1. Re: problem with importing raw files
c.pfaffenbichler Jan 17, 2012 8:10 AM (in response to jmcp12)Is that in the developes file or in the Camera Raw dialog?
2. Re: problem with importing raw files
Tai Lao Jan 17, 2012 8:12 AM (in response to jmcp12)Looks like a hardware issue. If the artifacts do not print, it could be your video display card.
However, more likely is a hard disk, SCD card, or USB cable/connection problem. In all of these cases, the artifacts would print.
If you can post a link to one of the affected raw image files, others can attempt to open it on their/our computer.
____________
Wo Tai Lao Le
我太老了
3. Re: problem with importing raw files
Tai Lao Jan 17, 2012 8:13 AM (in response to jmcp12)It could also be radio frequency interference.
____________
Wo Tai Lao Le
我太老了
4. Re: problem with importing raw files
RenéG Jan 17, 2012 8:17 AM (in response to jmcp12)I agree with Tai Lao, it could be a cable/connection problem either with your card reader or the hard drive the photos are on.
I had that happen a few years ago and it was the card reader connection. I made sure it was tight and secure and re-imported the images from the card and everything was fine.
5. Re: problem with importing raw files
jmcp12 Jan 17, 2012 8:19 AM (in response to RenéG)ok brilliant, im going to try re-importing them, have a very cheap card reader so maybe thats it , thanks ill let you know if that solves it in a few minutes
6. Re: problem with importing raw files
jmcp12 Jan 17, 2012 8:32 AM (in response to jmcp12)hurray its fixed! i just went straight from camera instead of using the cheap card reader. thanks so much would never have guessed thought it was a broken sensor in my camera!
7. Re: problem with importing raw files
RenéG Jan 17, 2012 8:54 AM (in response to jmcp12)Glad it's fixed.
Nowadays good card reader are cheap; for $40-$50 you can get a good one.
