0 Replies Latest reply on Jan 16, 2012 7:17 PM by yoyonbo
    Off the Padding on UITextFieldGridItemRenderer and DataGrid
    yoyonbo
      Hi. Now I use the customized UITextFieldGridItemRenderer on spark.components.DataGrid
      My purpose is drawing background color of the cell when user click it and dataProvider is changed.
      I could draw the color by setting the UITextFieldGridItemRenderer.backgroundColor.
      But some pixel paddings are remaining in the cell. I want to fill cell entirely.
      I could implement same application by using GridItemRenderer. But it scrolls very slowly.
      Does anyone know the way?
      following is my renderer code.
      <s:UITextFieldGridItemRenderer  xmlns:fx="http://ns.adobe.com/mxml/2009"
                                              xmlns:mx="library://ns.adobe.com/flex/mx" >
                <fx:Script>
                          <![CDATA[
                                    import spark.components.gridClasses.GridLayer;
                                    private static const yellow:uint = 0xffff66;
                                    private static const pink:uint = 0xffcccc;
                                    private static const white:uint = 0xffffff;
                                    override public function prepare(hasBeenRecycled:Boolean):void {
                                                   var workCode:String = data[column.dataField];
                                                   if(workCode != null) {
        workCode = workCode.substr(4,2);
                                                   var newField:String = column.dataField;
                                                   var orgField:String = column.dataField + "_org";
                                                   if(data[newField] != data[orgField]) {
                   this.background = true;
        this.backgroundColor = pink;
              } else {
        this.background = false;
                                                   label = workCode;
                </fx:Script>
      </s:UITextFieldGridItemRenderer >
