4 Replies Latest reply on Jan 22, 2012 2:07 PM by Clack909
    Adobe 10.1.2 reader Customization Wizard
    Clack909
      I downloaded the following Exe from adobe yesterday to distribute via SCCM 2007.
      AdbeRdr1012_en_US.exe
      I extracted the exe above and used the Adobe Cusotmization Wizard X to confiure the package for SCCM deployment.  My problem is the extraced msi appears to install version 10.1.0.
      If i run AdbeRdr1012_en_US.exe manually it installs the correct version 10.1.2 what am I doing wrong? Any help would be appreciated.
        • 1. Re: Adobe 10.1.2 reader Customization Wizard
          ARM2705 Adobe Employee
          Upon extracting AdbeRdr1012_en_US.exe, you should see AcroRead.msi file along with Reader 10.1.2 msp file plus few more files. As you are customizing AcroRead.msi and so running it, will end up installing 10.1 since you have not included 10.1.2 patch.
          However, while running AdbeRdr1012_en_US.exe, this in turn runs the setup.exe file, which read Setup.ini file, where10.1.2 patch is referred and hence ends up installing 10.1.2.
          You can do the following,
          Once you have extracted the exe and customized AcroRead.msi. Use the below command line to install Reader 10.1.2,
          msiexec /i AcroRead.msi PATCH="<path to AdbeRdrUpd1012.msp>" TRANSFORMS="<path to transform file .mst>"
          • 2. Re: Adobe 10.1.2 reader Customization Wizard
            Clack909 Level 1
            Extracting AdbeRdr1012_en_US.exe produces the following files.
            ABCPY.INI
            AcroRead.msi
            Data1.cab
            setup.exe
            setup.ini
            There is no 10.1.2 msp file as you mentioned.
            • 3. Re: Adobe 10.1.2 reader Customization Wizard
              How are you extracting ?
              Use the following command line to extract,
              AdbeRdr1012_en_US.exe -sfx_o"<extraction path>" -sfx_ne
              e.g. if you want to extract to c:\ddd
              you should run the following command,
              AdbeRdr1012_en_US.exe -sfx_o"c:\ddd" -sfx_ne
              You should see the following six files,
              ABCPY.INI
              AcroRead.msi
              AdbeRdrUpd1012.msp
              Data1.cab
              setup.exe
              Setup.ini
              • 4. Re: Adobe 10.1.2 reader Customization Wizard
                Clack909 Level 1
                Thank you very much for your assistance I now have a working SCCM package.
