3 Replies Latest reply on Nov 22, 2013 7:48 PM by Bazinga_0223
    Will not print.
    michaelgabe40
      Each time I go to print a PDF into continues to go to "Print to File". How do I change this?
        • 1. Re: Will not print.
          Bernd Alheit Adobe Community Professional & MVP
          Disable the entry "Print to File" in the print dialog.
          • 2. Re: Will not print.
            Atul Agarwal Adobe Employee
            Dear michaelgabe40,
            If you have Adobe Reader version 10.1.2 then you may find the Print to file option by this method:
            1) Open any pdf and launch print dialog.
            2) Look for Advanced button on print dialog and click that.
            3) uncheck the print to file option on advance. print window
            If you have Adobe Reader version 10.1.1 or earler then you may find the print to file option by this method:
            2)You will find print to file at the bottom of print dialog.
            3) uncheck the print to file option on print window.
            This should resolve the problem.
            Atul
            • 3. Re: Will not print.
              Bazinga_0223
              I had a similar problem with Adobe Reader version 10.
              Everytime I would try to print a PDF, WHETHER OR NOT "print to file" was checked, Reader would try to print to file with a *.prn file.
              I checked all conceivable settings in all Reader and Print menu screens.
              Very maddening.
              I tried uninstalling and reinstalling Reader 10.  No workie.
              It was a problem with Adobe Reader 10 - not my computer (Win7).
              SOLUTION:
              I uninstalled version 10, reinstalled version 9, and everything is fine with printing PDFs.
              Logically, there is a problem with Version 10, with some computers (like mine).
              If you are having a similar problem, this is the easiest fix.
              I hope this helps.
