6 Replies Latest reply on Jan 16, 2012 7:59 PM by Ryuken3k
    can't properly create motion tweens between two keyframes in flash CS4
    Ryuken3k
      I'm trying to create a flash animation of a wing flapping using three keyframes. The first keyframe is at frame 1. I then created a second keyframe at frame 5 by pressing F6, and then I created another keyframe at frame 10 by pressing F6. At frame 5, I rotated the wing so that it is going up. Frame 10 is the same as frame 1.
      frame 1: enter image description here
      frame 5: enter image description here frame 10: enter image description here
      I right clicked on a frame between frames 5 and 10 and then clicked the first option, "Create Motion Tween"; I then performed the same action on a frame between frames 1 and 5. When I preview or test the movie, there is no transition between the frames. From frame 1 to 5, there is supposed to be a transition of the wing flapping up. From frame 5 to 10, there is supposed to be a transition of the wing flapping downwards to its initial position. Instead, when I test the movie, the wing remains still until frame 5 and instantly goes to its "wing up state" and when it gets to frame 10, instantly goes to its "wing down state".
      Here is what the timeline looks like after I've made the changes mentioned above:
      I'm using Flash CS4 to make the animation but the tutorial I'm following is using Flash CS3. I know I can use other methods to create the motion tween but I want to know why the method I'm using isn't working.
