I am in process of upgrading Robohelp 7 to Version 9. My Projects were upgraded sucessfully. I was able to open them locally with no problems. I am using Visual sourcesafe to deploy htm files on the Server. When I looked in the browser the formatting was gone (Style sheet was not applied). I opened the project in Robohelp 9 and see the correct style sheet was selected. In the Html view, the CSS code was there.
<link rel="StyleSheet" href="../styles.css" type="text/css" />
I assigned "none" then reapply the style sheet on the page and then I was able to see the correct formatting in the browser.
If it is a small project I would have go to each page and do the same but I have two big projects with around 2500 pages each. Is there any easy way to do it?
Thanks in Advance.
In the topic pane, select all the files, right click and select properties. You can now select the CSS for multiple files at once.
Greet,
Willam
Greet,
Willam
Thank you Willam..
I am able to apply the stylesheet on all at once. Still in process of deploying these files.
Rick.. I am using VSS to deploy the html files on the web server. Using it to share, Save all versions and deploy on web server.
Hi there
Can you expound on that process? Typically VSS is used to share work, not to deploy content. So I'm more than a bit curious here.
Cheers... rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7, 8 or 9 within the day! |
