesn't work either (regardless of which mode solo is set to in Preferences).
                    • 7. Re: Bouncing down to new track - mono!!
                      So, if in a session you solo one track, so that material in other tracks is muted, and export the mixdown like that in mono, what do you get?
                      • 8. Re: Bouncing down to new track - mono!!
                        myscreennameis:RobbieS
                        @CrispJB : Did anyone get an answer to this??
                        ignor SteveG, does not understand the question.
                        In CS3 I could select clips on a track and bound them to MONO:
                        Edit>Bounce to New Track>Selected Audio Clips (Mono)
                        I want to do the same in CS6:
                        Currently I have to use CS3 'Loop while recording' so I'm thinking I might as well just uninstall CS6
                        because to many featues from CS3 were removed in CS6 and I find it user UNFRIENDLY.
                        • 9. Re: Bouncing down to new track - mono!!
                          Understand the question perfectly - there isn't an answer because, as you have observed, the function isn't there at present.
                          I'm thinking I might as well just uninstall CS6 because to many featues from CS3 were removed in CS6 and I find it user UNFRIENDLY.
                          No features from Audition 3 (not CS3) were removed in CS6 (only it was actually CS5.5) - they simply weren't implemented in a complete rewrite from the ground up. Not all features were re-implemented, simply because there wasn't sufficient time to implement them all before the externally-imposed deadline arrived. Some, but not all, have been added back in successive iterations. Yes, it's pretty much by popularity I think, although some things will likely never return, as they've been superseded by newer implementations. A typical example of this would be Scripting.
                          What I pointed out (several years ago), possibly too subtly, was that there are alternative ways of achieving a  mono bounce, and it's one of those that you have to use. I have no idea if the original 'bounce to mono' will be implemented - if you want it back, you'll have to submit a feature request.
                          Audition Feature Requests
                          • 10. Re: Bouncing down to new track - mono!!
                            Ric077 Level 1
                            Right click track, "Track>Duplicate Track"?
                            • 11. Re: Bouncing down to new track - mono!!
                              Bob Howes Adobe Community Professional & MVP
                              Be a bit careful.  This thread started on CS5.5 about 4 years ago.  There have been  lot of versions under the bridge since then.  I personally didn't bother with CS5.5 because it was the first version of a total re-write to make Audition compatible with Apple and a lot of items that had been in AA3 didn't make it into the first version.
                              • 12. Re: Bouncing down to new track - mono!!
                                Ric077 Level 1
                                Bob, I am on the latest version of Audition CC, and "Bounce Track" still makes a stereo track Out of a mono track. Problem is I do the bounce to make a destructable track for noise reduction, in this case, beer cooler in a bar scene. I cannot take a noise sample from the mono track and use it on the stereo track, and I have already split the dialogue tracks. I was searching for an answer when I came across this thread. There are a few others but no answer to this. "Duplicate Track" seemed the best answer I could find.
                                • 13. Re: Bouncing down to new track - mono!!
                                  If you want a mono export (is this what you are after?) then it's pretty simple to do. Highlight all the clips you want to export, right-click on them, and at the bottom of the list you will get an option saying Export Multitrack Mixdown. Open this, and you will get a dialog box. There are several 'change' options, and you need to select the bottom one - Mixdown options. You need to set it like this:
                                  If you do this you will get a mono mixdown of whatever clips you have selected, whether they are stereo or mono - makes no odds. If you put anything in the track options, you will get additional files; since you've set it to 'selected clips' though, you don't need to make any other selection at all.
                                  • 14. Re: Bouncing down to new track - mono!!
                                    paulfigg Level 2
                                    A few observations:
                                    If your Mono clips live on individual tracks in a Stereo Session, the contextual Bounce To New Track option will result in a Stereo file. Conversely In my environment Bounce To New Track in a Mono Session creates a Mono file.
                                    Also, let's not forget the extensive Mixdown Options. So for example if your Session is Stereo, and your included clips on individual tracks are Mono - you can easily create a Mono Bus Track and route to it. You are essentially creating a mono submix. In the Mixdown Options, tick the Bus/Submix, and then export. These options work as described regardless of the Session's original configuration (Mono or Stereo).
                                    -paul.
                                    • 15. Re: Bouncing down to new track - mono!!
                                      Chris.Horgan
                                      I guess everyone has their methods...
                                      I find that Bouncing is faster than Exporting - and less likely for stuffups. It doesn't require filenames and paths, doublechecking formats, etc. KISS and you are less likely to loose audio quailty along the way.
                                      What I do is bounce to get a stereo track. Then I double click to get into the wave editor - hit SHIFT T for "Convert Sample Type" to change it to mono. While I'm there, I also normalise the track.
