8 Replies Latest reply on Jan 18, 2012 6:40 AM by Peter Spier
    Indesign crashes when updating incopy assignments!
    Limon26
      I've read through some forums and it appears others are having this problem.
      When I open indesign and it says do you want to update links (referring to the incopy assignements) that need updated.
      I click ok, and Indesign crashes!!!!
      One thing I read could be the issue....
      - anchored objects, (incopy can't handle all the anchored objects)
      That is RIDICULOUS if that is the issue.  If so, Adobe should have had a disclaimer....don't buy incopy if you plan on having more than text in your document.
      There are no error messages that come up, the program just crashes.  I'm using Indesign CS5 version 7.
      A solution I read was to save the indesign file that keeps crashing when updating the assignments as an .idml file.
      I tried this and it appeared to work, but what a joke!
      This is very unreliable and has caused a lot of stress.
      Anyone else have any solutions or can ADOBE come up with a solution???
