3 Replies Latest reply on Jan 17, 2012 3:52 PM by cclay53
    Dropdown List
    cclay53
      I have dropdown list that contains 8 items. The values are obviously 1-8 and refer to subforms.
      In code I have
      if (this.rawValue ==(1) {
           BaggerSub.presence="visible";
      elseif
           if (this.rawValue == "2"){
           BaggerSub.presence = "visible";
           ZipperSub.presence = "visible";
      endif
      The problem is if I select item 1 on the list nothing happens. If Iselect item 2, then the script for item 1 works. If I select item 3 thenthe script for item 2 works.
      I have the scripts in change.
      Any suggestions of where I went wrong.
      Craig
        • 1. Re: Dropdown List
          cclay53 Level 1
          Ok new information.
          If i choose an item and then choose it again it will load properly.
          • 2. Re: Dropdown List
            radzmar Adobe Community Professional & MVP
            I think you're using the change:Event for your script.
            In this case, the rawValue is not available, as it is set as very last.
            Use xfa.event.newText instead.
            if (xfa.event.newText === "1") {
                 ZipperSub.presence = "invisible";
            else if (xfa.event.newText === "2") {
            • 3. Re: Dropdown List
              cclay53 Level 1
              ok. That doesn't seem o work. But what i did do is move my script from a change event to exit and it works-
              Thank you.
              Craig
