7 Replies Latest reply on Aug 11, 2006 6:33 AM by $era
    Active Button States
    KrisCons Level 1
      Hi All,
      I am trying to achieve creating active button states in flash within my movieclip. My guess is it needs to be more technical than what I am attempting so if someone can point me in the right direction or even provide a snippet of code that will help, I would appreciate it.
      What I have so far:
      I have 3 button movieclips on stage each with the their own instance names (button1, button2 and button3). They have 3 keyframes, "up", "over" and "active".
      The code for button1 is as follows (and the others are similar as you can guess):
      on(rollOver) {
      _root.button1.gotoAndStop(2); // over state
      on(rollOut) {
      _root.button1.gotoAndStop(1); // up state
      on(release) {
      _root.button1.gotoAndStop(3); // active state
      _root.button2.gotoAndStop(1); // set this to up state
      _root.button3.gotoAndStop(1); // set this to up state
      Obviously this works until I move my mouse away from over the top of the button I have pressed becauseof the on(RollOut) event.
      Any suggestions on how I can get this to remain as the Active state until i click another button please?
      Regards
      K
        • 1. Re: Active Button States
          Darshan Rane Level 3
          hi
          i rollout state
          on(rollOut) {
          if(flag1 == false) //flag3 : boolean var
          else
          and in release
          on(release) {
          flag1 == true;
          flag2 = false;
          flag3 = false;
          remember to do this for every button
          hope it works
          its only to check if button is clicked or not
          • 2. Re: Active Button States
            KrisCons Level 1
            Hi
            Not a actionscript guru so could you please indicate how and where i declare the flag variable? Is it on each button instance or just on a Actions layer keyframe?
            What would the syntax be?
            • 3. Re: Active Button States
              KrisCons Level 1
              Hi
              I amended the code to the following: (only testing one button here)
              on(rollOver) {
              if(isactive == true) {
              _root.button1.gotoAndStop(3); //active state already on
              } else {
              _root.button1.gotoAndStop(2); //over state
              on(rollOut) {
              _root.button1.gotoAndStop(3); // leave active
              } else {
              _root.button1.gotoAndStop(1); //over state
              trace(isactive);
              on(release) {
              isactive == true;
              When the trace is run, the variable isactive is UNDEFINED. Why is this?
              Tahnks in advance
              • 4. Re: Active Button States
                declare these var
                var isactive : Boolean
                isactive = false
                • 5. Re: Active Button States
                  delare it on separete actions layer
                  on a frame before your buttons frame comes
                  isactive = false
                  even i am a learner in AS not a guru
                  • 6. Re: Active Button States
                    KrisCons Level 1
                    Hi
                    I have done what you said but isactive is constantly undefined.
                    I have an actions layer with the following in keyframe 1:
                    var isactive:Boolean;
                    isactive == true;
                    And I have another layer containing my button_mc instance which has the following code:
                    on(rollOver) {
                    _root.button1.gotoAndStop(3); // active state already on
                    } else {
                    _root.button1.gotoAndStop(2); // mouse over state
                    on(rollOut) {
                    _root.button1.gotoAndStop(3); // leave active as it is
                    } else {
                    trace(isactive);
                    on(release) {
                    isactive == true; // set isactive var to true
                    If you can spot any problems then please point them out, otherwise I'll give up!
                    Cheers
                    • 7. Re: Active Button States
                      $era
                      Hi
                      i thing the promblem is mistyped in your code a very small but very commone.
                      when you want to assign a value to a variable you use single equal sign( = ),
                      but when you wanna check for equality between two values you use double equal sign ( == ).
                      i hope that will help you.
                      isactive == true;
                      on(rollOver) {
                      } else {
                      on(rollOut) {
                      } else {
                      trace(isactive);
                      on(release) {
