2 Replies Latest reply on Jan 15, 2012 3:21 PM by Steve Grisetti
    "Mismatch project settings preset"
    Saipotmarkus123
      I have tried to edit my films taken with a Flip Mino HD camera. The films show OK in the organizer but in the editor I can only hear the sound but the film does not show at all. Since I live in Sweden I choose PAL and there is no Flip-format choice in the menu as there is under the NTSC alternative.
      The message I get when adding clips to the editor says: " The format of the clips you are adding do not match the project setting format. For best results you should use a project preset that matches your clips. Do you want to change the project  settings to match your clips?"
      I answer Yes but it does not fix the problem.
      So, I wonder how I can find out what exactly is the difference in the settings between the clips and the project preset and what settings I should use?
      Thanks!
