6 Replies Latest reply on Sep 4, 2006 11:24 AM by CatBandit
    Check Box
    xxColeSmackXX
      Now I'm just trying out Capture and I've noticed something that I may just be overlooking. I know how to create a Click Box to but is there a way to make that click box a check box? I ended up just doing a simple rollover image just curious if there is an easier way.
      thanks
        • 1. Re: Check Box
          Hi xxColeSmackXX and welcome to our community
          Unfortunately, Captivate does not offer a check box as an option. If you feel it would be useful, I would encourage you to sumbit an enhancement request using the following link.
          Click here to visit the wish form
          Sincerely... Rick
          • 2. Re: Check Box
            CatBandit Level 3
            I'm a little bit curious/confused here, folks. For years we have "filled in" a blank check-box by simply putting a click-box over it, set to "jumpto" the following slide which is displaying the "checked" condition (naturally you can reverse the polarity of this to show a "un-ticking" action, vice "ticking").
            Is there some reason why this won't be sufficient for your needs, " xxColeSmackXX"?
            P.S. Okay Rick, what am I missing? It's Thursday, not Monday, and I've had 2 cups of coffee . . . the mention of a rollover really throws me because I can't see a way to make a rollover do as a replacement for a check-box at all . . .
            • 3. Re: Check Box
              Hi Larry
              Hmmm, I think I must have been led down an odd path by the mention of a rollover image. I was thinking of a live check box. I'm assuming xxColeSmackXX must have been referring to an image of an UN-selected check box that would change to showing a check mark when rolled over. But you are absolutely correct in that one could achieve this in the manner you outlined. I think what probably exacerbated my weird way of thinking was that I visualized multiple check boxes that could arbitrarily be in selected/unselected states. Programming this via different images on different slides could be a daunting task to say the least. ;) (Think perhaps a column of 5, with different possibilities)
              Cheers... Rick
              • 4. Re: Check Box
                CatBandit Level 3
                Yeah Rick, I see what you mean. " xxColeSmackXX", perhaps you can help us help you by defining more clearly what you want to happen; that is, what should be seen on the end-user's screen before and after some "event" occurs, and exactly what the "event" is that will trigger the appearance of this *something* (rollover, mouse-click, etc.).
                Have I made myself clear? Hope so.
                • 5. Re: Check Box
                  xxColeSmackXX Level 1
                  I was wanting to do multiple Check Boxes on the same page.
                  • 6. Re: Check Box
                    CatBandit Level 3
                    quote:
                    That certainly did little to clear up my confusion, but maybe Rick "gets it" and can respond with something more intelligent than I am about to offer ....
                    Just place as many click-boxes as you need on the background and set each up as needed. The only danger is getting them over-lapping, which could cause some confusion at play-time. Good luck!
