2 Replies Latest reply on Jan 17, 2012 11:06 PM by scaleheights89
    editable property for mx:Object
    scaleheights89
      <mx:Object  dataField = "name" primaryKey = "true" editable = "true" updatable = "false" needToBlank = "true"/>
      In this, Can someone explain what is the use of properties editable , updatable and needToBlank?
      What happerns when each one is set to "false"?
        • 1. Re: editable property for mx:Object
          Flex harUI Adobe Employee
          Can’t tell without more context.  That is the same in ActionScript as:
          Var foo:Object =
          • 2. Re: editable property for mx:Object
            scaleheights89 Level 1
            i have the code
            <mx:ArrayCollection/>
            </mx:ArrayCollection/>
            In a separate .as file, i have the following method:
            public function upd1(a:ArrayCollection) : void{
            var b :ArrayColection;
            for(i=0:int;i<a.length;i++) {
            var sample:Object = a.getItemAt(i) as Object;
            var dataField : String = sample.dataField;
            if (sample.hasOwnProperty("updatable"))
            b.addItem(dataField);
            i dont see the upd1 method acting on the field "name".
