0 Replies Latest reply on Jan 16, 2012 10:59 AM by JaredHess
    Keeping Temporary Files Around? Need properly formatted .ali file for a CHM help.
    JaredHess Level 1
      As part of our localization process, I need to access the .ali file that is in the temporary folder. Back in RH 7, I could just copy the .ali file from the RH project, but in RH 9 it's now in an XML format and isn't in a format directly usable with CHM files. However, when RH compiles the CHM file, the .ali is changed into a format I need. Unfortunately, if I decompile the CHM file, the .ali file isn't there. So my only route is to grab it from the temporary build folder. If I'm compiling a large file, it's not a big deal because I have time to make a copy of the .h file in the temporary folder and paste it somewhere outside of the folder but for smaller projects the temporary folder is around for just a little while before it is removed.
      Does anyone know of a way to keep the temporary build folder around after compilation of a CHM file finishes so I can access this file?
      Jared
      RH 9.02
