1. Re: Indents & Tabs
Eugene Tyson Jan 18, 2012 3:43 AM (in response to Muppet Mark)The text engine would have been updated for CS3, CS4 and CS5 and CS5.5 - so there could be discrepencies in how text is handled in later versions.
You might have better success opening the CS2 file in CS2 and exporting it to an INX. Then open the INX file in the newer version of the software.
Although - it could be an entirely different issue.
If you can supply sample files and step by step to recreate the issue too, that would be great.
2. Re: Indents & Tabs
Muppet Mark Jan 18, 2012 4:17 AM (in response to Eugene Tyson)Thanks Eugene, I'll go look for some samples in my files… This has happened consistently over a 500 catalogue around 30 documents in all… Not all pages thankfully just where tabs sit on top of indents… I told the boss that the issue was probablly the result of a text engine change… I just want to know how best to proceed with other jobs where I may get this again…
Here is a snapshot of a text frame not behaving properly… The first tabs are not pushing the text to where I would expect them… There are graphical icons in another layer above that sit down the key…
Then the very same box which I can move either right or left hand bounds then snap back in to my column guides?
I will have to delete all the junk out of a file to make a sample as it now appears to me that cut & paste also fixes the dammed box…?
3. Re: Indents & Tabs
Eugene Tyson Jan 18, 2012 4:35 AM (in response to Muppet Mark)The only other thing I can think of is if you
1) Export the CS2 files to INX and open them
or
2) Export the CS5 files to IDML and open them
See if either of those fix the issues?
4. Re: Indents & Tabs
Muppet Mark Jan 18, 2012 5:16 AM (in response to Eugene Tyson)Eugene, I no longer have a box with CS2 on it… Moved to a new mac with CS5 so Im opening and doing a 'save as' with the [converted] document… After a little experimenting it would appear that option 2 works… At least I only have to jump thru the one extra save hoop… ( thats NOT too bad ) IDML constructs an NEW document so it should 'recompose' the text correctly I suppose? The other methods force the text to 'recompose'… I have my route at least… TVM
5. Re: Indents & Tabs
Bob Levine Jan 18, 2012 5:21 AM (in response to Muppet Mark)Correct. When you open an older file, InDesign will maintain the text flow until you work on a story. By going to INX/IDML you force that right out of the gate through the entire document.
Bob
6. Re: Indents & Tabs
Muppet Mark Jan 18, 2012 5:45 AM (in response to Bob Levine)Bob, I will put all my older jobs on pre-wash… At least I don't have to make a script for this now… result.
7. Re: Indents & Tabs
Eugene Tyson Jan 18, 2012 5:50 AM (in response to Muppet Mark)You could make a script to open the folder of InDesign files and export to IDML - then reopen them and save as the same name to a different folder.
That would be cool.
8. Re: Indents & Tabs
Muppet Mark Jan 18, 2012 5:59 AM (in response to Eugene Tyson)I have played with exporting files to IDML from within Bridge as a background process… but that was for another purpose ( too slow )… It's worth re-considering for this fixer thou… there goes another weekend…
9. Re: Indents & Tabs
Peter Spier Jan 18, 2012 6:15 AM (in response to Muppet Mark)You might want to try the Recompose All Stories command. Cmd + Opt + / on Mac, Ctrl + Alt + / on Windows.
