3 Replies Latest reply on Jan 18, 2012 7:53 AM by Rahul7777
    flex validations
    Rahul7777
           Hi everyone,
                                 My application has 8 modules and each with around 25 fields, for validation, i should have 200 validators??, can i hook all phonenumbers to one like that,
      Ex:
               HomePhone, OfficePhone, CellPhone should have one call to validator not 3 validators,
      <mx:StringValidator id="validContactTitle"
                                  source="{tiContactTitle}"
                                  property="text"
                                  valid="ValidField(event)"
                                  invalid="InvalidField(event,data,'JobTitle_Required')"
      Here source can take any arrayCollection like that i googled but with no luck...
      Based on valid or invalid i have to do lot of logic inside so i  can't loop it.
      any help is appreciated.
        • 1. Re: flex validations
          senthil s
          Hi Rahul ,   You can use single validater for several sources    eg:            if you are using 4 textinput means  use that id as validater source  eg:  string_Validater.source=TextInput_id_1; string_Validater.source=TextInput_id_2; string_Validater.source=TextInput_id_3; string_Validater.source=TextInput_id_4;  Try dis it will work...  Reg, Senthil.
          • 2. Re: flex validations
            Rahul7777 Level 1
            Thanks senthil for your reply,
            i think validator source is of type object, it will take the last one, not all
            x=y;
            x=i;
            x=j;
            x=k;
            x will be k right????
            let me try and give you quick reply .
            • 3. Re: flex validations
              Rahul7777 Level 1
              Can you run this example: will give you some idea.
                             xmlns:mx="library://ns.adobe.com/flex/mx"
                             minWidth="955" minHeight="600"
                             creationComplete="application1_creationCompleteHandler(event)">
                  <fx:Script>
                      <![CDATA[
                          import mx.events.FlexEvent;
                          import mx.events.ValidationResultEvent;
                          protected function application1_creationCompleteHandler(event:FlexEvent):void
                              pnV.source = phoneInput;
                              pnV.source = zipCodeInput;
                              pnV.source = city;
                              pnV.source = state;
                          protected function pnV_validHandler(event:ValidationResultEvent):void
                              trace("valid handler " + event.currentTarget.source.name);
                          protected function pnV_invalidHandler(event:ValidationResultEvent):void
                              trace("invalid " + event.currentTarget.source.name);
                  </fx:Script>
                  <fx:Declarations>
                      <!-- Place non-visual elements (e.g., services, value objects) here -->
                      <mx:PhoneNumberValidator id="pnV"
                                               property="text" valid="pnV_validHandler(event)" invalid="pnV_invalidHandler(event)"/>
                  </fx:Declarations>
                  <s:VGroup>
                      <mx:TextInput id="phoneInput" name="phone"/>
                      <mx:TextInput id="zipCodeInput" name="zip"/>
                      <mx:TextInput id="city" name="city"/>
                      <mx:TextInput id="state" name="state"/>
                  </s:VGroup>
              </s:Application>
