5 Replies Latest reply on Mar 16, 2009 10:21 AM by ginafromtampa
    Outline (Multi Level)  Numbering
    Cruella101
      Is there an equivalent to Word's Outline number feature in bullets and numbering? I quite often have the need to have lists that look like the following:
      1. Some instruction.
      2. Another instruction.
      3. A question
      * if you answered yes to the question, do something
      * if you answered no, do something else
      4. Another instruction
      or
      1. Some text
      2. More text
      a) sub text for item 2
      b) another sub text for item 2
      3. More text
      Sometimes I'll need up to three levels of numbering. If I switch to bullets or a new numbering scheme in the middle of my list, the next item in the list ends up numbered incorrectly or not at all.
      Anita
        • 1. Re: Outline (Multi Level)  Numbering
          MergeThis Level 4
          Best practice for RH lists like these is to pretty much follow a similar process as in Word: number the entire outer list, and then work your way into the inner levels. The real difference is that you don't have Word's multiple options presented to you as templates. Instead, you need to step through part of the process.
          1. Create all the paragraphs that will constitute the list as Normal text (or remove all numbering from an existing list).
          2. Select all paragraphs and click the Create a Numbered List toolbar button.
          3. For sub-numbers, select "sublist" paragraphs and click the Increase Indent toolbar button. (You can then change the "sub" formats [a,b,c, i,ii,iii, etc.] through the Style menu.)
          4. For sub-bullets, perform step 3 and then, with the "sublist" paragraphs still selected, click the Create a Bulleted List toolbar button.
          This seems to be the only way to fool RH into not ending the numbered list when it sees a sublist, then starting a new list when resuming the outer list.
          The bothersome part is when you have to modify the list, because RH will try to "help" you by adding closing and opening tags as you add or delete content. Your choices are to either clean up the underlying code, or remove all numbering, make your changes, and perform steps 2-4 again.
          Leon
          • 2. Re: Outline (Multi Level)  Numbering
            Cruella101 Level 1
            Thanks. This seems to work. Now I just have to train myself not to play with the formatting/indents until I have all the items for the list in place.
            • 3. Re: Outline (Multi Level)  Numbering
              gdavism2m
              Leon,
              In RH6, considering numbered lists, what if I have numbered list then a note paragraph and then want to continue with the next numbered step? I have styles defined for my note text.
              For example:
              1. step 1
              Note: Note text
              2. step 2
              • 4. Re: Outline (Multi Level)  Numbering
                MergeThis Level 4
                AFAIK in RH6 & RH7, RH still very helpfully (it thinks) closes the current list before that interruption, then resumes it afterward. There's nothing for it but to manually fix that in the code.
                From your example, remove everything in bold:
                <li>step 1</li>
                </ol>
                <ul><li>
                <p class=whatever>Note: Note text</p> </li></ul>
                <ol>
                <li>step 2</li>
                etc.
                Leon
                • 5. Re: Outline (Multi Level)  Numbering
                  ginafromtampa
                  I'm having the same problem with RoboHelp 7: I wanted to use outlined numbered lists (such as 1.1.1) but you can't. However, RoboHelp 8 does. See the article on List Styles ("Advanced lists Creates a hierarchical or outline list, such as numbered heading styles, with numbering such as 1, 1.1, 1.1.1, and so on..."
                  Click the link below:
                  List Styles
